Looking for passenger side bed molle storage system
Discussion in '2.5 Gen Tundras (2014-2021)' started by CanTundra, Mar 7, 2022.
  1. Mar 7, 2022 at 9:17 PM
    CanTundra
    CanTundra [OP] New Member
    2021 Tundra TRD Off Road
    Hi guys looking for a rack that I don’t have to drill into bed etc
    Perhaps something that can fit into factory rails ?
    lightweight use like shovel,axe etc
  2. Mar 8, 2022 at 4:40 AM
    Blue Thunder
    Washington
    I haven’t seen a full panel but I have a set of these. Their only drawback is the panels rattle against the side of the bed because they are not secure at the bottom
  3. Mar 8, 2022 at 5:06 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    Cali Raised LED and Victory also have bed side molle systems. I think both of them mount using the bed rails.
  4. Mar 8, 2022 at 5:10 AM
    MightyTundraGA
    MightyTundraGA New Member
  5. Mar 8, 2022 at 6:15 AM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    Putco makes some as well, but they are really expensive.
  6. Mar 8, 2022 at 6:32 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    check the marketplace, there is a member selling a victory panel. I am pretty sure you have to drill for all of them unless you have the bed rails. I have the cali raised and had to drill 1 hole for the side panel but the front of bed one did not require drilling.
  7. Mar 8, 2022 at 5:46 PM
    CanTundra
    From what I found the Rago are short panels and need drilling.
    Victory are cool but drilling needed.I wish they made use of the tie down locations
    Cali are bolt in from what I see. Does any one know if you lose the front tie down ? I see in video the rear is re used
    ps I have undercover armour flex bed cover that also needs rail system to mount.
  8. Mar 8, 2022 at 7:52 PM
    MadMaxCanon
    I have cali raised and you do not lose the front tie down.
    Caliraisedled likes this.
  9. Mar 12, 2022 at 8:36 AM
    CanTundra
    I watched their video and there was no drilling. Can I trouble you for picture of where you drilled and the tie downs?
  10. Mar 12, 2022 at 8:47 AM
    MadMaxCanon
    My wife took the truck for some errands today but I had to drill because one of the existing holes that the panel uses was being used as a drain for my tonneau cover so I drilled a hole slightly higher and used it as the new drain hole so technically I guess it doesn't require drilling. Also I do have their bed stiffeners as well.
  11. Mar 12, 2022 at 11:40 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    I know your looking for passenger side storage, but maybe consider the front panel that Victory 4x4 offers?
    I am in the process of installing the front Molle panel. Requires no drilling if you don’t have a plastic bed liner. I have a Bed Rug installed, so I have to make some minor modifications to it in order to make it work. Just need to make two slits in the rug for the bed mount brackets to slide through and it’s all done!
  12. Mar 12, 2022 at 12:12 PM
    CanTundra
    no rush send me pics of the tie downs when u can thanks so much
  13. Mar 12, 2022 at 12:15 PM
    CanTundra
    thats a nice one I saw that and I like how it has more of a traditional molle with drilled holes more options to mount. but I always thought the side is better since you have that dead space over the wheel wheel hump. What do you think?
  14. Mar 12, 2022 at 1:22 PM
    RustyShackle323
    Stewart
    NC
    I think it comes down to personal preference. Agree about the dead space, but for a rack like that, you are pretty much left with drilling holes and I wasn’t real excited to drill holes in my truck. So the front panel suites my needs for what I intend to use it for.
    Plan to put traction boards, high lift Jack, small shovel, and possibly first aid kit. Will need to play around with the arrangement to get it to fit. But I believe I can make something work.
