Looking for a replacement bed
Discussion in '2nd Gen Tundras (2007-2013)' started by spensane, Feb 20, 2019.
  1. Feb 20, 2019 at 8:01 AM
    spensane
    spensane [OP] New Member
    Jeremy
    2008 CrewMax Tundra
    Hello all,
    Has anyone replaced there bed on their Tundra? I have a 2008 CrewMax and my bed is starting to rust. I’m looking for a replacement bed but can’t seem to find one. Any help would be awesome.
  2. Feb 20, 2019 at 8:05 AM
    Mnorris1206
    08 tundra
    In right their with ya .And toyota wants almost 7k for an 8' bed
  3. Feb 20, 2019 at 6:12 PM
    2O1OTundra
    2O1OTundra New Member
    Jerry
    2010 Tundra CrewMax
    Have you tried looking on http://www.car-part.com/ to see if anything is decent? You can sort by distance to try and find something close to you.
  4. Feb 21, 2019 at 2:27 PM
    spensane
    Jeremy
    2008 CrewMax Tundra
    Thanks, I'll check it out.
  5. Feb 22, 2019 at 4:29 AM
    Dr_Al
    Dr_Al New Member
    Al
    Have you talked to a good body shop? I'm betting for a lot less than $7k they can replace both sides and fix any rust issues.
    Mnorris1206 likes this.
  6. Feb 22, 2019 at 4:34 AM
    Mnorris1206
    08 tundra
    I got quoted 400 to fix my bed rust but thats a buddy discount .All 4 corners are rusting inside of mine.
  7. Feb 22, 2019 at 7:40 AM
    spensane
    Jeremy
    2008 CrewMax Tundra
    Mine is doing almost the exact same thing. I'll get a picture up here later.
  8. Feb 22, 2019 at 10:49 AM
    Dr_Al
    Dr_Al New Member
    Al
    The last time I changed a side bed panel you got the whole side. The seam is that thin hump right next to the bolt is where the side panel stops. It looks like that rust next to the bolt isn't on the side panel but could easily be repaired. The problem with finding a used bed is either you are going to have to go for a long drive or you are going to be looking at junkyards with trucks that went through the same winter conditions as yours. Would you want to spend $1000 on a bed that might look the same as yours in a couple years?
    Around me there's three types of body shops. The dealerships (enough said), the body shops that do a large volume and charge a premium, and the smaller guys who don't have the latest and greatest stuff but do good work for a reasonable price. If it was me I would try to find option #3 (sounds like the $400 might be one) and spend $600 or so on a set of fiberglass bedsides. Repair the rust as needed and make sure it's rustproofed well (maybe have a spray in liner done to both the top and underside) then put new fiberglass sides on. Seams like that would last the lifetime of the truck. It may not be the cheapest option but I would be looking more for doing it once and forgetting about it.
    spensane[OP] likes this.
  9. Feb 22, 2019 at 11:35 AM
    spensane
    Jeremy
    2008 CrewMax Tundra
    Thanks for the advice, I'll call some of my local shops.
  10. Feb 22, 2019 at 11:42 AM
    TheBeast The Beach
    someone here did some repairs to his bed i.e cut and weld small pieces then he had it line -X..looks great once done.
    Rex Kramer likes this.
  11. Feb 22, 2019 at 12:16 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    My box is in worse shape than that,and I have decided that unless my bed falls off in the middle of the road, I'll fix it when I get around to it as I have another project that is in need of my time and resources right now. So the truck will have to wait. This truck has been the most bothersome vehicle I have owned in the last 30 years, it seems there is always something going on with it! That being said, my interest in it is begining to slip.
  12. Feb 22, 2019 at 12:22 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    I just put a bed mat over mine. One day it'll fall off and that'll be fun, but until then I ain't doin shit.
    PhotoNerd, Half Assed and robie56 like this.
  13. Feb 22, 2019 at 12:25 PM
    n2deep
    n2deep Pavement Princess
    Look on Copart.com and maybe buy a wrecked truck to swap the bed and then scrap the leftovers. Been looking for a be myself but nothing close to me yet.
  14. Jul 12, 2019 at 9:50 PM
    Mrbullets
    Mrbullets New Member
    Hope I'm not too late on this, but that rust is from a seal underneath that was missed during build. I had the same problem on my 07 and in the end the dealer replaced my whole bed even though my truck was outside the 7 year warranty. I this affects mostly 07 and 08 models. The dealership at first was trying to say it was my fault and I hauled salt, but I told him wouldn't the whole bed be rusty not just the spots behind the wheel wells...then he said we have an excecutive coming by in a week can you bring your truck back when he is here so he can look at it....after a week I get a call run over and they throw it on a lift and 30 minutes later they come back and tell me they are fixing it at no cost to me. The dealership wasn't real happy about it but excecutive said it was a missing seal during build and they would cover it....I saw the invoice after wards and 7k is spot on plus 1k in labor to paint.
    bleach likes this.
