Low hum between 45-60mph
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2018SR, Jun 27, 2023.
  1. Jun 27, 2023 at 8:16 AM
    2018SR
    2018SR [OP] New Member
    2018 Tundra SR 4.6L 4x4 90K miles. At speed starting at 45mph there is a deep hum sound that seems to come from the rear of the truck. Nothing terrible sounding, sounds like elevated tire noise. I have had tires recently replaced and alignment done and the noise is still occurring. Suspecting a bad wheel bearing, I jacked up the truck and physically tried to wiggle each wheel to see if there was wheel bearing play. There is none. I asked a dealer to take a look and they said the rear drivers side wheel bearing needs to be replaced. I took to a local shop to have it replaced and they said the wheel bearing was fine. The shop recommended that I take it to a place in town that specializes in rear differentials to see if they can find anything. I haven't brought it there yet. Thought I would ask here if anyone has experienced rear-end humming noise or has any tips on what it might be. Thanks
  2. Jun 29, 2023 at 9:44 AM
    dofu
    dofu New Member
    Dave
    San Jose, CA
    2015 White Tundra Crewmax SR5
    I would suggest you look at the rear tire balance weight first. Some may have fallen off or incorrectly balanced. I put on new tires, got an alignment and had weird road noise at around 45+ mph. They initially gave me a sheet to show proof, but found that they had to rebalance the tire again. Hope this helps!
  3. Jun 29, 2023 at 10:08 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    With the brakes assembled and the other end of the axle in the diff i doubt you're going to feel much by hand in the way of wiggle until it's to the point of sparks flying and air gaps. A lot of the time you can't even feel a bad front bearing either until just before it converts to a 3-wheeler.
    Have a cheap infrared thermometer? Sometimes that can nail down the bad bearing.
    2018SR[OP] likes this.
  4. Jun 29, 2023 at 4:41 PM
    2018SR
    Today I had the wheel bearing in question replaced. Truck rides like new. Noise is gone. Tech used a stethoscope to identify the bad bearing. You are correct, the bearing was bad but had no play in it with the wheel on when I physically tested it.
    Thanks
    dofu likes this.
