Lower ball joint dust covers
Discussion in '1st Gen Tundras (2000-2006)' started by TimH, Nov 12, 2024.
  1. Nov 12, 2024 at 5:38 PM
    TimH
    TimH [OP] New Member
    2003 Tundra SR5
    So, I replaced my LBJs with Toyota brand one. The Toyota brand did not come with the dust boots. Honestly I'd forgotten about them. I live in the northeast winter crud is coming. Seems to me the boots would just hold the crud against the ball joint. Any opinions on this?
    Mr Badwrench likes this.
  2. Nov 12, 2024 at 6:13 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    No they don’t. You have to buy the dust boots separately. For my year 2002 and possibly earlier, they only make one side (two different part numbers but the part is identical). I’m not sure if they fixed that problem yet or not so beware.
  3. Nov 12, 2024 at 7:18 PM
    Usually if I find the new part lacks something that’s on the old part, I transfer it over.
  4. Nov 12, 2024 at 7:44 PM
    Mr Badwrench
    Mr Badwrench New Member
    I think you're right. They don't look too critical honestly. I don't think I have them anymore. Only thing I can guess, they might be rock chip protectors for the ball joints stud threads, only guessing.
  5. Nov 13, 2024 at 1:52 AM
    TimH
    2003 Tundra SR5
    The passenger side LBJ is the one that failed. I had a garage replace that one because it had the be towed. When I replaced both LBJs a couple weeks ago the pass side didn't have the boot. So the garage must have left it off. The drivers did have a boot. I'm pretty sure the moog or TRW LBJ i installed came with boots. The also came with bolts. The Toyota brand did not so I used the old bolts. When I ordered brake lines I ordered new bolts and dust boots for the LBJs. I have to install them.
    G_unit3000 and shifty`[QUOTED] like this.
  6. Nov 13, 2024 at 4:50 AM
    I can nab the OEM part number on the boots and screws if it helps.
    G_unit3000 likes this.
  7. Nov 13, 2024 at 5:53 AM
    TimH
    2003 Tundra SR5
    Thanks, I ordered the boots and bolts when I ordered the brake lines so no need to look up the part numbers.
    Once again, thanks for posting the web page to look up parts. That saved a lot of time
  8. Nov 19, 2024 at 3:53 AM
    TimH
    2003 Tundra SR5
    Just looking over the zlBJ. Are there extra bolt hols in the LBJ to hold the dust covers? I can't tell with the tire on.
  9. Nov 19, 2024 at 4:08 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you have the small ball style then they are held on with the longer bolts through the same holes that hold the joint on. If you have the big ball style then it uses separate bolts. 2003 is the in-between year.
  10. Nov 19, 2024 at 4:40 AM
    TimH
    2003 Tundra SR5
    Thanks
  11. Nov 20, 2024 at 5:51 AM
    SteveT
    SteveT New Member
    LugNutz
    2002 Tundra SR5 Access Cab
    None yet. Just good ole maintenance
    Hey if you guys have it, I wouldn’t mind getting that dust cover part number. The OEM site diagrams don’t get that level of detail. I tore mine off before I realized they didn’t come with the new LBJs.
    thank you!
  12. Nov 20, 2024 at 5:53 AM
    NickB_01TRD
    Nick
    KY
    shifty` likes this.
  13. Nov 20, 2024 at 5:31 PM
    TimH
    2003 Tundra SR5
