Lubricate Propeller Shaft (4wd)
Discussion in '2.5 Gen Tundras (2014-2021)' started by samot, Sep 29, 2023.
  1. Sep 29, 2023 at 9:21 AM
    samot
    samot [OP] New Member
    125 Juniper Rd.
    none
    Hi, First time to lube our Tundras drive shaft. Looking it up i see it calls for two different greases. The double-cardan joint calls for moly-disulphide lithium base, all others lithium base chassis grease. How important is it to follow these directions? Is it harmful to treat the double-cardan joint same as all the others and use lithium base in it? The truck is a 2020 4WD, bought it used with 26K on speedo, like you i want to get as much service from it as can be had. Thxs for your advice. :)
    john in New Mexico
  2. Sep 29, 2023 at 9:26 AM
    SD Surfer
    Bruce
    So Cal
    Following... I don't have an answer, but I wanna' know too.
    samot[OP] likes this.
  3. Sep 29, 2023 at 9:37 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Joints are sealed, can't lubricate on your model year.
    ejes, samot[OP] and Spyker like this.
  4. Sep 29, 2023 at 10:17 AM
    SD Surfer
    Bruce
    So Cal
    Same for 2019?
  5. Sep 29, 2023 at 10:38 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    There hasn’t been zerk fittings for a long time on the Tundra. I think they stopped around 2017 ish.
    I can confirm that my 2020 Tundra doesn’t have them.
    ejes and samot[OP] like this.
  6. Sep 29, 2023 at 10:40 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yeah. My 2019 doesn't have any zerks.
  7. Sep 29, 2023 at 10:43 AM
    SD Surfer
    Bruce
    So Cal
    Sweet!! One less thing for me to probably neglect. :rolleyes:
  8. Sep 29, 2023 at 10:47 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yes, just buy new driveshafts when yours die prematurely.
  9. Sep 29, 2023 at 10:52 AM
    yakeng
    I hate that they aren’t serviceable. All the driveshaft shops in my area are sketchy and take forever.
  10. Sep 29, 2023 at 10:56 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You are basically on hook now and need to replace them every 10 to 15 years. At least that's my experience with sealed driveshafts.
  11. Sep 29, 2023 at 11:12 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I don't have enough first-hand knowledge on the difference between greasable and non-greasable u-joints but this video would have you believe that it's actually an upgrade to have the non-greasable joints
    https://youtu.be/JSPC2Toq27g?si=m3cNnS7k0A72EESw
  12. Sep 29, 2023 at 11:38 AM
    SD Surfer
    Bruce
    So Cal
    Yeah, if it becomes an issue in 15 years (when I'm 76) that's probably what I'll do. :rofl:
    So you've had to replace them I take it?
  13. Sep 29, 2023 at 11:39 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    On my other vehicle (old Volvo wagon).
  14. Sep 29, 2023 at 11:48 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
  15. Sep 29, 2023 at 11:52 AM
    bfunke
    South Carolina
    I’m told the moly fortified is best where shiny surfaces slide across one another as in the slip yoke
  16. Sep 29, 2023 at 11:55 AM
    I've since switched up where moly is required.
    The Valvoline 985 tube has 2.5% moly. Ever since I installed my lift, the SPC arms call for 3% moly, and I've moved to Valvoline Palladium #2 https://www.amazon.com/dp/B0735RLMCC/
  17. Sep 29, 2023 at 12:18 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Correct.
    But in the regular ujoints, you don’t want the moly grease - just regular red grease like shown above. It is available in synthetic, just maybe not valvoline.
    The little rollers in the ujoint ends are supposed to roll. With moly grease, they will tend to slide. Also the moly additive is a solid, which can gum things up. I had a long conversation with an engineer at spicer a few years ago, and thats what I was told.
    so i follow the toyota recommendation, which mirrors what spicer says.
  18. Sep 29, 2023 at 1:43 PM
    bfunke
    South Carolina
    In reality you can probably use Valvoline red or RednTacky on your entire OEM driveline
    HulkSmurf14 and samot[OP] like this.
  19. Sep 29, 2023 at 2:43 PM
    samot
    125 Juniper Rd.
    none
    Title wave of replies, john you're in the right spot. I searched this question before joining this group and asking. The search yielded the link pasted below, guess i need to scroll a bit more to learn some about where i was at. Anyway thx for helping me out here, no fan of 'life time lube' bits and pieces but guess that is what we've got until it seizes and needs replacement. https://www.tundras.com/threads/lubricate-propeller-shaft-4wd.111055/ :)
  20. Sep 29, 2023 at 4:53 PM
    bfunke
    South Carolina
    I think the U-joints without the zerks will last several hundred thousand miles with normal use in mild climates. YMMV with severe use or salt
  21. Oct 15, 2024 at 4:32 PM
    Land Cruiser Tim
    Land Cruiser Tim New Member
    2007 4.7L & 2019 5.7L Tundra, 1997 80 Series Land Cruiser, 1998 Tacoma
    Bumpers Armor
    Wow, no grease fittings and reading this thread confirmed it.
    I'm disappointed with Toyota, so many things done right with the 2019-2021 and with the 2022+ fiesco no thanks.
    But...... No grease fittings.....? Huh? ...... No transmission cooler.... Head scratcher!
    I'm a Land Cruiser guy and a maintenance nut, I feel incomplete without greasing the drive shaft after an oil change but.....
    Kinda makes me rethinking selling the 2007 4.7 tundra, such a great truck for years but we needed more for our new Jayco trailer.
  22. Oct 15, 2024 at 4:54 PM
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
    Most people can get 150k+ miles out of u-joints. Some people never change them ever
    If you're super paranoid, you can get spicer u-joints for about $40 a piece. All of the popular chain autoparts store let you rent a tool for free (deposit needed) to make swapping them easy. I can swap out a set in about 45 minutes from when I park my truck
    Wishbone Runner likes this.
