Lightweight wheels?
Discussion in 'Wheels & Tires' started by 70m4h4wk, Apr 20, 2024.
  1. Apr 20, 2024 at 10:49 PM
    70m4h4wk
    70m4h4wk [OP] New Member
    Paris of the Praries
    23 Silverado LT, CCSB, 2.7L Turbo
    2/2 Drop, Ram Daytona Spoiler
    I'm looking for some lightweight wheels to pair with some tall skinny highway tires for long hauls.
    I don't have the cash for TE37s or Lightspeed racing wheels.
    So far the best deal I've found is on FN Konig Countersteers. About $1000 for 20lb wheels.
    Anyone know of lighter wheels around the same price point, or cheaper wheels at the same weight?
    These will be going on my Silverado, but it just so happens that 3rd gen Tundra wheels will fit. The GMC forums haven't been any help.
    AggiePhil likes this.
  2. Apr 20, 2024 at 11:08 PM
    PROTERRA
    PROTERRA @201.PRO
    Sal
    So Cal
    2024 Tundra TRD PRO
    have you checked out SCS wheels??
  3. Apr 21, 2024 at 11:54 AM
    70m4h4wk
    I have. The f5 is a couple pounds heavier than the FNs
    PROTERRA likes this.
  4. Apr 22, 2024 at 11:54 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    For a couple pounds, I think you’re better off saving weight in the tires. Find light weight highway tread tires in the lightest load capacity you can get away with. I wouldn’t go taller than stock, as you’ll lose more MPG to the added weight and mechanical disadvantage of the fall tires than you’ll gain with lower rpm.
    Unless you just want new wheels, you’ll need to rack up millions of miles before the savings related to lighter wheels maths out in the fuel economy realm.
    Small light tires and drive like an old lady. Haul as little weight as you can.
  5. Apr 22, 2024 at 1:09 PM
    70m4h4wk
    If I get the FN wheels and new highway tires I can save something like 33lbs per corner. My stock wheels are 41lbs. Looking at highway tires, if I go down to a 235/70R17 I can save another 10lbs. I can't find any highway tires lighter than 30 lbs though.
    AggiePhil and PROTERRA like this.
  6. Apr 24, 2024 at 8:37 AM
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    You'll be happy with FN wheels. I have a different version of their wheels on my 2016 Tundra. The quality is great and their customer service is top notch too. Just make sure since these are going on your Chevy that the hub size and back spacing will work for you. Even if the bolt pattern is the same, there are other variables to consider.
    70m4h4wk[OP] likes this.
