Lift my "lowered" 2015 TRD Pro
Discussion in '2.5 Gen Tundras (2014-2021)' started by TRD_femi, Jun 22, 2023.
  1. Jun 22, 2023 at 3:43 PM
    TRD_femi
    TRD_femi [OP] New Member
    2015 TRD Pro
    Please HELP!!
    What other companies (like a Camburg) make complete kits for lifting this truck?
    This isn't my area of expertise!
  2. Jun 22, 2023 at 8:13 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  3. Jun 22, 2023 at 9:17 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I guess we need to know how you’re lowered first. If that’s your truck in your avatar she’s definitely low low.
  4. Jun 25, 2023 at 5:37 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    This thread makes me wonder who in their right mind would buy a Pro and lower it.
    itsallgood101, Zoso and Skaufma0 like this.
  5. Jun 25, 2023 at 6:19 PM
    blenton
    blenton New Member
    :notsure: :rasta: :tinfoilhat: :crazy: :homer: :facepalm::notsure:
    Zoso and texasrho83 like this.
  6. Jun 26, 2023 at 2:11 PM
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    I was thinking the same thing, could certainly have some chopping done.
  7. Jun 28, 2023 at 11:36 AM
    TRD_femi
    2015 TRD Pro
    Front: DJM arms, shortened knuckle & custom coilovers w ADS struts
    Rear: Tundra Racing custom shackle kit & custom ADS shock
    Now, I need to raise the truck.
    What solutions (like Camburg) are available?
  8. Jun 28, 2023 at 11:47 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Just put oe stuff back on…
    HulkSmurf14 likes this.
  9. Jun 28, 2023 at 12:12 PM
    2mchfun
    I'd say it all depends on how you intend to use the truck. I have some factory like new suspension parts in my garage in OKC. Let me know if you want to negotiate. Just beware they aren't PRO parts. Good luck!
  10. Jun 28, 2023 at 12:23 PM
    TRD_femi
    2015 TRD Pro
    Can't put on parts you don't have....
  11. Jun 28, 2023 at 2:07 PM
    blenton
    blenton New Member
    The only suspension parts that are Pro-specific are the shocks and sway bars. Knuckles, shackles, control arms, etc are the same for all trim levels (except 2wd vs 4wd, which should have some obvious differences). As as been suggested above, your best bet is to find some factory takeoffs and then you are left with choosing which aftermarket shock/coilover you want. As far as I know, there aren’t many if any OE spec aftermarket parts like that from the likes of I on, King, etc. I think they make some gusseted or beefed up spindles designed for long travel but not for OE spec stuff. OE stuff would be the best for that.
  12. Jun 28, 2023 at 3:05 PM
    memario1214
    Colton
    Missoula, MT
    Alright this helps. So now, how much lift are you trying to get over what the stock height of the truck would be?
    RobertD likes this.
  13. Jun 28, 2023 at 6:35 PM
    TRD_femi
    2015 TRD Pro
    2-4" should be enough, what would you recommend?
  14. Jun 28, 2023 at 6:50 PM
    2-4” taller than now? Or taller than stock
  15. Jun 28, 2023 at 6:55 PM
  16. Jun 28, 2023 at 6:59 PM
    TRD_femi
    2015 TRD Pro
    Stock.
  17. Jun 28, 2023 at 7:00 PM
    And you haven’t googled 4” lifts for Tundras?
    yakeng and des2mtn like this.
  18. Jun 28, 2023 at 7:03 PM
  19. Jun 29, 2023 at 4:39 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I love some easy entertainment first thing in the morning. :pccoffee:
  20. Jun 29, 2023 at 10:14 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I’d find a reputable offroad shop in your area and just tell them you want a 2-4” lift.
    No disrespect, but these questions are easily answered with basic searches. If you can’t do that, you’ll probably struggle with the lift.
    itsallgood101 likes this.
  21. Jun 29, 2023 at 12:25 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You need to buy some oe lower control arms and spindles if you dont have them. This is easy
  22. Jul 9, 2023 at 4:20 PM
    MountainMan
    MountainMan New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
  23. Oct 13, 2023 at 7:20 PM
    TRD_femi
    2015 TRD Pro
    Now I need a ladder to climb into the truck!
  24. Oct 13, 2023 at 7:22 PM
    pics or it didn’t happen!
  25. Oct 13, 2023 at 11:51 PM
    TRD_femi
    2015 TRD Pro
  26. Oct 16, 2023 at 8:10 AM
    SD Surfer
    Bruce
    So Cal
    Much better
    TRD_femi[OP] likes this.
  27. Oct 16, 2023 at 9:56 AM
    Trdripper
    Trdripper New Member
    Bronze 2nd Gen
    King 3.0 front Coilovers with TC UCA King 3.0 rear Bypass shocks
    Nice fender flares!
