Lift kit?
Discussion in 'Suspension' started by conroe2012tundra, Mar 16, 2021.
  1. Mar 16, 2021 at 7:37 PM
    conroe2012tundra
    conroe2012tundra [OP] New Member
    KB
    2017 Tundra Platinum crewmax, black
    TRD exhaust
    Looking to lift my ‘17 4x4 crewmax, 3-4”. Any recommendations as to brand?
  2. Mar 16, 2021 at 7:42 PM
    Engineer4038
    Engineer4038 New Member
    2017 Tundra SR5 CM 4x4
    Toytec 3” Lift
    Are you wanting a coilover lift or spacer lift? Most people here prefer coilovers to spacers (I have 3” Toytec spacers but they came installed when I bought the truck) but it just depends on your budget and needs.
  3. Mar 16, 2021 at 8:18 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    How much do you want to spend? You can go anywhere from $200 to $5000.
    Coilovers are the ideal solution and range from around $850 and up, and up, and up.
    Eibach, Toytec, King, Fox, Falcon, Icon, OME, are the common ones, but there are others out there.
    You'll see a lot of Icons and Kings around here, and folks seem to really like them.
  4. Mar 17, 2021 at 2:18 AM
    conroe2012tundra
    KB
    TRD exhaust
    I’m looking to spend around $1400
    I’d like to do coil over. I imagine you end up with better handling etc.
    What are the cons of going the spacer route?
  5. Mar 17, 2021 at 5:20 AM
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    I would consider Eibach coilovers stage 2 lift.
  6. Mar 17, 2021 at 6:10 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    In the 1500 range you have some good coil over options from Toytec- their aluma series and also Eibach, then there is Dobinsons, OME.
  7. Mar 17, 2021 at 6:33 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome and my suggestion is to read threads after threads on said topic in the suspension section of the forum... Good luck
    Badknees likes this.
  8. Mar 17, 2021 at 4:27 PM
    conroe2012tundra
    KB
    TRD exhaust
    What are thoughts on this particular kit?
    Toytech/Eibach 2.5” lift
  9. Mar 17, 2021 at 11:12 PM
    OnespeedTRD
    Don
    San Diego
  10. Mar 17, 2021 at 11:18 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  11. Mar 18, 2021 at 5:25 AM
    conroe2012tundra
    KB
    TRD exhaust
    Thanks.
    New to lifting trucks. So could I use 1” lift blocks for the rear? I hear if you use shackles you have to modify the TRD dual exhaust.
  12. Mar 18, 2021 at 6:11 AM
    conroe2012tundra
    KB
    TRD exhaust
    Just ordered! Now just need some rear shackles, and to ditch these 20” wheels and go with some 18’s and decent rubber.
  13. Mar 18, 2021 at 6:43 AM
    conroe2012tundra
    KB
    TRD exhaust
    Would you recommend add-a-leaf in addition to the shackles? I’m eyeballing the various options on the Toytec site.
  14. Mar 18, 2021 at 8:36 AM
    Pineapplehead
    Pineapplehead New Member
    Philip
    New Meadows, Idaho
    2010 Super White Tundra DC
    Take a look at the Icon Vehicle Dynamics rear expansion pack. Deaver also makes something similar. Good luck!
    conroe2012tundra[OP] likes this.
  15. Mar 18, 2021 at 8:37 AM
    alb1k
    Left Coast
    It's good
    Ill leave that one to the rear lift crowd. Good luck, show pics when you get there.
  16. Mar 19, 2021 at 12:10 PM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I added 1.5" shackles and don't have any issues with my TRD dual exhaust under "normal" driving. However, I don't off-road much and the shackles might make the leafs contact the exhaust pipe at extreme articulation...not sure.
  17. Mar 29, 2021 at 9:58 PM
    Zed
    Zed New Member
    Houston Texas
    2017 Brown 1794 Tundra
    what are you opinions are with:
    Front Diff. Drop Kit
    Toytec Progressive 3 Leaf Add A Leaf Pack with U-Bolts
    SPC Adjustable Upper Control Arms
    and how does that compare to the fox 2.5?
  18. Mar 29, 2021 at 10:05 PM
    jessenavarro
    jessenavarro New Member
    Jesse
    Oak Glen, CA
    2018 White Tundra TRD Off-Road 4x4
    Front Fox 2.5 Coil-over shock with adjustable reservoir -- DSC Rear Fox 2.5 shock with adjustable reservoir -- DSC Total Chaos Fabrication UCA -- tubular Method Race Wheels MR701 18x9 + 25mm -- Matte Black BFG KO2s - 35x12.5x18 Demello Sliders RetraxPro XR bed cover Yakima Roof Rack setup Baja Designs S8 40" light bars x2 (amber and white LED) Baja Designs Squadron Pro ditch lights Baja Designs Squadron Sport fog lights Switch Pros SP-9100 Midland MXT400 GMRS radio
    i was once in this boat. I went w something inexpensive. Worked ok, but ultimately upgraded to fox coilover. You really do get what you pay for. My two cents
  19. Mar 29, 2021 at 10:43 PM
    Zed
    Zed New Member
    Houston Texas
    Fox are backorder for 8-10 weeks :/
    been looking for 2.5 everywhere
  20. Mar 30, 2021 at 5:50 AM
    jessenavarro
    Jesse
    Oak Glen, CA
    ebay... I got 2.5s with DSC very easy. You can put alerts and it’ll tell you when they are in stock. You’ll have to jump on it as soon as you get that email. There are a few websites that offer the “alert me when in stock” option.
    Also try https://www.headstrongoffroad.com/s...or_Extended_Travel_-_2007__Toyota_Tundra.html
    I got some parts from them.
