lug nut question???
Discussion in 'Wheels & Tires' started by wrtnaz, Sep 19, 2018.
  1. Sep 19, 2018 at 9:52 AM
    wrtnaz
    wrtnaz [OP] New Member
    Tucson, Az
    2018 MGM Tundra SR5 CrewMax
    Wireless Charging Center Console Tray 6 3/4" Antenna Mast OEM Bed Mat Weather Tech In-Channel Low Profile Wind Deflectors Chrome Mirror Caps/Handles Limited Grill w/Chrome Surround Ionic 5" Oval Stainless Step Bars Center Console 110v and USB Power Converter Black Tundra Door Sill Protecters Undercover Swing Case Wireless LED Bed Light Strip Toyota Chrome Exhaust Tip 18" TRD Wheels
    I have a 2018 SR5 with steel wheels and purchased the aluminum TRD Pro wheels from someone off a 2017. I went to Discount tire to have them installed and they just called and said they need different lug nuts. I looked on here and the size lug nuts is M14x1.5. What is different about the ones I currently have on my 2018 and what they say they need? I called the dealership and they say they have them for $20 a piece. Autozone says they have them for $2 a piece. I am super confused. If M14x1.5 is what I need then why don't my current ones work and why is there different prices at autozone and the dealer? How do I know if what auto zone is offering is correct or not? Do I give them the info off the vehicle I purchased the wheel from or the info from my current vehicle to find out what lug nut I need? PLEASE HELP
  2. Sep 19, 2018 at 10:10 AM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    My understanding is the steel wheels use the acorn style lugs because the wheel is not hub centric so tapered ends of the lugs center the wheel. The aluminum TRD wheel is hub centric and uses the flange style (Flat) lugs. Torque specs for steel wheels is different from the ones on the aluminum wheel. I made sure to get the lugs with the OEM TRD wheels that I bought off CL.
    ChrisTRDPro likes this.
  3. Sep 19, 2018 at 10:13 AM
    wrtnaz
    Tucson, Az
    I definitely saw that there is a difference for torque value. So are you saying the 14<x1.5 is the size but the difference is the shape of the lugnut itself? I have contacted the guy a purchased the wheels from and he is going to see if he has them when he gets home from work today. Thanks
  4. Sep 19, 2018 at 10:19 AM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    Yes, the seat of the lugs are different. The lugs for steel wheels are tapered(conical) and the lugs for the aluminum wheels are flat. I don't know if you can use the conical seat lugs on the aluminum wheels. I've seen some people say they've used them but don't know if that would damage the wheel.
  5. Sep 19, 2018 at 10:24 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    IMG_20131119_215641_zps71756522.jpg The lug on the right is what you need for the TRD wheels. Don't use the acorn lugs on the aluminum wheels. The lug well in the aluminum wheels are totally different and you wont get the lugs to seat properly. The torque spec for the aluminum wheels is 97 FT/LBS.
    Jerry311SD, scpete24 and ChrisTRDPro like this.
  6. Sep 19, 2018 at 10:30 AM
    wrtnaz
    Tucson, Az
    that is perfect...thanks for the pic. Now that I see the difference how do I find it?
  7. Sep 19, 2018 at 11:58 AM
    duece292
    Greg
    Green Bay, WI
    I'm sure a dealer has them but you'll pay a premium. I've seen them on Ebay in stainless and in black for around $40.00 for a set.
  8. Sep 19, 2018 at 12:03 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    If you are a Costco member you can get a 20% off coupon for parts & service at a participating Toyota dealer.
    Edit: Just double-checked Costco and the coupon is for 15%.
  9. Sep 19, 2018 at 12:03 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Check local auto parts stores they should have some in stock
  10. Sep 19, 2018 at 12:16 PM
    duece292
    Greg
    Green Bay, WI
    Gorilla has OEM lugs. 73148TXX is the part number, add BC to that for the black chrome ones. I think they're sold individually.
  11. Sep 19, 2018 at 12:50 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    ^^^^^^That is the way to go. I have Gorilla lugs in black. They are very high quality, better than OEM. And they are cheaper than OEM, but not the cheap stuff you find at the autozones. You can buy them in different quantities. For some reason, I remember that I had to buy mine in packages of 4, so 5 packages.
  12. Sep 19, 2018 at 12:55 PM
    tbutler
    tbutler Team Toyota
    2021 Land Cruiser HE - Black
    How do you get this 20% off coupon?
  13. Sep 19, 2018 at 1:03 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    On costco.com select "Services" --> "Costco Auto Program" and the click "Learn More" (this will take you to the auto program website). There is a menu for "Parts & Service" (sorry - looks like the discount is 15%, not 20). Fill out the form and you can get a coupon for the dealer in your area that participates. If you want to go to a dealer in a different city you can try entering the zip code for that dealer. (i used this at our local GMC dealer to get 15% off the service of my wife's suv).
  14. Sep 19, 2018 at 1:03 PM
  15. Sep 19, 2018 at 1:04 PM
    https://www.costcoauto.com/parts_and_service/enterzipcode.aspx?gotourl=/parts_and_service/
  16. Sep 19, 2018 at 1:11 PM
    tbutler
    tbutler Team Toyota
    Thank you for the quick reply! This will be handy.
    Also thank you to @Jim LE 1301 for the link.
  17. Sep 19, 2018 at 1:13 PM
    :thumbsup:
    tbutler[QUOTED] likes this.
