Looking for ideas (dual battery inside cab)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Luke_Skywalker, May 10, 2022.
  1. May 10, 2022 at 9:48 PM
    Luke_Skywalker
    Luke_Skywalker [OP] New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    Hello folks,
    Like the title of this thread reads, Im looking for ideas for a dual battery system where the AUX is inside of the cab. Ive been thinking of a longer "flat" battery that can maybe fit up behind the seats. To me, this is an ideal location because its centered in the vehicle, which will help with weight distribution. I know i will eventually have a bumper and winch up front and would like to keep weight in the front of the vehicle down to a minimum. Ideally, Id like to be able to have the battery be lithium for the weight savings. I wonder if anyone has done something like this before.
    The goal ultimately is to add 100ah of power to the Tundra for accessories, fridge etc. Additionally, powering the system would be done through some sort of solar (eventually).
    jjjesks75 likes this.
  2. May 10, 2022 at 10:02 PM
    How many passengers do you have on the regular? If you aren't opposed to removing the smaller rear seat there are all kinds of possibilities for platforms and accessories. Some have put fridges in there and the like, and I don't see why you couldn't do a battery plus other goodies there. It also has the advantage of being able to use the seat mounts to secure it all.
  3. May 10, 2022 at 10:27 PM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    Thats a great idea, but wouldnt work for my case. Currently, no passengers, but I got rid of the rear seats in my FJ to build a platform for my dogs and promised myself id keep the interior of my Tundra intact.
    GODZILLA likes this.
  4. May 10, 2022 at 10:39 PM
    The bonus to the small seat and such is that it can all be readily reversed, but I do understand the sentiment.
    Edit: I do understand the sentiment. Damn fingers have a mind of their own.:facepalm:
  5. May 10, 2022 at 11:11 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Just be careful what battery you put in because some will off gas when charging and/or discharging.
  6. May 10, 2022 at 11:17 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Battery in the cab seems like a bad idea. My 2nd battery is in front of the passenger wheel well in my bed. This seemed a good spot to me because it’s out of the way in front of that wheel well, and it’s helping to counter all the weight on the driver’s side of the truck: primary battery, steering column, driver, fuel tank.
    Link to my setup
  7. May 11, 2022 at 7:55 AM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    Great input everyone.
  8. May 11, 2022 at 7:59 AM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    Awesome setup! If i didnt use my truck regularly for work, I would give something like this a go. A big reason for wanting everything to be in the cab is that i dont have to mess with it coming in and out of the vehicle during the different "setups". Definitely drawing some inspirations though.
    Terndrerrr[QUOTED] likes this.
  9. May 11, 2022 at 8:18 AM
    Terndrerrr
    Music City
    6UR-FE
    I hear you. My house battery has been in the way when I haul plywood for a home project. But it only makes it stick out of the bed a few more inches though. I have hauled mulch as well with a tarp covering the entire bed, hanging over the rails, front of the bed, and tailgate. That keeps the battery box from getting funky. Otherwise, I don’t really notice it’s there.
  10. May 11, 2022 at 8:36 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I think some LiFePO4 batteries are narrow enough to fit behind the back seat and you could place several of them in parallel to reach your desired AH.
  11. May 11, 2022 at 9:17 AM
    Wallygator
    NewImprovedRon likes this.
  12. May 11, 2022 at 9:18 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Here's the old mans setup which is located in the bed. As others mentioned not sure I love the idea of it in the cab.
    Wallygator likes this.
  13. May 11, 2022 at 9:26 AM
    BayRunner
    2017 Tundra Platinum
    I wouldn’t suggest a battery inside the cab. I’ve actually seen instances of this where acid gas corroded the inside of the cab over time. Who knows what it did to the driver.
  14. May 11, 2022 at 11:02 AM
    Vizsla
    Vizsla 2 = 2.5
    OP doesn’t want to remove seats so not much help, and not sure what’s required to carry different types of batteries. No room in the bed, so this is what I did to safely carry an AGM battery in cab. Battery is mounted behind the refrigerator on a mount that replaced the rear passenger seat, mount is removable/seat can be reinstalled. Battery hold down/box is securely attached in a sealed battery box, and AGM battery is vented to outside underneath the truck. Always try to park in the shade, mounting solar panels to the truck didn’t seem useful, so installed a plug for solar on the bed side and use portable panels.
    House battery box
    House battery accessory fuse panel
    Starter battery - isolator mounted on side of battery
    Solar charge/accessory power port for house battery
  15. May 11, 2022 at 11:05 AM
    eick
    eick New Member
    If you’re not worried about hitting rocks you can always mount/weld a battery box on the frame under the cab. There’s room and someone here has done it
    Wallygator and Saltyhero13 like this.
  16. May 11, 2022 at 11:05 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    OP that's the one thing you have to consider with the battery inside the cab....heat. Batteries don't like it hot and it's not good to charge them while they are.
    Saltyhero13 likes this.
  17. May 12, 2022 at 8:20 AM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    Again, great info/input from you guys. Certainly giving me ideas. I think what i will ultimately do, is mount a slim battery behind the smaller seat, in its own sealed box. Then I will run some sort of vent tube to the exterior of the truck to avoid any gas venting. Other than trips, the truck sits parked in the garage or in a shaded carport so im not super concerned with heat. Theres nothing ill be able to do to avoid that during trips but ive found that if you try to account for every single scenario when it comes to mods, you'll never be happy so you just gotta send it. This mod is wayyyyy down the list as im still running the OEM battery and have essentially a stock truck but i love to hear peoples ideas way in advance before i start to piece things together.
