Lower Ball Joints - How Often to Replace?
Discussion in '1st Gen Tundras (2000-2006)' started by Bourbon, Oct 9, 2023.
  1. Oct 9, 2023 at 7:13 PM
    Bourbon
    Bourbon [OP] 2006 Tundra DC V8 4WD
    2006 Tundra TRD DC
    I purchased my truck in 2020, and records showed the Lower Ball Joints were placed by the Toyota dealer as part of the recall a 17,000 miles in 2009.
    I am coming up on 115,000 miles (so, 14 years and 100k). Due to the catastrophic method of failure, I am interested to know if I need to replace them (maybe just for peace of mind). Is there any suggestions on when to replace?
  2. Oct 9, 2023 at 7:26 PM
    Yes. Are you familiar with how to do the basic test for ball joints, tie rod ends, and wheel bearings? i.e. jacking up the front wheels and grabbing with both hands at different positions and slap/push-pull left/right-back/forth to check for play? There are specific positions to utilize for this test.
    This should be part of your basic maintenance routine and ideally just take care of it while doing your regular tire rotations, or jack up each front wheel to test at each oil change.
    Of course, also listen for popping sounds in various situations, as those can be a precursor to suspension parts failures.
    Bourbon[OP] likes this.
  3. Oct 9, 2023 at 7:32 PM
    100k is a reasonable replacement Interval for these.
    FirstGenVol and Bourbon[OP] like this.
  4. Oct 11, 2023 at 4:20 PM
    Bourbon
    2006 Tundra TRD DC
    Understood. I perform basic inspections, but I wouldn't say I'm familiar with a standardized process. I'll look for that. Thanks
  5. Oct 11, 2023 at 4:27 PM
    It's for Dodge/RAM, but it hits all the important notes.
    https://www.youtube.com/watch?v=VASdyDnKu-E
    dirtnsmores and abcinv like this.
  6. Oct 11, 2023 at 4:34 PM
    Bourbon
    2006 Tundra TRD DC
  7. Oct 11, 2023 at 4:49 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I would start checking it more regularly around 80k and probably change them at 120k at the latest unless there was a sign one of them was going. Typically, there is a sign.
