Magnuson Performance Package Released
Discussion in 'Performance and Tuning' started by wxman91, Dec 19, 2024.
  1. Dec 19, 2024 at 1:47 PM
    wxman91
    wxman91 [OP] New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
  2. Dec 19, 2024 at 2:09 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Hmm, they mention airflow increase but nothing about HP, Torque, potential MPG improvement. Maybe it is just about better air and heat exchange?
    Id expect dyno numbers from them, especially considering the picture on the product webpage is of a tundra sitting on a dyno. :monocle:
  3. Dec 19, 2024 at 2:16 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    If they do the same with the Tune for the NA that they do with the FI you should keep your $. The tune they made for the SC did nothing for shifting logic. Had to go to a "tuner" and VFTuner to get a real tune that made the Magnuson product worth the investment.
  4. Dec 19, 2024 at 2:31 PM
    MVRCA
    MVRCA New Member
    Las Vegas
    2016 Tundra TRD Pro
    White Knuckle sliders, BDS 3" lift with Fox 2.5's. Method 305 NV with 35" Trail Grapplers.
    I dig it.
  5. Dec 19, 2024 at 2:41 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    $3400 for no appreciable gains :rofl:
  6. Dec 19, 2024 at 4:07 PM
    Frank_TRD23
    Frank_TRD23 New Member
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    And those images look like CAD file design not actual model.
  7. Dec 19, 2024 at 5:56 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Stillen 2.0?
  8. Dec 20, 2024 at 7:08 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    To summarize:
    "this cooler significantly reduces intake air temperatures (IAT) to ensure consistent, repeatable performance", but no mention how much it actually reduces temperatures...well it is red so thats rad
    "Breathe new life into your engine with a robust cold air intake system that increases airflow by 25% over the factory airbox. Designed for a simple 15-minute install"....15 minutes? I highly doubt anyone could swap out a twin intake in 15 minutes and more air without mapping for more fuel is pretty useless..
    "Keep your intake temperatures under control with a high-performance, double-pass, all-aluminum radiator. Using B-tube technology the LTR is engineered to increase total heat exchanger surface area by 2.5 times compared to stock"....if somehow this radiator's claims are true for $649.00 thats probably cheaper than an OEM radiator and if it has 2.5 times the surface area that would be impressive, but skeptical thats true
    "Unleash an aggressive growl and improved exhaust flow with a 3-inch, mandrel-bent, T-304 stainless steel cat-back exhaust system. This system reduces backpressure, increases airflow,"....Decreased back pressure isn't always a good thing at least you are unleashing the aggressive growl so thats also rad ...
    $3400 ish to be more rad is pretty rad for Magnuson, I bet you get a lot of stickers with it to so you can show everyone how rad you are too!!!!!
  9. Dec 20, 2024 at 7:20 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Window Dressing!
  10. Dec 21, 2024 at 1:54 PM
    Frank_TRD23
