Limited vs Platinum Hybrid Gauge Cluster
Discussion in '3rd Gen Tundras (2022+)' started by Spakylpm, Sep 25, 2022.
  1. Sep 25, 2022 at 7:48 AM
    Spakylpm
    Spakylpm [OP] New Member
    2024 Tundra
    Can someone explain the difference between the Limited and Platinum Hybrid gauge cluster? I see under the compare the Platinum has the 12.3-in. digital meter with selectable gauge display screen, so what does the Limited come standard with? Is the Limited Hybrid not a digital screen? Or is it just smaller?
  2. Sep 25, 2022 at 7:55 AM
    Boats N TRDs
    Boats N TRDs New Member
    Travis
    2022 Tundra Limited HV TRD OR
    Chrome delete
    The limited comes standard with the analog guages, but the 12.3" digital display is an option.
    My understanding is that all hybrids come with the 12.3" digital gauges (that is the only way to display the iForce Max meter). Mine is a limited hybrid with the digital gauges.
    Here are the 2 options for gauges:
    Analog gauges:
    Digital gauges:
    FYI: my build sheet did not specify that it had the digital instrument cluster. Sales guy said it would have it, but I wasn't able to confirm it until I went to pick up the truck.
    DJyrjn and Spakylpm[OP] like this.
  3. Sep 25, 2022 at 7:58 AM
    Spakylpm
    2024 Tundra
    That makes sense but in the comparison (build), it does not show it as standard or an option 12.4 for Limited. Thanks appreciate it
  4. Sep 25, 2022 at 7:59 AM
    Boats N TRDs
    Travis
    Chrome delete
    I edited my original comment to address this. My build sheet did not indicate that it came with digital gauges, but it did show up that way.
  5. Sep 25, 2022 at 8:05 AM
    Spakylpm
    2024 Tundra
    Thank you sir!
  6. Sep 25, 2022 at 9:01 AM
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    The analog gauges are standard in the SR, SR5, and non-hybrid Limited. There is NO option in those trims for the 12.3” screen. All hybrid models (regardless of trim) come with the 12.3” screen, so that’s the only way to get it in a Limited. I believe it is optional with non-hybrid drivetrains in the 1794 and Platinum, and it’s standard in the Capstone and TRD Pro by default because those only have the hybrid drivetrain
    Spakylpm[OP] likes this.
  7. Sep 25, 2022 at 9:04 AM
    Spakylpm
    2024 Tundra
    Make sense thanks
  8. Sep 25, 2022 at 11:12 AM
    Kagisexton
    Kagisexton New Member
    Christopher
    2022 Tundra Platinum
    Sounds correct but I believe with the platinum, 1794 and up, it is standard and not an option.
    chaztizer likes this.
  9. Sep 25, 2022 at 3:44 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    My Limited hybrid has digital cluster.
  10. Sep 27, 2024 at 6:53 PM
    Pattington22
    Pattington22 New Member
    ‘24 Limited Nightshade (Silver)
    I know this is an old thread, but I just picked up my 2024 Limited Nightshade non-hybrid, and it has the fully digital cluster. I am confused - the Canadian spec sheet doesn’t even note it as an option.
  11. Sep 27, 2024 at 7:34 PM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    I believe in 2024 all limited models regardless of motor choice got the digital gauge cluster.
