Lift and offset for 35’s?
Discussion in 'Wheels & Tires' started by Dullrich22, Apr 16, 2021.
  1. Apr 16, 2021 at 11:26 AM
    Dullrich22
    Dullrich22 [OP] New Member
    2021 Crewmaxx limited
    None yet, lift & tire shopping
    New user here!
    Just got put of the Ford game and bought the most American truck on the market. Wanted a naturally aspirated V8 without this Auto start/stop BS and I think I’ve made the right decision.
    Purchased a 2021 crew max Limited in the charcoal grey.
    I’m considering lift and wheel options to clear 35’s with no body mount chop. 4.5” or 6”
    Any suggestions for offset without too much deep dish and preferably no fake bolt heads or bead locks?
  2. Apr 16, 2021 at 11:42 AM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
  3. Apr 16, 2021 at 11:50 AM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    You can run 35's on a 3" lift. Any higher then 3" you're just getting additional height.
    biebs96 and YotaBro like this.
  4. Apr 16, 2021 at 11:52 AM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    I agree, I wouldn’t go any higher than 3”. I’m currently running 2.5” lift with narrow 35’s no BMC
    biebs96 likes this.
  5. Apr 16, 2021 at 11:54 AM
    biebs96
    PA
    ^^ ditto I’m on a 2.5 front lift and I have 35s as well.
  6. Apr 16, 2021 at 5:02 PM
    Dullrich22
    Thanks everyone for the feedback so soon! I like the looks of a 12.5 wide 35, probably a toyo A/T. Is there any chance anyone has run them on factory wheels with a 3” lift? I don’t mind going to a 4.5” with an aftermarket Upper control arm if that will clear and not rub.
  7. Apr 16, 2021 at 5:08 PM
    SwampThing
    SwampThing New Member
  8. Apr 16, 2021 at 5:08 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    I got a 3” up front and 1” in thx rear. Running 35’s with plenty of room..not sure on stock but I have +25 offset and 6” bs. No rub. With 3” everyone will recommend UCA’s too. Over that amount you have too.
  9. Apr 17, 2021 at 8:44 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    This is 35x12.5 tires on a 2" level. No BMC needed
  10. Apr 17, 2021 at 8:52 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    6-inch Rough Country lift with 20x9 XD Rockstar IIs and -12 offset. 35/12.50 Nitto Trail Grapplers. Very happy. DA891A16-39FC-4D30-9944-473A294F1583.jpg
  11. Apr 18, 2021 at 5:37 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Go 6 or wish you did. -11 offset
    TravisJr likes this.
  12. Apr 18, 2021 at 5:44 AM
    Loose
    Loose New Member
    2020 Platnium
    20210218_174142.jpg 20210218_181056.jpg 295/60/20 (34x11.6) on 3 inch lift in the front and 1 inch add a leaf in the rear. Wheels at +20 offset. No CMC needed and no rub