  18. May 12, 2022 at 10:59 PM
    eick
    eick New Member
    You can fit a small battery in the engine bay up on the passenger side near the cab air inlet/firewall.
    You’ll have to fab up a mount but that’s not too hard
  19. Oct 18, 2022 at 11:12 AM
    TonyNCo
    TonyNCo New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    Hello, good info here. I am in the process of trying to find a good place to mount mine. Just replaced my OEM starting with a AGM, group 27.
    I have the Genesis universal single battery kit. Has a tray/and electronics.
    Wondering about either under seat (worried about leaks/fumes/etc) AGM is sealed though...
    Attached to frame. Trying to locate a heavy duty box to use has not been successful. Thinking about having a friend weld up a custom on to bolt on... I think I would prefer this, but it is also the one that seems to need the most prep/fab work.
    Or in the p/u bed. Reluctant to do that since it sticks out some when tucked into the space by wheel well.
    Also, it just occurred while typing, I still need to mount my truck bed tool box. I could put the 2nd battery in that...
    Those electrical/battery experts... Does the 2nd battery have to match specs? I believe the type of battery has to match or is highly advisable. As in an AGM with another AGM... The Genesis kit is sized for a group 34. The specs are slightly different for a group 27 and group 34.
  20. Oct 18, 2022 at 12:02 PM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    If you are going to mount a tool box, you really should install it in that. Make some space over on the driver side for it to make it easier to run the battery cables for yourself. If you have a buddy who can weld maybe have him build you a bracket of some sort the battery can sit in so you can properly secure it within the box. Consider a way to keep the battery covered so none of your tools bump into it and cause it to be damaged or arc between the posts.
    A second battery does not need to match the size of your first battery, but it is advised to match the type (although you dont have to do this if you have the right type of voltage regulator). If you already have an agm, get another one of those, since they can be cycled pretty low as well. Make sure you use proper cable sizes and remember the further you run the cable the thicker you want it so you lose less current over the length.
    Hope this helps
  21. Oct 18, 2022 at 1:02 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I will be switching to a lithium battery soon because costs are going down, you can use up to 80% of the battery (vs 50% for AGMs), and during that 80% the voltage is constant. With non-lithium batteries the voltage levels will creep down as it is being used.
    Got my eye on this one, which has the same dimensions as my group 31 secondary AGM:
    https://www.amazon.com/dp/B09BR4MYBV/?coliid=I10XFWLBHSD1KI&colid=1DIVQE7G9K3VU
    Terndrerrr likes this.
  22. Oct 18, 2022 at 1:17 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I’d go with SOK. A little bit more but at least you can swap out the cells if one craps out on you but your bms is still good. The amp time and renogies are sealed and you’ll have a hard time getting it put back together once cracked open. Plus they have every feature like heat (for your winter rubicon trips), high cutoff etc etc. I’m debating up switching mine over if there’s a BF sale. Check out will prowse on YouTube. He’s reviewed almost every LifePO4 battery ever made
    Cruzer[QUOTED] likes this.
  23. Oct 18, 2022 at 1:20 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I like that kid, he's funny AF when he just laughs at the cheap stuff. He did a review and the SOK and AT are basically the same thing, same parts, which is why I'm looking at the AT.
    Mater[QUOTED] likes this.
  24. Oct 18, 2022 at 1:21 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Got it! I’ll have to go back and watch that one. Thanks for the tip
    Cruzer likes this.
  25. Oct 18, 2022 at 2:30 PM
    SD Surfer
    Bruce
    So Cal
    I like how excited he gets geeking out on this stuff.
    Some of the guys on the RV forum I'm on have been using the Weize 100Ah Lithium based largely on Will Prowse reviews of it and nobody has anything bad to say about it.
    I'm about to pull the trigger on 2 of them for my trailer. $350/ea on Amazon.
    https://www.amazon.com/dp/B09F2LLMY3
    https://www.youtube.com/watch?v=-c6A1THDaeU&t=14s
  26. Oct 18, 2022 at 8:48 PM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    I may pull the trigger on this for my kayak trolling motor battery.
  27. Oct 18, 2022 at 9:04 PM
    jjjesks75
    jjjesks75 New Member
    jason
    2021 tundra trd sport 4x4
    currently stock
    I had a small xs power battery (almost mower sized) in my 08 as a back up to my system. I had 2 3k amps and a 4 channel. Only other thing was a big 3 done to the truck.
  28. Oct 19, 2022 at 8:00 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Check if it has an IP rating (water/dust resistance) since it’ll be near water - I haven’t been able to find it. That’s a deal breaker for me as my battery is exposed underneath the truck.
  29. Oct 19, 2022 at 8:19 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    This is what I did as I have a Weatherguard chest mounted in the bed of my '07. I have an MTM "Ammo Crate" repurposed as a battery box that holds a 75 Ah AGM and a relay/fuse panel. it's bolted to the chest and bed and has venting. My battery is on the passenger side to help balance out some of the Tundra lean.
    If I was starting 100% over or didn't have a chest, I'd look at a battery box under the bed of the truck. There are some pretty good voids in front of and behind the rear fenders and you can mount to the frame. I'd also be much more comfortable mounting a Li-Ion battery there vs inside the cab.
  30. Oct 19, 2022 at 8:31 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    My first thought, and as many others have stated, is what a bad idea.
    Why not dual battery under the hood where it's less of a hazard and route a protected/enclosed terminal block inside the cab?