  15. Jul 12, 2019 at 9:55 PM
    Mrbullets
    The dealership is Pappas Toyota in saint peters Missouri. I know of 3 others besides mine that got the bed replacement and all were 07 to 08 and Toyota covered it.
    NewImprovedRon likes this.
  16. Jul 13, 2019 at 4:56 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The inside of the bed on my '07 was pretty rough, but the underside was fine. I cleaned it up, and sprayed it with Line-X - that was 2 years ago.
    BlackSheep and NewImprovedRon like this.
  17. Jul 13, 2019 at 8:35 AM
    Mrbullets
    Yeah it looks like yours was a different problem. Mine had rust spot start behind both wheel wells and I thought it was just some surface rust so I cleaned it up and put some touch up paint on it. But it kept bubbling through because it was rusting from underneath. I took it in the the dealership to ask what I could do or what they thought was going on and that's what led to them replacing the whole bed.
  18. Aug 28, 2020 at 8:04 AM
    S2S
    S2S New Member
    What size bed do you need if you still need, im gonna ditch my bed for a 2014-up. My bed is a 08 6,5” bed
  19. Aug 28, 2020 at 9:21 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    We need to know who that exec is and where we can get a hold of him.
  20. Sep 1, 2020 at 7:26 PM
    spensane
    Jeremy
    2008 CrewMax Tundra
    I need a 5’6”. Mine is an ‘08 CrewMax.
  21. Sep 8, 2020 at 7:59 PM
    TurboGoKart
    TurboGoKart New Member
    Any idea what TSB or recall number that is? My 08 is horrible, one corner just popped and I can see the bed jiggling as I drive down the road. Would love to have the dealer fix it.
  22. Sep 9, 2020 at 6:54 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I think the TSB is considered "obsolete" and we're SOL on it.
  23. Jun 8, 2021 at 4:22 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Wow, this is EXACTLY what I need, in the right color, too.
    So I have been to two shops regarding bed rust and some corrosion along the bottom of my tailgate.
    First shop quoted $600 to fix tailgate, and "around" $1,500 for bed rust (definitely one grapefruit sized hole all the way through, potentially more, but drop in liner has not been removed. Bed has only been looked at from underneath.
    Second shop basically said they can fix the tailgate, but the rust would probably just come back in a year or so, since the corrosion is from the inside.And as far as the bed goes, they seemed to think that even with cutting out the rust and welding in new metal, the rust would still come back. Their suggestion was to find a bed from the south, hopefully with a good tailgate, and go that route.
    I have looked at some of the linked websites, and the shop said they could look into sourcing it for me.
    Any thoughts on this?
    And member S2S, any chance you still have this?
    SPP
  24. Apr 6, 2022 at 11:30 AM
    TundraRay
    TundraRay New Member
    2006 Tundra Crew Cab
    Auto Rust Tech in RI works exclusively on bed and frame rust repair.
  25. May 2, 2023 at 8:44 PM
    RustyTundra
    RustyTundra New Member
    White 2011 ExCab 4.6L
    Just bought 2011 Extended cab. Only 63k miles on it. Thought I got a good deal for it until I looked under the bed liner.
    Say hello to a new member to the rusty bed club!
  26. May 3, 2023 at 4:44 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Move down south.. no rust..no troubles ;)
  27. May 3, 2023 at 6:09 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    Facebook marketplace has a couple in my area.
    There is a post for a black 07-13 crew cab bed in Mt. Holly, NC for $850.
    Taylor Mayberry is the person who has it listed.
    It has a dent on the driver's side towards the front.
  28. May 4, 2023 at 6:51 AM
    RustyTundra
  29. Sep 7, 2023 at 8:04 AM
    Rayja
    Rayja New Member
    Rayon
    2008 tundra sr5 double cab 4.7l
    I have a 2008 tundra sr5 double cab 4.7l.. bed liner if anyone interested I'm in Savanah Georgia. And a 2010 5.7L.. shoot me a message rayonw83@gmail.com or message here
  30. Jan 21, 2025 at 12:19 PM
    Tundra family
    Tundra family New Member
    Lots of rust free beds for sale in AZ salvage yards. A couple grand gets 1 sent to ya.
