Lighter fuse location?
Discussion in '1st Gen Tundras (2000-2006)' started by markshoreline, Nov 18, 2018.
  1. Nov 18, 2018 at 11:35 AM
    markshoreline
    markshoreline [OP] New Member
    Mark
    Whidbey Island, WA
    2006 Tundra TRD 75k miles
    Front trailer hitch, tonneau cover
    I went to inflate my tires by plugging a portable air compressor into the power outlets on the right side of the console, but lost power. Anyone know where the fuse is???
    Thanks!
  2. Nov 18, 2018 at 12:34 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    In the panel in the drivers side of the dash. Should be a 15A labelled “PWR OUTLET”. The 15A “CIG” fuse for the cigarette lighter socket is in there too.
  3. Nov 18, 2018 at 1:25 PM
    Professional Hand Model
    Hand Protectors
    How many amps does your compressor draw?
  4. Nov 18, 2018 at 1:29 PM
    markshoreline
    Mark
    Whidbey Island, WA
    Thanks, is that panel under the dash, L of the steering wheel? I’ll check when I get home.
    It is a small compressor- I plugged it into my Prius to see if the problem is the truck or compressor and it worked fine. D/k the amp draw.
  5. Nov 18, 2018 at 1:34 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That would be the one.
  6. Nov 18, 2018 at 1:35 PM
    Hand Protectors
    Should be on the placard of the compressor.
  7. Nov 18, 2018 at 7:51 PM
    markshoreline
    Mark
    Whidbey Island, WA
    Not on the compressor or product manual is the amp draw states...however, not knowing what the fuse codes mean I pulled every fuse under the dash and they were all intact. However, when I started the truck and tested the power outlet there was power and it works fine now. Maybe moving the fuses did the trick?
    landphil likes this.
  8. Nov 18, 2018 at 8:05 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I've had a similar thing with my '08 - also with a 12v compressor (Viair 85P), a key cycle brought power back to the power outlets. The outlets do stay on for a couple hours after turning the ignition off in both of our trucks (at least my friend's '06 does), so I'm assuming the body controller is part of the circuit and may just be shutting off the circuit when it senses an overload.
  9. Nov 18, 2018 at 8:08 PM
    markshoreline
    Mark
    Whidbey Island, WA
    Thanks for the help. I did find a blown tail light fuse (I think) under the hood that I will replace tomorrow.
