Low battery in key fob
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2-4-5 trioxin, Dec 3, 2023.
  1. Dec 3, 2023 at 10:51 AM
    2-4-5 trioxin
    2-4-5 trioxin [OP] New Member
    2020 Tundra Limited
    I’m assuming there is an issue with the Toyota app. I got a message in the app saying the key fob battery was low. I replaced the 2032 battery in both and I’m still getting the message for the low battery.
    21ProWeb likes this.
  2. Dec 6, 2023 at 6:53 PM
    2-4-5 trioxin
    2020 Tundra Limited
    Has anyone else had a problem with the key fob?
  3. Dec 6, 2023 at 9:05 PM
    Dukhnt
    Dukhnt New Member
    I had a message on my dash this morning that the battery level in the fob was low.
    Grabbed the other one from the house, and message went away.
  4. Dec 7, 2023 at 9:53 AM
    seydou
    seydou Distinguished Member
    Have you tried force closing the app and/or clearing the cache?
  5. Jan 14, 2024 at 7:07 AM
    rodbucks
    rodbucks New Member
    jeff
    Campbell
    2019 Tundra Limited Cement
    Fox 2.5, Rago Front Skid, BD Pro Ditch Lights, Diamondback HD, TRD Exhaust, TRD Rear Sway
    Three times now I have an issues with my key fob, twice is the last 3 weeks. My problem is nothing works, no power to anything. No alarm, no windows, nothing happens when trying to start it. Last night I had to disconnect the battery for 5 minutes then reconnect it and then everything was fine. Batteries are fine in both fobs, not sure what is going on.
  6. Jan 14, 2024 at 7:50 PM
    Savmikey47
    Savmikey47 New Member
    Try a different brand of battery. Duracell doesn’t work. I had to switch to energizer or Panasonic
    EarlyRiser likes this.
  7. Jan 23, 2024 at 10:54 AM
    21ProWeb
    21ProWeb New Member
    Mason, Ohio
    2021 MGM Toyota Tundra TRD Pro
    YESSSSS!!!! Very frustrating! Same issue with app.
  8. Jan 23, 2024 at 11:24 AM
    21ProWeb
    21ProWeb New Member
    Mason, Ohio
    Did this ever get resolved or go away?
  9. Feb 3, 2024 at 4:21 AM
    Rat Fink
    Rat Fink New Member
    Alabama
    25 Silver 1794
    Yup, same message in app. Replaced original battery and it went away. Month later it's back on. Replaced battery and still there. Tested month old battery that came out and still has full voltage. Everthing still works so gonna wait for truck to tell me it's low or just change it annually. Finally caught up on the list of recalls, thought the red alerts were gone but noooo, got me a key fob alert now.
  10. Feb 3, 2024 at 6:15 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Voltage can be fine but not enough current on the battery. Had this issue with a garage sensor.
    Retired...finally likes this.
  11. Feb 3, 2024 at 5:46 PM
    21ProWeb
    21ProWeb New Member
    Mason, Ohio
    Update: The message went away. I called Toyota and complained and they put me in touch with the dept in charge of app. They said it’s a known issue with app and they were working to fix it. Apparently they did.
  12. Mar 11, 2024 at 5:18 AM
    Eurodriver
    Eurodriver New Member
    I am having an issue with the dash saying key fob battery low, replace battery - not the app.
    Has anyone had that problem? The truck is only 2 years old so I don't understand how the battery died so quickly.
  13. Mar 11, 2024 at 8:34 AM
    seydou
    LOL Who knows how old the cheap POS chinese battery was that the fob came with. Did you replace it? Did it solve the problem? How long do you expect batteries to last? News flash, your oem starter battery will likely die before three years.
  14. Mar 11, 2024 at 9:06 AM
    Eurodriver
    Uhhh FYI the battery in my key fob was made in indonesia, not China so its way more better.
    But not I haven't replaced it yet. :muscleflexing:
  15. Mar 11, 2024 at 9:14 AM
    seydou
    In that case, yes, I have had that same problem. In fact, everyone with a dead/weak fob battery has had the exact same problem.
    You know what solved it? No, posting on the internet won't help. Instead try installing a new battery. That seems to work in most cases where batteries need to be replaced. ;)
    HulkSmurf14 likes this.
  16. Mar 11, 2024 at 10:59 AM
    Eurodriver
    Posting on the internet is what we do in this forum though. Nobody with a 3rd Gen knows how to do anything without going to a dealer for warranty work so we just complain.
    HOLY BALLS IM IN THE 2.5 GEN FORUM. How did I get here?!?!?
  17. Mar 13, 2024 at 11:32 AM
    2-4-5 trioxin
    2020 Tundra Limited
    I changed the battery a few times in my key fobs and it still had the low battery warning on the app. About a month later it went away on its own. I’m guessing it was a problem with the Toyota app.
  18. Mar 14, 2024 at 5:44 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Dealership sent me a coupon for free batteries in 2 FOBs. I figured at 7 years it was time to replace. Took FOBs to parts department and dude looks at coupon and reads fine print like he has never seen one.
  19. Dec 16, 2024 at 10:55 AM
    Double DC
    Double DC New Member
    2005 DC & 2021 DC
    So I got the "key fob battery low" message on the dash. Went to page 452 of the manual for instructions on replacing the key fob battery. Looks like a simple process in the manual - similar to other key fob batteries I've replaced before. But when I remove the cover, the battery is not visible. There is no mention in the manual that one needs to remove the circuit board to replace the battery, but I'm guessing the battery is on the other side of the circuit board. Am I missing something?
  20. Dec 17, 2024 at 8:46 AM
    seydou
    LOL Did you end up flipping it over, discovering the battery?
  21. Dec 17, 2024 at 9:26 AM
    Double DC
    2005 DC & 2021 DC
    No, I have not removed the circuit board. It appears there are 4 very small plastic clips holding the circuit board in place. With my luck, I'd snap off at least one or two of them, and f--- up the key fob. Since the manual makes no mention of removing the circuit board, I am holding off for the moment. Will let someone at the dealer show me the process if no one here has dealt with this yet. 2nd key fob is working just fine in the meantime.
  22. Dec 17, 2024 at 9:38 AM
    seydou
    Fear not, you can remove the board without affecting the clips. It is meant to be done. 2032 is the battery type IIRC. And I would swap out both batteries at the same time.
    Double DC likes this.
  23. Dec 18, 2024 at 5:25 AM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
  24. Dec 18, 2024 at 5:51 AM
    Double DC
    2005 DC & 2021 DC
    Yes, that is easy. Made the mistake initially of thinking I had to pop the board out of the small black clips to access the back side of the circuit board. Thanks!
    ejes likes this.
