Load Range E Tires...
Discussion in 'Wheels & Tires' started by Tundyfundy, Mar 2, 2022.
  1. Mar 2, 2022 at 9:51 PM
    Tundyfundy
    Tundyfundy [OP] Petunia The Tundra, and her sidekick Colbie
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Hey Yall,
    My current tires are the BFG KO2, 275 70 r18 Load Range E.
    Honestly, I feel like the 10 ply (I know its not a true 10 ply) is overkill. I really hate the decreased ride comfort and hit my gas mileage took. They seem really heavy. I tow a pretty heavy travel trailer like twice a year, and I don't do any crazy off-roading. Mostly fire roads and stuff like that.
    My question is, do they make all terrains in a lower load range that would improve my ride? maybe give back some of my pep off the line? I thought I would get the load range E for towing but after thinking about it, the stock tires that came on my 2016 DC were passenger tires I believe. They did just fine while towing. I was thinking load range C would be the sweet spot but I just do not know enough about it. Hoping to gain some insight so any would be helpful. Thanks in advance.
    r1-superstar likes this.
  2. Mar 2, 2022 at 9:56 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    There are plenty of off road tires that are not E rated.
    TheBeast, 14burrito and r1-superstar like this.
  3. Mar 3, 2022 at 3:32 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    I’m in the same boat. But I’ve only got 25K miles on them and it was $1100 for the set so I’m just gonna ride them out as it were and next set won’t be LT load range E tires
  4. Mar 3, 2022 at 5:50 AM
    Sunnier
    Sunny
    San Diego, CA
    If I may suggest a temporary solution for the time before you wear these out and get different tires: it’s maybe time to use those tires to do more serious off-roading. :cool:
    ** Just wanted to say ‘hi!’, and I hope you’re all well!
  5. Mar 3, 2022 at 5:54 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    EXACTLY the same here. Although I really like the look AND performance of my Wildpeak AT3s, my next set will not be E rated tires.
    Doxiedad[QUOTED] likes this.
  6. Mar 3, 2022 at 6:11 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I only see General Grapper APT in an SL rating for 275/70 R18 on Discount Tire's website - all others are E rating. If you stay with an E rating, I would look for a lighter tire if nothing else - Toyo Open Country AT III and Cooper Discoverer XLT AT3 are some of the lighter choices that get good reviews here. If you aren't fixed on that size, I agree load range C is a good compromise or even an SL rated tire might be OK (but I think the side walls are too thin for almost any type of off-roading). I run Cooper Discoverer XLT AT3 295/70 R18 and they've been great so far, but my next set will likely be Toyo Open Country ATIIIs based on the research I've done. Best.
  7. Mar 3, 2022 at 6:16 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I just put Cooper XLT's on 20" rims, so it may not translate perfectly to your wheel and tire setup. They get good reviews for their off road and towing chops, which I haven't tested yet; but they're extremely nice on road. They're as well behaved as the stock Michellin AT's that came on the truck, and for now at least they're a little quieter (less than 1k on the Coopers vs. 24k on the outgoing Michellin's). I had the truck levelled and put these slightly heavier tires on all in the same week, so the differences in acceleration and ride comfort all got mashed together; but the current ride is at least as comfortable as before the change.
    good luck,
    Badknees likes this.
  8. Mar 3, 2022 at 6:19 AM
    CTundraForMe
    CTundraForMe New Member
    I'm using LT275/65 R18 Wrangler Kevlar load range E. Smaller tires than you I think?
    I love them, can go anywhere, the ride is incredibly smooth at speeds I won't post, plenty of get up and go, even with about 400lbs of armor on my truck. Avg 15.7 mpg.
    Maybe the issue is the larger tire?
    WVI likes this.
  9. Mar 3, 2022 at 6:56 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Aren't your tires F rated 12 ply?
  10. Mar 3, 2022 at 7:10 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Nope...looks like Falkens website is off. Your tires are E.
  11. Mar 3, 2022 at 7:14 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Wrangler kevlar load range C for me. I tow a 5th wheel once in a while and like the added sidewall strength. Very affordable as well.
    WFD473 likes this.
