Lower control arms?
Discussion in '1st Gen Tundras (2000-2006)' started by Daq_daddy, Aug 26, 2019.
  1. Aug 26, 2019 at 6:23 PM
    Daq_daddy
    Daq_daddy [OP] New Member
    2005 SR5 Doublecab
    So it seems I am in the market for new LCAs, This one of those toyota/oem only kinda things? Or are there decent aftermarket options...or something more beefy?
    Also, any other parts I should be looking at replacing while im in there? Got the SPC UCAs on there already. 2005 SR5 DC with 3in toytec boss lift.
    Thinking I will do the lower ball joints at the same time. From what Ive heard thats one I should definitely go OEM on. Thoughts?
    Thanks guys, I did some searching but was coming up blank.
    Altitude likes this.
  2. Aug 26, 2019 at 6:31 PM
    koditten
    Kirk
    Midland of the Mitten
    You can press out the old bushings and press in new ones. White Line makes a kit.
    It is easier to heat up the old bushings housing with a propane torch. The old ones come out easier that way. A bit smelly, but it's not hard.
    Have you checked to see if you have cam bolts that are removable? Pretty common for them to be frozen. Makes the job a big pain.
  3. Aug 26, 2019 at 6:35 PM
    Daq_daddy
    2005 SR5 Doublecab
    Yeah they are frozen. Im not exactly set up to tackle all of this. So ill be calling in some support. Just trying to do a little research/crowd sourcing before I just go OEM as well
  4. Aug 26, 2019 at 6:52 PM
    koditten
    Kirk
    Are you asking if the control arms that for example, Rockauto sells are good enough quality?
    I have had no issue using those parts. The are listed as original grade. The only difference I can tell is the paint is thicker on Toyota control arms.
    Of course the price is way cheaper. $70 vs $170? Its a "no brainer".
    I'm actually running a left control arm for my 2004 Tacoma that I got from Rockauto.
  5. Aug 26, 2019 at 8:13 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm running aftermarket lower arms that came with bushings. They've been fine so far, been in for 8 months. I went with Beck Arnley but they sent me two arms that came from different manufacturers, different bushings, different paint, different stamps. If I did it again I would probably go Moog on lower arms. The only ones I know to avoid are Mevotech.
    Toyota arms are sold without bushings, the Toyota bushings themselves are about $150 per arm.
    Lower ball joint 100% go Toyota. Get a pair of outer tie rod ends too, those arent as critical so go Moog or Raybestos (I ran Ray's for years and they're stamped 555, good quality).
    JasonC. and koditten like this.
  6. Aug 26, 2019 at 11:32 PM
    Daq_daddy
    2005 SR5 Doublecab
    Definitely the kind of info I'm looking for. Thanks yall
  7. Aug 27, 2019 at 2:08 PM
    growit
    growit New Member
    2006 Dbcb SR5
    I used oem Ball Joints and AC Delco Pro lower control arms
    koditten likes this.
  8. Aug 27, 2019 at 4:08 PM
    koditten
    Kirk
    That's a good recipe.
    Konniekay91 likes this.
  9. Aug 27, 2019 at 5:33 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    A few pics of the arms
    Also, for the pivot bolts you might find that Toyota charges an insane amount. As much as I wanted to go Toyota on those I couldn't justify their price. I went with SPC alignment cam/bolt kits, I bought 2 pairs from Wheelers Off Road. Each pair does one control arm. I wasn't thrilled about the plastic sleeves but so far they are good.
  10. Aug 30, 2019 at 6:23 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    I was able to buy new Toyota OEM lower control arms for like $170ish each. Bushings installed.
    I searched the specific part numbers needed and searched the old interwebs. I think I bought one from Amazon and the other from a toyota dealership with online ordering. Those were the best deals at the time.
    20-30 minutes of searching online can sometimes save a lot of money! Best of luck!
  11. Aug 30, 2019 at 6:51 AM
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    I just picked up Moog LCAs from Amazon for like $106 apiece. Am also replacing the outer tie rods and lower ball joints with OEM from Cool Springs.
    Wait. I know you have the darkest of Tundras, but what Gen is it? I though you have a 1st but those look like the TC cam tabs.
    Darkness[QUOTED] likes this.
