Line-x Remove deck rail system or not
Discussion in '2.5 Gen Tundras (2014-2021)' started by spyshot, Oct 10, 2019.
  1. Oct 10, 2019 at 6:53 AM
    spyshot
    spyshot [OP] 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    I’m getting line-X liner sprayed in next week. Should I remove the deck rail system myself? Or will the Line-x plug the holes and make it more difficult to install? I don’t like the idea of them taping around the rails.
  2. Oct 10, 2019 at 7:27 AM
    OV-1794
    OV-1794 New Member
    My line-x dealer removed the rails, bed bolts, and tie downs without me asking. They did an amazing job in my opinion. Mine was scheduled and dropped off through my dealer though or I would've asked. Just check with them.
    Tchase and BravoDeltaRomeo like this.
  3. Oct 10, 2019 at 7:52 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I removed the rails, they plugged the holes during their prep. Forgot to remove the corner tie downs, they left them in and sprayed them too.
  4. Oct 10, 2019 at 7:56 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    My dealer installed mine, Same as above removed the rails but didn't remove the bed bolts and tie downs which were subsequently sprayed.
    If you ever need to remove a bolt after its been sprayed its a bit of a PITA.
  5. Oct 10, 2019 at 8:10 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Most dealers will remove the rail system if its installed and you can always ask them about it. If its already removed you could plug the holes yourself so they can see it
    or have that specific discussion and hope they dont spray over the holes anyways.
    I had the conversation with my installer because my bed rail system was on order (thanks @Roman) but they sprayed over the holes anyways. I had an appointment for them for fix it, but I ended up
    taping the holes myself and it all worked out.
  6. Oct 10, 2019 at 8:11 AM
    ToyotaTroy03
    ToyotaTroy03 New Member
    2019 MGM Platinum Tundra
    I had my bed rails removed, and holes plugged.
    My corner tie downs are sprayed over.
    I would definatley have the bed rails removed.
    Line X did an awesome job.
    Hope that helps.
    I can send pictures this evening.
    BravoDeltaRomeo likes this.
  7. Oct 10, 2019 at 8:22 AM
    spyshot
    Ohio
    Thanks for info. The reason I am posting is because the receptionist said “oh I’m not sure, they may tape over them or if they have to they will remove them.”
    I’m going to call back and get some straight answers.
    Thanks Adam
  8. Oct 10, 2019 at 8:25 AM
    purplenova
    Tom
    Ohio
    Please - whatever you do, speak to the installer that will be spraying your truck, not the receptionist. This way that person knows what you want done.
    Better yet - go there today if possible and have a face to face with the installer......
    TheBeast likes this.
  9. Oct 10, 2019 at 8:41 AM
    15whtrd
    15whtrd Mr. Blonde
    My dealer removed the tiedown cleats. At the time I didn’t have the rail system. The holes were easily cleaned out prior to installing my bed rail system. I think it’s best if you just remove it yourself so there will be no problems with them installing it wrong or stripping threads. I also had them remove the bed bolts but they didn’t torque them properly and. 62 ft lbs The liner doesn’t really stick to a surface unless they prep it first. Maybe you could put just a little grease on a bolt and spin it in to the threads. That will keep the spray from sticking. Mine peeled right out with a little pick.
  10. Oct 10, 2019 at 8:45 AM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    I took my truck to the Line-x dealer and they removed the deck rails and taped the tie downs for me. One thing I didn’t like was them inadvertently slapping their Line-x logo into the bed. Peeled that off and that area of the lines looks like shit.
  11. Oct 10, 2019 at 8:57 AM
    15whtrd
    15whtrd Mr. Blonde
    You have to tell them you don’t want it. They asked me and I said yes.
  12. Oct 10, 2019 at 9:17 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    What? They sprayed around it?
    I'll have to check mine. I asked for no stickers or branding on the roll down window and they stuck the LINE-X and the truck shop sticker on it anyway. I removed them immediately.
    Time to check my Line-X sticker on the truck bed portion to see if comes off easily. I just left it, but now I'll confirm it's not sprayed around or something crazy or stained.
    my pic from a different thread
  13. Oct 10, 2019 at 9:19 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I was really irritated about this and I had to pull out a couple of the bolts and it jacked it all up.
  14. Oct 10, 2019 at 9:31 AM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    Yep, lesson learned. I'll tell those guys next time I bring my next Tundra in after this one stops running.
    I meant they put that sticker on right after they finished spraying. So the Line-x didn't have time to fully cure. After peeling the sticker off, you can see the sticker smashed and indented into the line-x. Aside from that, I'm very happy of my line-x.
  15. Oct 10, 2019 at 9:41 AM
    spyshot
    Ohio
    Good suggestions!