  12. Mar 3, 2022 at 7:23 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    im going to disagree here. There are almost no oversized 18 inch tires that are not e rated. OP runs 275/70/18, which is nearly 100% e rated.
    @Tundyfundy - we have fairly similar uses of the truck as we have chatted about in the past. My experience after running 2 sets of bfg ko, toyo at, now currently on stock michelin P rated. My travel trailer is 4k lbs, i carry 4-500 lbs in the bed when towing. The P rated stock tires handle this just fine at 50psi. However E rated was more solid feeling.
    I have run 5-6 sets of bfg at tires over the last 2 decades. They ride like total garbage once they are 2 years old. I don’t know what it is, but they suck as they age, their wet traction declines. Michelins do not do this, toyo at after 3 years still rode the exact same as new.
    my next set if tires will be E rated michelins. Going from e rated to p rated tires had zero affect on mileage or acceleration. The weight alone meant nothing
    Sunnier likes this.
  13. Mar 3, 2022 at 7:24 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    We love our Yokohama Geolander ATS.
    Cooper tires were pretty ok as well.
    Darkness likes this.
  14. Mar 3, 2022 at 7:42 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  15. Mar 3, 2022 at 12:21 PM
    r1-superstar
    DB
    UTAH
    That is correct; E rated.
  16. Mar 3, 2022 at 12:41 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I love my Yokos too but my last set were D rated (years ago) and my mpg took a swift kick in the nuts when I got E rated ones. I was surprised because they don't weigh much more, less than 5lbs difference if I recall. Not a big deal since it isn't my daily but if it were I'd be looking for something else.
    14burrito[QUOTED] likes this.
  17. Mar 3, 2022 at 2:02 PM
    alb1k
    Left Coast
    It's good
    I stand corrected. My 33's were never E rated, but different wheel size and stuff. Thanks
    Hbjeff[QUOTED] likes this.
  18. Mar 3, 2022 at 2:20 PM
    poop_bubbles
    poop_bubbles New Member
    285 75 18 here
    They don’t exist outside of E, which is unfortunate. I think it’s because they are tall thin pancakes.
  19. Mar 3, 2022 at 4:13 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    They recently came out with General Grabber ATX that are standard load rating in 275/70r18. They are also pretty easy on the eyes.
  20. Mar 3, 2022 at 5:59 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    As noted there are very very few non E rated 275/70/18 AT tires.
    If memory serves correct your only options in a tire that you would actually want to buy is the General Grabber AT/X and Goodyear Duratrac comes in a D but doubt it would be much different than E loads.
    I find the 33” tire to be just right on these and most trucks either at factory height or leveled.
    This is part of what keeps me in the 20” wheel world. The 275/60/20 is essentially the same size as the 275/70/18 but lots of options that are not E load.
    I am only a mild off-roader so my 275/60/20s will handle anything I am going to throw at it.
    Hbjeff likes this.
  21. Mar 3, 2022 at 6:40 PM
    platslvrblt19
    platslvrblt19 New Member
    San Antonio, TX
    ‘19 Silver Platinum Tundra
    I’m experiencing the same also - Wildpeaks have been great, but waiting for them to wear and get a set of C or D.
  22. Mar 7, 2022 at 12:25 PM
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    How much of a change in your speedometer, if any, running the 60 vs 55?
  23. Mar 7, 2022 at 12:42 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Just ordered Toyo AT3 in 275/65/18 SL through discount tire
    Tire rack has the Toyo's
    C rated at 2535 lbs weigh 50 lbs
    SL rated at 2756 lbs weigh 41 lbs
    E rated at 3415 lbs weigh 51 lbs
    Was really considering Duratracs in SL 45 lbs as well as Cooper AT3 42 lbs
    I have had Duratracs on the FJ and they are great. Very good in snow and ice when newish. Only complaint is they could hum a bit on the freeway.
    I was looking for a slightly lighter, quieter all terrain tire.
    Tundyfundy[OP] likes this.
  24. Mar 9, 2022 at 6:08 AM
    Black
    Very minimal. Not a thing to even bother with.
    Mostly below 50 mph driving for me.
    So speedo says 50mph I am actually doing 51.7.
    If I am on the highway and my Speedo reads 80 I am doing 82.8
    I set the cruise just shy of 80 on the interstate.