  12. Aug 30, 2019 at 8:23 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    First gen. The only TC parts I have are steering rack bushings and spindle gussets.
    FlightSimGuy[QUOTED] likes this.
  13. Aug 30, 2019 at 8:24 AM
    FlightSimGuy
    Ok. So what are those cam tabs?
  14. Aug 30, 2019 at 8:25 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    SPC
  15. Aug 30, 2019 at 8:29 AM
    FlightSimGuy
    Ok. I'll have to see if I can find 'em. That's what I need
    00TundraZ[QUOTED] likes this.
  16. Aug 30, 2019 at 8:31 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    from what I have researched they're your best bet aside from toyota OEM, but those are stupid expensive.
    Good luck!
    :thumbsup:
  17. Aug 30, 2019 at 8:43 AM
    FlightSimGuy
    No, Toyota OEM are those stupid little punched/bent out tabs.
  18. Aug 30, 2019 at 1:43 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you mean the dials with cams, that is SPC. I got them from Wheelers Off Road. If you are looking at the tabs on the frame that the bolts go through that's just Toyota. I know TC makes a tab gusset for 2nd/3rd gen but there is no such thing for 1st gen.
  19. Aug 30, 2019 at 2:33 PM
    FlightSimGuy
    I mean the tabs on the frames. Those came on the truck?
    How do you like the SPC bolts and how long have you had them?
  20. Aug 31, 2019 at 2:27 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah there are tabs on the frame that kind of guide the cam washers. That's how it came from the factory.
    The SPC bolts have been on since January when I rebuilt my entire front end. I wasn't happy about the plastic sleeves they use but they've worked fine so far.
    FlightSimGuy and bmf4069 like this.
  21. Aug 31, 2019 at 8:06 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    These moog Lca probably don’t have same holes as oem for the skid plate?
    FlightSimGuy likes this.
  22. Aug 31, 2019 at 9:50 AM
    FlightSimGuy
    I'll let you know when I get them.
  23. Aug 31, 2019 at 9:52 AM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Sorry I meant the lca skidplate didn’t see you had a 2006.
  24. Aug 31, 2019 at 9:54 AM
    FlightSimGuy
    Ah. Yeah, I don't know if they even have those holes. I was going to check. :D
  25. Jul 26, 2022 at 8:33 PM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Going to bump this up. For those that have replaced their lower control arms, did you have to loosen and move the steering rack down to access the rear cam bolts? The bolts exit out the rear side and will hit the inner tie rod boot. The only solution I see at this point is to loosen the steering rack and move it out of the way a bit to slide those bolts out. Just hate having to do another extra step. Any other recommendations for removing those rear cam bolts?
  26. Jul 26, 2022 at 8:48 PM
    Casper421
    In the woods
    06 DC
    Unfortunately that’s the only way.
    des2mtn and MS22 like this.
  27. Jul 26, 2022 at 9:11 PM
    sn_85
    sn_85 New Member
    Boise
    Always gotta be the hard way. Oh well at least I got all the nuts and bolts loose and hopefully I won't need to saw the cam sleeves out.
  28. Jul 27, 2022 at 3:49 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    Are the lower control arms all the same for all years of the first generation tundra.
  29. Jul 27, 2022 at 8:07 AM
    digitalferg
    digitalferg New Member
    Wandering the Wild West
    2006 Tundra DC TRD 4x4
    No. The earlier years used a smaller lower ball joint and have a smaller taper hole for the smaller LBJ shaft. Looking at Toyodiy, it shows the change-over at build date 08/2004.
    Though there seems to be some conflicting info out there on the 'nets (what a surprise...). I've seen folks with 2004 model year trucks indicate their trucks took the later, larger LBJs (but not mention their specific build date) and also seen some folks say 2003 got the larger LBJ.
    I'd recommend you verify using your VIN if you have a 2003 as indicated on your profile.
    NetGnome[QUOTED] likes this.
  30. Jul 29, 2022 at 10:47 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I was replacing my inner and outer tire rods at the same time so I was able to remove them, turn the wheel and then pull out the alignment cam bolts without moving the steering rack. Either one is a pain though.
    If you do end up loosening the steering rack, replace the bushings at the same time.
