Lower ball joints keep snapping
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ttev2424, Sep 11, 2023.
  1. Sep 11, 2023 at 4:35 PM
    Ttev2424
    Ttev2424 [OP] New Member
    2014 crewmax 5.7 SR5
    I have a lifted tundra on 37s. Bought it this way. Have broken three lower ball joints. This last time they only lasted about 2 months. Each time one broke I had replaced all 4. Was wondering if anyone has some knowledge or can point me in the rite direction on how to fix this issue. Was thinking aftermarket control arms and going down to 35s
  2. Sep 11, 2023 at 5:58 PM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    What brand LBJs did you use?
  3. Sep 11, 2023 at 6:00 PM
    Pics of suspension setup
  4. Sep 11, 2023 at 6:20 PM
    Ttev2424
    I had replaced them with oe replacement ball joints. Not the best quality but definitely should have had more than two months on them. Also what parts of suspension?
  5. Sep 11, 2023 at 6:32 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    How tall is your lift?
  6. Sep 11, 2023 at 6:34 PM
    Ttev2424
  7. Sep 11, 2023 at 6:36 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Do you have a bracket lift? Doesn’t seem like it.
  8. Sep 11, 2023 at 6:36 PM
    What the heck is this noise
  9. Sep 11, 2023 at 6:39 PM
    Ttev2424
    That's what the BDS gives you to attach to the bottom of the shock there. For the lift kit. Note I had bought the truck prelifted already, and I'm fairly new to the game
  10. Sep 11, 2023 at 6:42 PM
    Azblue
    The Dirty T ( ^_^)_且
    That would be a fucked up cheap strut/shock extender. Basically a big ass spacer on the bottom of the shock rather than the top, which will throw the geometry all out of whack and break shit, as the OP is finding out.
    Just say no to spacer lifts of any kind.
    reywcms likes this.
  11. Sep 11, 2023 at 6:43 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Hmmm, you can't buy OEM balljoints though, Toyota only sells them as part of the lower control arm, do they not?
    If you're throwing Moog, Duralast or whatnot, that might be part of the issue. I heard some of the ACDelco stuff still made in Japan was good, or Beck/Arnley - but I haven't done mine yet. I'd like to - my front passenger side started oozing recently as well, but was told if there's no play in it, not to worry too much about it just yet, it's not a first gen.
  12. Sep 11, 2023 at 6:43 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Take a picture to the left of the pictures you posted.
  13. Sep 11, 2023 at 6:44 PM
  14. Sep 11, 2023 at 6:46 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You can see end of the drop bracket in his first picture, so I’m leaning toward…
    …Yes! ;)
  15. Sep 11, 2023 at 6:55 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Any pics of the broken BJ’s?
  16. Sep 11, 2023 at 7:02 PM
    Ttev2424
    Wouldn't be able to post broken joints till tomorrow
    landphil likes this.
  17. Sep 11, 2023 at 7:27 PM
    drpheta
    drpheta New Member
    1. Get rid of the lift and get shocks/coilovers that provide a proper lift, and UCAs if going over 3 inches.
    2. Don't buy any LBJs not made in Japan. Toyota doesn't sell LBJs for our trucks outright, so unless you want to get complete LCAs buy Japanese made AC Delco or Beck Arnley or Sankei 555 LBJs.
  18. Sep 11, 2023 at 8:26 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Nothing wrong with the BDS bracket lift.
    Rc23 likes this.
  19. Sep 11, 2023 at 8:35 PM
    Wishbone Runner
    Wishbone Runner Toyota Connoisseur
    2019 Platinum
    And what do you mean by broken? Has play in it, the stud popped out of the joint, the stud broke?
    landphil and Cruzer like this.
  20. Sep 11, 2023 at 8:35 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Ok so you've got a bracket lift, which rules out extreme angles that would cause binding, but somehow it's happening. What is the truck doing when the LBJ breaks? Dipping into a pothole? Going over something big?
    Rc23 and landphil like this.
  21. Sep 12, 2023 at 9:20 AM
    Ttev2424
    When the lower ball joints break, it's when I'm in reverse and start turning the wheel. Coming out of parking spot
  22. Sep 12, 2023 at 9:21 AM
    Ttev2424
    And by broken, I mean the shank completely breaks off, leaving part of the joint in the control arm and the shank and bolt still in knuckle
  23. Sep 12, 2023 at 9:22 AM
    Ttev2424
    Will post pic of broken joint after work
  24. Sep 12, 2023 at 9:50 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Does the passenger side have this piece of metal welded on? It's designed to keep you from overturning.
  25. Sep 12, 2023 at 9:51 AM
    Ttev2424
    Yes, both sides have those aftermarket knuckles. I believe they came with the lift kit
  26. Sep 12, 2023 at 9:54 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    I'm talking about the extra piece of steel that was welded onto the knuckle. It's a stopper that butts up against the LCA to prevent you from turning the steering wheel any further.
    EDIT: The extra piece of steel is welded on during the installation
  27. Sep 12, 2023 at 9:57 AM
    Ttev2424
    This is the passenger side
  28. Sep 12, 2023 at 9:58 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Are those OEM LCAs?
  29. Sep 12, 2023 at 10:00 AM
    Ttev2424
    Honestly not sure, I did not install, I'm leaning towards factory because the lift kit that was put on the truck uses the factory arms I believe
  30. Sep 12, 2023 at 10:00 AM
    MedCityMoto
    Maybe they're not, and that's what's causing them to break?
