Loud engine knock while idling- 2020 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by trucksareforgirls2, Feb 8, 2021.
  1. Feb 8, 2021 at 5:38 AM
    trucksareforgirls2
    trucksareforgirls2 [OP] New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Hi all,
    I noticed a couple days ago that my engine has started knocking loud when the truck is idling at a traffic stop etc. I did have the first oil change last week I think, or the week before, so I am not sure if they screwed something up?
    Could it be bad gas? I use octane 87 and have since I bought it.
    Thanks,
    -T
  2. Feb 8, 2021 at 5:57 AM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    Check the oil first. If it’s ok, and knocking is loud, take it back to the stealership.
    It could be something serious, and that knocking is causing more damage as you run it.
    Drain the cheapo gas, or next fill up, try a tank of Sunoco 93 octane. That’s what is usually in mine.
  3. Feb 8, 2021 at 6:00 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Probably a case of bad gas? if its still under warranty take it in and have it checked out... highly doubt its knocking, but just like @a522467 stated a tank of premium, or seafoam can help out some...
  4. Feb 8, 2021 at 6:00 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Have you checked the oil level?
  5. Feb 8, 2021 at 6:09 AM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    Have you checked the oil level on the dipstick? Sometimes dealers screw up.
  6. Feb 8, 2021 at 6:40 AM
    trucksareforgirls2
    Northeast USA
    No, I have not checked oil level. Is it best to do that after it has been running for a while or after it has been sitting?
    -T
  7. Feb 8, 2021 at 6:41 AM
    trucksareforgirls2
    Northeast USA
    It's more like a loud ticking noise at idle.
  8. Feb 8, 2021 at 6:44 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Engine off for minimum of five minutes. Hot or cold engine doesn't matter.
  9. Feb 8, 2021 at 6:58 AM
    Vizsla
    Vizsla 2 = 2.5
    From owners manual
    TTund16 and Tierhog like this.
  10. Feb 8, 2021 at 7:16 AM
    trucksareforgirls2
    Northeast USA
    LOL, now you post that...
    I had my work husband check the oil and it's fine. I turned the engine on and idled it and no noise, so it seems to be more when the engine warms up. I will see if it does it tomorrow when I am heading home or doing errands.
    -T
  11. Feb 9, 2021 at 2:12 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    If it sounds like this then it's most likely the timing chain tensioner. This is my son's truck and the sound is inconsistent. He has taken it to the dealership multiple times and they can never reproduce the sound. I talked with him yesterday and he said that it has not done it in months. Fortunately he has an extended warranty.
    https://www.youtube.com/watch?v=afkA1qmNt9w
  12. Feb 9, 2021 at 4:12 AM
    Pine Tree State
    Pine Tree State New Member
    2021 SR5 TRD Sport CM
    This is very nearly the same sound that my truck was making yesterday for a short period while I was waiting in a drive thru line.
  13. Feb 9, 2021 at 4:26 AM
    jewild
    jewild New Member
    2019 Tundra Limited
    3/1 level" Real lift, 20" fuel wheels on 31"tires
    These trucks are designed to run on regular gas. If you want to pay for the high octane that's your call.
    Adding seafoam is useless also in my opinion, but i'm not getting into that battle.
    If your on your first tank, I'd say everything isn't even grown together as of yet.
    I would mention it at your free checkup, but i believe they'll tell you it's normal.
  14. Feb 9, 2021 at 5:17 AM
    blanchard7684
    blanchard7684 New Member
    you aren't going to get pre-ignition at idle. It likely isn't gasoline related.
    The 5.7 is a naturally noisy engine. Shockingly noisy. The 4.0 is also louder than some diesels...
    If this happened right after the first oil change I would check the following.
    1. Engine top cover and insulators. Make sure whoever changed the oil somehow didn't remove the insulator material under the top cover of engine. The amount of insulator material in the 5.7 is a really good indicator Toyota knows these engines are loud AF.
    2. Check the oil change invoice for proper oil weight, type, and volume.
    3. Observe oil pressure gauge...if it falls to the low mark you've got big problems.
    4. Check in engine bay and undercarriage for a dropped wrench, tool, etc that might be causing the noise.
    5. Check to see if the skid plate is loose in the case they took it all the way off to change the oil and didn't tighten it.
  15. Feb 9, 2021 at 5:24 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    If the noise continues after doing all that has been suggested, you can temporarily remove the serpentine belt to eliminate fan & pulley noise. This may help you narrow down the source of the noise... don't forget to put the belt back on.
  16. Feb 9, 2021 at 5:29 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    My 2018 is damn silent. Barely ticks. So, I can't see all 5.7 are loud.
    Waffletractor and Clemsonman14 like this.
  17. Feb 9, 2021 at 8:58 AM
    yel911
    yel911 New Member
    NH
    2018 Crew Limited
  18. Feb 9, 2021 at 9:26 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    If your 5.7 is quiet, there's probably something wrong with it! :laugh::rofl:
    TTund16 likes this.
