Light bulb for 2019 SR5 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by RFG1022, Jan 6, 2020.
  1. Jan 6, 2020 at 5:51 AM
    RFG1022
    RFG1022 [OP] New Member
    2019 Toyota Tundra SR5
    I need to replace my light bulb on my 2019 toyota tundra is there any other way then disassembling your whole front end to get to a light bulb? Why did toyota design something like this? Please help!! Thank you!
  2. Jan 6, 2020 at 6:15 AM
    RFG1022
    Wow so your screwed if a bulb goes out or you want to put LEDS in. Either way!!
  3. Jan 6, 2020 at 6:24 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    It's really not that hard. It took me a few minutes to remove the grill, corner plastic and headlight. I did scratch on of the corner piece during reinstallation.
    While you're at it, might as well change the fig lights. I did have to do it twice in the span of two days. One of my led was upside down.
  4. Jan 6, 2020 at 6:39 AM
    RFG1022
    I'm just wondering if it's worth all this for leds. Taking a chance of scratching things and breaking tabs etc. All for a different light bulb?
  5. Jan 6, 2020 at 8:08 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Do you mean the headlight assembly or just the bulb?
    The individual bulbs come out by themselves, with no disassembly required. Twist and pull. The battery side is cramped but totally doable.
    Am I wrong?
  6. Jan 6, 2020 at 8:15 AM
    SprinterAE86
    Ian
    I have touch up paint and different grit sand paper and buffing compound in my truck. I get chips driving down the highway all the time. I try to do the repair as soon as I notice it.
    The escutcheon on my led is removable to be able to put the dust cover on. I did not know the led have reflectors pointing up and down for hi/lo orientation. I reinstalled one upside down.
  7. Jan 6, 2020 at 8:16 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yup.
  8. Jan 6, 2020 at 8:47 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I thought to even change the headlight bulb you have to disassemble? The only one you can change without disassembly is the turn signal bulb, I believe.
  9. Jan 6, 2020 at 9:28 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    I sure hope no one is putting LED bulbs in a halogen reflector housing. Just get the higher output halogens if you need brighter lights. Coming from a Subaru with factory LED headlights, I'm impressed with the output from my stock SR5 halogens.
  10. Jan 6, 2020 at 9:37 AM
    SprinterAE86
    Ian
    You'll be surprised how much better having LED's over halogen. Subaru's I owned did not have any good headlight. But they were the older models.
  11. Jan 6, 2020 at 9:41 AM
    BecauseRacecar
    Ohio
    My point is only that if your truck has a halogen reflector housing (as opposed to a halogen projector like in the Tacomas/4runners) and you simply swap the halogen bulbs out for LED, what you'll get is a brighter light scatter for yourself, and subsequently blind everyone else on the road.
    Lots of discourse (and good pics!) over in Tacoma world about this sort of thing: https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
  12. Jan 6, 2020 at 9:49 AM
    SprinterAE86
    Ian
    Yes, that is true. I might be blinding people already without even knowing it. I do see allot of other vehicles that does that. Especially the F series.
    I need to do a test and see before I upgrade my headlights.
  13. Jan 6, 2020 at 10:25 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Buy the right LEDs and you wont have a problem. After installing turn them on against a wall and make sure you have a sharp cut off line with no scattered light. You should have a good hot spot. The leds should look exactly like the halogens you removed. If not, remove them and send them back. I'm using Sylvania H4 Zero LED and they look exactly like the halogens except the color.
    SprinterAE86 likes this.
  14. Jan 6, 2020 at 12:22 PM
    RFG1022
    That's what I was doing. You say it's not worth it and leave the stock bulbs in there? What can you put leds in the stock housing?
  15. Jan 6, 2020 at 12:31 PM
    RFG1022
    Can you put leds bulbs in a stock Halogen reflector housing?
  16. Jan 6, 2020 at 12:42 PM
    RFG1022
    These are the ones I bought for my truck any opinions? See attached.
  17. Jan 6, 2020 at 12:45 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    They go in just like a regular bulb.
  18. Jan 6, 2020 at 1:04 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
  19. Jan 6, 2020 at 1:14 PM
    SprinterAE86
    Ian
    Yes
  20. Jan 6, 2020 at 1:36 PM
    sundance
    sundance New Member
    I thought the 2019s came with LED headlights?
  21. Jan 6, 2020 at 2:01 PM
    Ronin73
    Ronin73 New Member
    Not the SR5, it only has LED DLR lights.
  22. Jan 6, 2020 at 2:02 PM
    sundance
    sundance New Member
    Thanks! I used Beamtech in my 2014. Loved them. Not too bright but the cutoff was a little high.
  23. Jan 6, 2020 at 3:57 PM
    RFG1022
    I'm mechanically inclined, but it scares the shit outta me having a 50,000 dollar vehicle and taking about the whole front end just to get to a damn light bulb...
  24. Jan 6, 2020 at 4:00 PM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    On my 2020, the SR5 package incl LED headlights
  25. Jan 6, 2020 at 4:20 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    It’s easy. If I can do it anyone can.
  26. Jan 6, 2020 at 4:39 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I changed my bulbs with some HR supernova LED bulbs on my 17 Pro. At the time I didn’t have the money for 18 LED OEM lights. The light scatter not bad and the out put is so much better. And no I am not blinding people. I never get flashed unless my BD squadron sports are on. Then I get flashed. At some point I will do the full swap. Yes I had to pull the whole front end off. Not bad but still a pain in the ass. A54A98FC-59A3-4EB6-BBE2-F5BABA859645.jpg
    Baja Designs Squadron Sports. Mega bright no need for high beams
    Iahcon, omgboost and NewImprovedRon like this.
  27. Jan 6, 2020 at 4:43 PM
    RFG1022
    Well I will give it a shot this Sat,
    4Runner[QUOTED] likes this.
  28. Jan 6, 2020 at 5:52 PM
    Bigbird57
    Bigbird57 New Member
    Auxbeam on Amazon. Just be sure the logos face each other. No cooling fan= no noise 15783616132957644798412494426030.jpg
  29. Jan 6, 2020 at 6:15 PM
    RFG1022
    I was going to do those but heard alot bad reviews on them
  30. Jan 6, 2020 at 6:19 PM
    RFG1022
    Anyone see the tips of these bulbs how do you know what's to or bottom there's like a little tip on the top of these bulbs
