Loud Pop (Spring settle sound) when pulling into and out of driveway.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Onthomp94, Jul 21, 2020.
  1. Jul 21, 2020 at 4:32 AM
    Onthomp94
    Onthomp94 [OP] New Member
    Oliver
    2018 Tundra Cement
    I have a 2018 tundra with 14000 miles on it. Got it about a month ago. It came with 2.5 inch level blocks which I thought could be the issue I am hearing but I just replaced them with 5100s all around and it is still happening. It happens sometimes when pulling in and out of the driveway. But I have heard it at other random times. It sounds like the coil popping. It happened yesterday when I pulled into the driveway slightly to quickly. And then again when pulling out. It also happened when I was pulling into work this morning. I pulled up a little to far and my tire bumped the parking chock, and it made the noise when I reversed it back a few inches. I don’t want to do anything that could damage it more if this is a serious problem. It is under warranty still but I have a feeling that the dealership could never recreate the sound to be able to diagnose it. Any thoughts or experiences with something like this?
  2. Jul 21, 2020 at 4:45 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Do you have a TRD skid plate? It’s a beige color with a little door on the front?
  3. Jul 21, 2020 at 4:49 AM
    timsp8
    NY
    Take a picture of your suspension. I know you said it was before you got 5100s, but are you sure the cup that hold the spring is right side up? Some have accidentally put it on backwards.
  4. Jul 21, 2020 at 5:01 AM
    Tundyfundy
    Bay Area, CA
    He said it was like that before the new suspension but always a possibility I guess.
    timsp8[QUOTED] likes this.
  5. Jul 21, 2020 at 6:03 AM
    timsp8
    NY
    Yeah I said he said it was doing it before, but maybe taking a picture will identify something not installed correctly or help narrow it down.
    Tundyfundy, Tundra234 and Geo4x4 like this.
  6. Jul 21, 2020 at 6:28 AM
    I'm wondering if the tire is hitting the corner of the skid plate. OP, what size are your tires/wheels?
    Tundyfundy likes this.
  7. Jul 21, 2020 at 11:31 AM
    Onthomp94
    Oliver
    2018 Tundra Cement
    I am running the stock 275/55R20. Will be upgrading to a 285/65 or 60 soon.
  8. Jul 21, 2020 at 11:48 AM
    Onthomp94
    Oliver
    2018 Tundra Cement
    here are some shots of the side that is making the noise.
    E3C8D752-4AD8-4B29-AD49-4C60A83A7F05.jpg BAC7D185-4EEC-4E18-A3EA-35F0B5EFEDBA.jpg 554FBB2A-C313-436B-B0DE-7FEDD4D5D3C9.jpg 9C3E91E4-B912-46D3-AD88-95D5C10A7EA0.jpg 40E47050-70A9-44DC-9E69-FBD8BCC7C414.jpg EF1257CB-0619-4382-9E9E-9FB2D536160D.jpg 4B665E3C-46F8-4040-9FF2-86E642337D0B.jpg
  9. Jul 21, 2020 at 11:50 AM
    Onthomp94
    Oliver
    2018 Tundra Cement
    After looking at those photos could my lack of bump stop extenders plus the 5100s at top setting have anything to do with it?
  10. Jul 21, 2020 at 1:25 PM
    timsp8
    NY
    I don’t think that would make a pop. I had a pop in my old truck, but I had aftermarket control arms and it was the upper ball joint. Everything on yours looks ok, but I can’t tell about your cv axle angle. Do you have a diff drop kit?
  11. Jul 21, 2020 at 1:49 PM
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    Hell, all I have to do is walk past my 2020 Turd Pro and something pops. No idea what it is. Does on crank also and randomly while just sitting there with no one touching it.
  12. Jul 21, 2020 at 2:28 PM
    K9scout
    K9scout New Member
    2019 Tundra Trd Pro
    My 19 does the same thing. I can’t figure it out.
  13. Jul 21, 2020 at 2:30 PM
    chingyeunglo
    chingyeunglo New Member
    Mine too.
