Lug nuts
Discussion in 'Wheels & Tires' started by 1Tundra5, Dec 26, 2024.
  1. Dec 26, 2024 at 4:19 PM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    My dad will go from the stock steel wheels to the aluminum 18 inch Trd off road wheel. Do they both use the same lugs nuts?
  2. Dec 26, 2024 at 4:32 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    The steel wheels use the acorn style nuts. Aluminum wheels require the shank style nuts.
    I think the part number is 90942-A1001 (please check) but would recommend getting the solid nuts rather than the OEM nuts so you do not have the 'swollen' issue down the road.
  3. Dec 26, 2024 at 4:34 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Nothing worse than swollen nuts.
    Tripleconpanna likes this.
  4. Dec 26, 2024 at 5:13 PM
    1Tundra5
    Junior
    2015 White SR5
    which are the solid ones?
    I have the ones that are have a loose washer like part.
  5. Dec 26, 2024 at 6:05 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
  6. Dec 26, 2024 at 8:02 PM
    Jmunk
    Jmunk New Member
    2020 Tundra SR5 Crewmax
    The lug nuts for the aluminum wheels use a washer, the steel wheel lug nuts use a conical style. The aluminum wheel lug nuts have a conical end and can be used on a steel spare wheel.
    Don’t use the conical style lug nuts on an aluminum rim, you’ll ruin the rim.
  7. Dec 26, 2024 at 8:52 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Usually the rim seller (on Offerup or whatever) would give you the lugnuts with the sale as they don’t have any use for them. The Toyota Aluminum style nuts are pretty specific to the design.
