Looking for adapters or wiring schematics to put 2018(3rd gen) seats into a2013 (2nd gen)
Discussion in '2nd Gen Tundras (2007-2013)' started by Jrzsurfer, Jan 17, 2021.
  1. Jan 17, 2021 at 8:09 AM
    Jrzsurfer
    Jrzsurfer [OP] New Member
    The Garden State
    2013 TRD ROCK WARRIOR
    Can anyone help in the install of these in my truck. They are brand new with 8 way adjustments and heat. If I can not install them I'd be willing to part with them if interested. Thx for any help20210116_131601.jpg 20210116_131614.jpg
  2. Jan 17, 2021 at 8:23 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    JRZ are my initials. Lol. What year are these seats?
  3. Jan 17, 2021 at 8:41 AM
    Jrzsurfer
    The Garden State
  4. Jan 17, 2021 at 8:43 AM
    619Tundra
    How much are you asking for?
  5. Jan 17, 2021 at 8:45 AM
    Jrzsurfer
    The Garden State
    I'd rather install them in my truck. I paid 2500 for them so if I can't get them installed then I'd have to be in that range thx
  6. Jan 17, 2021 at 8:47 AM
    619Tundra
    Ouch. There might be another member here that can chime in on this. Good luck with the install.
  7. Jan 17, 2021 at 8:47 AM
    Jrzsurfer
    The Garden State
    I did just post so I'm getting to see if there is someone here that can point me in the right direction
    Mountun Goat and 619Tundra like this.
  8. Jan 17, 2021 at 8:51 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Does your truck have any power seats currently? Nice score, I’ve been wanting to replace my fronts for some time now as the drivers is bagggged out.
  9. Jan 17, 2021 at 8:52 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    @Roman could get you parts numbers for oem harnesses I’m sure
  10. Jan 17, 2021 at 8:53 AM
    Jrzsurfer
    The Garden State
    Yes. Have power. No heat though. Mine are bagged out too lol
    Mountun Goat likes this.
  11. Jan 17, 2021 at 8:55 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Should have a look at you fuse panels and see if the heated seat wiring is in place. That’s where I’d start :)
    Jrzsurfer[OP] likes this.
  12. Jan 17, 2021 at 8:58 AM
    Jrzsurfer
    The Garden State
    Good call. That's a start. Thx
  13. Jan 17, 2021 at 9:13 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Hit the wiring diagrams link in my signature.
    You’re gonna need to look at a LOT of them and compare each circuit and plug.
    The 2021 diagrams will cover the 2018.
    The 2010 diagrams should be close enough to your 2013.
    You’ll need to research:
    Power seat adjustment drivers and passenger)
    SRS/airbag system
    Seat heaters
    Occupant sendors (might be in the seat adjustment)
    good luck!
    Mountun Goat and Jrzsurfer[OP] like this.
  14. Jan 17, 2021 at 10:16 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Being the seat heater on/off switches are in the climate control of a 2014 & up, you'll have to rig your own switches and wiring for them.
    I added seat heater to my 2014 SR5.
    I tapped into the 12volt power plug circut in the console.
    You can figure out which wires do what and just add your own switches..
    Car, Truck and SUV Automotive Carbon Fiber Seat Heaters by Rostra
    Something like one of these for both..
    I used these and mounted them in the console...
    B7D1F766-7EB1-468F-B367-77F5181E343C_zps_1f63529365161f521258f2c138d3ffe29402349d.jpg cqycitt2_zpsyt5qmggk_604bd6fbc1a87a398374321aeb2ae31695b7e782.jpg
    Some 2015 wiring diagrams that might help you..
    [​IMG] [​IMG]
    Heater wires are in this connector under each seat.
    Corresponding to the pins in the diagrams above.
    QY2 on the right seat.
    PZ1 on the left seat.
    [​IMG] [​IMG] [​IMG]
  15. Jan 17, 2021 at 10:20 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    This is how my 2014 power seat is set up.
    Not sure if your 2013 would be much different..
    There should be 3 connectors in your truck under the seat:
    yellow air bag connector
    P7 small white connector, seat belt warning and seat position air bag sensor
    PZ1 a larger white connector.
    If you're missing the PZ1, you could just find a constant 12 volt and ground to power the seat.
    From what I can tell, the PZ1 connector supplies power to the power seat, mirror and telescopic steering wheel memory, seat heaters, and seat climate control.
    The only 2 wires you will need from that plug is the hot and the ground to power the seat for movement.
    If your 2013 connectors don't match up, you could bypass the connecters and use something else, spade crimp on connectors, or whatever multi wire connector you can find.
    The other small white connector P7 has the seat belt switch wiring.
    I just went out to my 2014 with my DMM to confirm the following.
    It is an SR5 with the power driver's seat.
    This is the female PZ1 that should be under the driver's seat from the truck.
    Looking at that plug as pictured above;
    the lime green wire (top left) is constant 12volts, it would connect to a white wire from the seat.
    the white with black stripe (top right) is your ground, it would connect to same white w/ black stripe
  16. Jan 17, 2021 at 10:39 AM
    Jrzsurfer
    The Garden State
    Wow. Super informative. Thx 1lowlife for all the info. I may have to pm you for more info if that's OK. I knew someone here would have a thorough reply thx again
    MTRock, Mountun Goat and 619Tundra like this.
  17. Jan 17, 2021 at 11:33 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I don't know much, but I'll be glad to help you if I can....
    I'd say your biggest challenge would be to figure out the heater wiring, (HIgh, low, seat bottom and seat back) .
    I used Rostra heaters so it was pretty simple..
    I'm sure you can find some toyota switches that would fit into blank dash cut outs if you have any available..
  18. Jan 17, 2021 at 11:51 AM
    Jrzsurfer
    The Garden State
    You know more than me sir... Very much appreciated. TY
    MTRock and Mountun Goat like this.
  19. Jul 22, 2023 at 1:29 PM
    Yotaholic
    Yotaholic Amateur Professional
    Lone Star Republic
    2011 TRD DC 4.6
    I am in the process of trying to hook up the airbag in my 2017 seats to work in my 2011 truck. Am I correct in thinking that the yellow/black airbag wire on the truck goes with blue wire on the seat and then solid yellow on the truck goes with brown on the seat? That's what I'm thinking but don't want to accidentally detonate the bag in my face if I hook it up backwards.
  20. Sep 2, 2023 at 9:11 AM
    DbPanda
    DbPanda New Member
    Bump.
    having same problem at yotaholic
  21. Sep 21, 2023 at 12:04 PM
    Yotaholic
    Lone Star Republic
    2011 TRD DC 4.6
    You ever figure it out? My truck has been at the dealership and I haven't had the chance to look at it in a couple months.
  22. Dec 21, 2024 at 9:42 PM
    ardnut5102
    ardnut5102 New Member
    I used the same two wires to connect my Scheel man seat for cooling and heating. I de-pined and rewired the male connector (White, White black strip) to the scheel wiring only two cables were required from them. My original seats did not come with seat heaters. 2015 tundra
