Lower ball joints....what bolts?
Discussion in '1st Gen Tundras (2000-2006)' started by Bought2Pull, Aug 9, 2024.
  1. Aug 9, 2024 at 8:55 PM
    Bought2Pull
    Bought2Pull [OP] New Member
    Greg
    WV
    2006 Tundra 4 door
    I have read several times on this discussion forum when replacing the lower ball joints I'll also need new bolts. However, I haven't seen these bolts for sale on the OEM sale pages I've searched.
    Can someone provide a link to those bolts?
    Thanks!
  2. Aug 9, 2024 at 9:34 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    It depends on your year....easist might be to call Orisman or Serra tomorrow and they'll confirm the part number usung the VIN, or can look them up. This is a good read too.
    shifty` likes this.
  3. Aug 9, 2024 at 10:22 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Mine is a 2006 but I was thinking "just ask when I call Orisman."
    Eager to get this project rolling....need to move the truck so I can mow the grass where I have it parked.
  4. Aug 10, 2024 at 12:15 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    • Recall kit set - New OEM Lower Ball Joints - 4006-62134
    • LBJ Bolts - 90105-12316 - 8
    JasonC. likes this.
  5. Aug 10, 2024 at 2:44 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    @Bought2Pull - you need to learn to use the search function. You have multiple posts and multiple questions already answered.
    ATBAV8 and shifty` like this.
  6. Aug 10, 2024 at 6:25 AM
    This ^^
    This sticky thread exists for a reason - a lot of times you can just search for a term in there and get the info you need, but as a new owner, you should read it anyway if you haven't, and reference it if you have.
    Parts lookup info here, @ToyotaDude linked above too, I think.
    But since you have an '06, it'll be the same as mine. If you buy the recall kit, it won't come with cotters or castle nuts. If you just buy the joint (left/right) directly, you get all the extras. Torque to 59lbft, use (at least) blue threadlock. I mark my bolt head position with a marker.
    ToyotaDude and des2mtn like this.
  7. Aug 30, 2024 at 5:32 PM
    Spike77777
    Spike77777 New Member
    2000 Limited Bilstein shocks, mild lift 1" front and 3/4" block rear. 17" Stock wheels from later model Tundra with 275/70/17
    Just call a Toyota parts department, give them your VIN and ask what part number. I just went ahead and ordered them through the dealer. Around $30 for the 8 bolts.
  8. Aug 30, 2024 at 6:05 PM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    FWIW I ordered my LBJ from ourisman 2 weeks ago and the bolts online. They reached out to me via email that I actually ordered the wrong bolts for my vin and offered to swap in the correct ones.
    w666, Bought2Pull[OP] and ToyotaDude like this.
  9. Aug 30, 2024 at 10:30 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Thanks guys. I ordered the bolts from Ourisman Toyota (I spell that right?) called and asked about the parts and bolts after sending an email. Got all the parts the next day.
    jerryallday likes this.
