Magnuson flex fuel
Discussion in 'Performance and Tuning' started by Tundra_wil, Oct 16, 2023.
  1. Oct 16, 2023 at 4:42 PM
    Tundra_wil
    Tundra_wil [OP] New Member
    I have a 2016 FF 5.7 truck . Does anyone know if you use the OEM fuel pump / injectors for base 91 fuel? Also what’s the limit of the FF injectors and pump?
  2. Oct 16, 2023 at 4:48 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  3. Oct 16, 2023 at 4:53 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Have you reached out to Magnuson?
  4. Oct 16, 2023 at 4:55 PM
    AZTundra
    Paul
    Phoenix, AZ
    I have a 2017 Flex Fuel with the Magnuson. It utilizes the factory Flex Fuel pump, there isn't a need to swap the pump unless you are going to be pushing more power than a standard Magnuson kit. The fuel injectors should be the green injectors included with the kit (they replace the stock flex fuel injectors). I think the green ones are rated at 535cc's.
    I'm running a smaller pulley (2.2") from @snivilous and still using the stock flex fuel pump and green injectors, but running a custom dyno tune.
  5. Oct 16, 2023 at 6:20 PM
    Tundra_wil
    im looking into the 2650 kit mainly for towing I live in AZ as well so that’s good info was there any special instructions for the pump? I heard it had to be set to zero ethanol or something
  6. Oct 16, 2023 at 9:20 PM
    AZTundra
    Paul
    Phoenix, AZ
    I'm not 100% sure on the newer 2650 kit. My Magnuson is the older 1900 model. I know there is a Toyota TSB for ethanol issues on the flex fuel trucks. I don't recall anything specific during the inital install regarding that, but I did have to have my ethanol percent reset once due to the percent creeping up. I've had the blower for 3.5 years and it's been relatively solid aside from needing a coupler replaced.
    If you haven't found a shop yet I highly recommend going through Jeff at Westcott Designs over by 19th Avenue and Happy Valley. They have done many installs over the years.
    HulkSmurf14, Saltyhero13 and reywcms like this.
