Light swirl marks from hand washing
Discussion in 'Detailing' started by Robster80, Feb 10, 2022.
  1. Feb 10, 2022 at 3:52 AM
    Robster80
    Robster80 [OP] New Member
    Been handwashing my 21 since i bought it last year with no swirl marks. My last wash apparently something went wrong i now have quite a bit of light swirls here and there especially on the sides of the doors. Should i let a detail place/expert handle this or are there products i can easily use myself even if i dont have a polisher/buffer whatever u call it?
  2. Feb 10, 2022 at 4:02 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Depends on the level of perfection you want. I personally got Ceramic coating with paint correction done by a professional. Was it cheap? The difference is night and day. I was told to use a foam cannon, have dedicated sponges for body and wheels separate and exchange water often. Its worth the 2 K in my opinion.
    Here a good guy to follow. He shows how to do it yourself and he has another video where he talks of the experience after washing his truck.https://youtu.be/qxcymSqnqco
  3. Feb 10, 2022 at 5:00 AM
    Steelyhead
    Steelyhead 2016 Tundra TRD
    America
    16 Tundra TRD/03 Limited TRD
    Lots of beer breaks
  4. Feb 10, 2022 at 5:20 AM
    thumper_racer
    thumper_racer Not a New Member
    TN
    2012 MGM Rock Warrior
    If you are hand washing, use the 2 bucket method with some grit guards in the bottoms. If your truck is really dirty, do a pre-wash so the bigger stuff comes off. Lots of suds = lubrication; don't exert a lot of pressure on the washing mitt/sponge/whatever you are using to wash with.
    Cg13055 likes this.
  5. Feb 10, 2022 at 5:24 AM
    ronrich
    ronrich New Member
    What color paint do you have? With darker colors, swirl marks are almost evitable. That's is why I will not have a black or darker vehicles anymore, they show all the imperfections in the paint. There are many products out there that claim they "reduce the appearance of" scratches and/or swirls, etc. The best results I've found (recommended to me by a professional detailer/body shop) is Meguiar's. They have many products and different abrasive grade cleaners and polishes. Larger grit equals more aggressive. Basically your putting more "scratches" into the paint/clearcoat but just finer to a polished glass-like finish which give the appearance of a highly reflective surface. Here is one of their products I've personally had great results with removing scratches. https://www.meguiarsdirect.com/meguiars-m2-mirror-glaze-fine-cut-cleaner-16oz.html. But like anything abrasive you need to be careful with it. It has a fine dissolving grit that works into a emulsion. After that you would apply their standard polish and/or wax sealant. Other things to consider is the cloth you are using to clean you car. Never use cotton rags or old tee-shirts as they are generally bad and will scratch the clearcoat. Use a high quality fresh/clean microfiber cloth. Also you must ensure a good soapy wash when cleaning your car to remove all the dirt and road grime, otherwise you wind up rubbing that into the paint hence the swirls. Hope this helps!
  6. Feb 10, 2022 at 6:37 AM
    Robster80
    yea mines magnetic gray metallic i love it but everytime i look at it i notice a new small hairline scratch or swirl, rock chip somewhere.
  7. Feb 10, 2022 at 6:49 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Using 2 bucket wash, clay bar, Megs Pro polish and/or megs ultimate polish, and megs ultimate liquid wax removed 99% of my swirls. Its a ton of work but satisfying when complete. That took a solid 5 hours! I think the glassiest my truck looked is when I used Megs NXT 2 wax.
  8. Feb 10, 2022 at 7:47 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    I've given up! :(
  9. Feb 10, 2022 at 10:15 AM
    Robster80
    o wow. I watched the vid. Something i definitely wanna try and do myself. So the polishing should get the swirl marks out?
  10. Feb 10, 2022 at 4:21 PM
    Mobeyk
    Mobeyk New Member
    certainly. The shop I had my truck at did same steps. wash, decontaminate, clay bar, 2 step paint correction, 2 layers of ceramic coating. 3 guys for 9 hours
  11. Feb 13, 2022 at 7:17 PM
    briarpatch
    briarpatch New Member
    The sad truth about these trucks is that they have very soft clear coat. The bad news is that they scratch/swirl easily.....the good news is that they correct easily. Correction by hand is possible, but difficult. With todays DA polishers, pad choices and product choices, you can tackle this yourself, if you are reasonably mechanically inclined. Chances are, the swirls could be handled with a light to medium polish, and you'll not have to go as aggressive as a compound. There are also a number of coatings on the market that DIY'ers can do with outstanding results.
    If you are sheepish about attempting it yourself, take it to a local, reputable detailer and get an estimate. Most shops offer a variety of packages to choose from, so you can probably find something that fits your budget. Be prepared, however.....proper paint correction and a professionally applied coating can be pretty expensive.
  12. Feb 13, 2022 at 8:24 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Well, stop doing the Mr Miyagi wax on wax off method....NEVER wash in circles...NEVER NEVER NEVER!
    ALWAYS wash in straight lines, washing in a circular motion only emphasizes the fact you have used a dirty rag contaminated with fine grit to produce swirls...
    I have been washing my daily driver, my Kia Niro since 2018, I do not have swirls.I use a VERY clean wash mitt, , and a foam gun. Always wash in sections, and always constantly clean the mitt with clean rinse water after completing each section.
    NO SWIRLS HERE!!
    But, if they are light swirls, wash and strip old wax off the car, use a clay bar and a clay bar lubricant, and a clean rinse. Dry it, I have a warm air cannon that blows all the water off, and get yourself a random orbital buffer. Use a good rubbing compound and gently remove those swirls. Be careful not to burn the clear coat and paint!
    I use Car Guys washing materials, and have to say, all my vehicles look terrific.
    If necessary, visit YouTube, watch a few videos, and get into the proper habits of wash & wax!
