Lowering a 6” lift
Discussion in 'Suspension' started by RuningTnDRA14, Feb 7, 2022.
  1. Feb 7, 2022 at 11:12 PM
    RuningTnDRA14
    RuningTnDRA14 [OP] New Member
    I have a 6” rough country lift kit on my 2014 Tundra. Can you lower a rough country 6” lift using the existing kit? Just need to drop it down to maybe 4” so i can still park the truck in my garage with the leitner bedrack. Thanks in advance.
  2. Feb 9, 2022 at 8:15 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Feb 9, 2022 at 8:18 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Most likely not as the subframe has been cut.
  4. Feb 9, 2022 at 8:21 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Shouldn't matter if it's cut
  5. Feb 9, 2022 at 8:30 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Depends exactly which kit you got. If you have spacers up front, try going with smaller spacers. If you got the coilovers, reduce the preload and get bigger bump stops to prevent the shocks from bottoming out.
    For the rear just get a block that’s 2” shorter and swap them out. Might need to get bigger bump stops in the rear as well.
  6. Feb 9, 2022 at 4:03 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    The RC 4.5" and 6" lift kit (along with many others) is the same except for a few easily swappable parts.
    But what Cruzer said above is the correct info to solve the problem, so i wont bother repeating it.
