Main & Rod Bearing Spec
Discussion in '3rd Gen Tundras (2022+)' started by KFRC46, Aug 22, 2024.
  1. Aug 22, 2024 at 7:06 AM
    KFRC46
    KFRC46 [OP] New Member
    Can anyone with TIS access post this?
  2. Aug 22, 2024 at 7:18 AM
    Breathing Borla
    Northern Illinois
  3. Aug 22, 2024 at 9:53 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    I can find the main clearances for the V35A that comes in the LS500, but the rods seem to be absent from their usual place in the manual.
  4. Aug 22, 2024 at 10:01 AM
    KFRC46
    That would be great if you can share, thank you!
  5. Aug 22, 2024 at 11:33 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Main journal 73.988 - 74.000
    Clearance metric
    Journals 1 & 4 .031 - .047 max .052
    Journals 2 & 3 .035 - .053 max .058
    Rod journal 55.392 - 55.400
    No clearance given, will look further.
    Tunrod likes this.
  6. Aug 23, 2024 at 5:40 AM
    KFRC46
    These clearances call for a 30W oil for temps up to 220F and 40W over 220F.
    Given the undersqaure bore/stroke ratio, high torque and boost pressure, bearing issues could be here to stay if you are using 0W20 oil..........
  7. Aug 23, 2024 at 6:18 AM
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    Interesting, I wonder if switching to a 10w - 30 weight oil would be beneficial for longevity. The issue I can see going that route is the first 20K you are supposed to take the truck back for an oil change at the dealer who would use 0w-20. I supposed that could be negated by letting them change the oil there and promptly switching it out. It would an interesting experiment.
  8. Aug 23, 2024 at 6:26 AM
    KFRC46
    I have been running Shell Rotella T6 5W-40 since 1500 miles, last UOA was less than average wear.
    Oil temps run around 220F driving up to 240F towing........
  9. Aug 23, 2024 at 6:30 AM
    Wtundra2023
    Now that is interesting. There is an oil analysis thread in here somewhere it would be interesting to see your results over the life of you engine vs someone who uses the 0w-20. How many miles do you have on your truck currently?
  10. Aug 23, 2024 at 6:31 AM
    KFRC46
    30K
  11. Aug 23, 2024 at 6:35 AM
    Wtundra2023
    It may be worth switching it out.
  12. Aug 23, 2024 at 6:48 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  13. Aug 23, 2024 at 6:52 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Yes, I too thought it was interesting that the clearances are larger than even the UR Series V8…. Which ideally should really run a 5W30. Like most accidents and disasters, we’ll likely see a combination of factors that add up to a failure.
    AZBoatHauler likes this.
  14. Aug 23, 2024 at 7:03 AM
    Wtundra2023
    raylo likes this.
  15. Aug 23, 2024 at 7:06 AM
    KFRC46
    The question is: "Is Toyota specing a 0W20 for fuel economy at the expense of longevity"
    The engineering requirement for oil viscosity to rod and main bearing clearances is not open to debate.
    A decision to deviate is knowingly making a compromise; At cruise RPM and low load on the highway, running no boost, in cool climates, with frequent changes, no fuel dilution, oil temps @ or under 212F a 20W MIGHT be sufficient...........
  16. Aug 23, 2024 at 7:36 AM
    dJunior
    dJunior New Member
    CT
    I think the page got taken down in a purge, however, the international LC manual calls out multiple viscoities with 0w-20 being the ideal one.
    However it shows you can run 5-20, 5-30 and 10-30(0F+)
    0W20 called out for best fuel econ and cold-weather starting.
    I would much rather run 5-30 in my engine, however, US manual doesnt call that out and if things blow up I really dont want to risk it with Toyota finding 5w-30 in my engine. (12/23 build)
  17. Aug 23, 2024 at 7:56 AM
    sudobash
    sudobash New Member
    The overseas LC300 with the V35A-FTS (Type '21) are seeing similar failures.
  18. Aug 23, 2024 at 7:57 AM
    KFRC46
    I think if it blows up there would be so much particulate in the oil you couldnt tell what viscosity it was.
    raylo likes this.
  19. Aug 23, 2024 at 8:06 AM
    dJunior
    dJunior New Member
    CT
    Correct- however, this was to the point that 30 weight oils would be more than OK as discussed above and looks like the engine was designed for that initally.
  20. Aug 23, 2024 at 8:08 AM
    sudobash
    sudobash New Member
    5W-20 is perfectly ok in the Tundra/Sequoia.
  21. Aug 23, 2024 at 8:15 AM
    dJunior
    dJunior New Member
    CT
    I would rather throw 5w-30 in it than 5w-20- especially since the engine can tollerate it just fine. Again I just dont want to risk it with a blow-up.
    sudobash[QUOTED] likes this.
  22. Aug 23, 2024 at 8:18 AM
    sudobash
    sudobash New Member
    The Tundra/Sequoia manuals specifically call out 5W-20 as being able to be used, so if you are wanting to use a thicker oil, 5W-20 fits the bill and the manual supports it.
    Breathing Borla likes this.
  23. Aug 23, 2024 at 8:20 AM
    dJunior
    dJunior New Member
    CT
    5w is only thicker at startup temps. Operating temps it is just 20 weight oil. 5w-30 would be a thicker oil at operating temps.
  24. Aug 23, 2024 at 9:00 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    One would think if viscosity was an issue it would surface in the other bearings as well?
    dJunior and Breathing Borla like this.
  25. Aug 23, 2024 at 9:03 AM
    Breathing Borla
    Northern Illinois
    this^
    its not viscosity, if it were you would see a MASS of failures not a few compared to all the tundras and V35A on the road, remember, they have made 100's of thousands of these now.
  26. Sep 11, 2024 at 7:27 PM
    carbinefreak
    carbinefreak New Member
    So knowing the bearing clearances are 30/40 weight depending on temps who else is running heavier oils? I live in the mountains of Colorado and my oil temps consistently hit 220-230F going up mountain passes when the truck is empty. Granted my 35" wheels have something to do with it probably. The truck is a lot quieter with 5w30 in it all the way to redline verses the 0w20. I'm not going back after running 0w20 for over 30k.
    sudobash likes this.
  27. Sep 11, 2024 at 9:10 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    In my previous Ecoboost Ford's, they called for 5W30 oil, which the Toyota engine is based on. Ask me how I know. Anyway, I routinely ran 10W30 and my Ecos liked it better. Quieter operation and no noticeable difference in fuel economy. I only have close to 12K miles on my Tundra, so I'll be switching to 5W30 oil at the next change. If it fails, it fails. But I highly doubt it will. I just believe with what I put my truck through, extreme heat here in Phx and towing, that the heavier oil will provide better protection. YMMV.
  28. Sep 12, 2024 at 4:11 AM
    dJunior
    dJunior New Member
    CT
    I would love to do 5W30, however, I dont want to jepordize warrnty and replacement issues in the future. At 61,000 i would make the switch.
    Unless Toyota for the US states it is OK to run 5W30 like they do for the 300 series.
  29. Sep 12, 2024 at 6:02 AM
    KFRC46
    I towed for about 3 hours yesterday on the interstate, oil temps were 232-238F.
    I wonder what the how thin a 20W would be at those temps..............?
    dJunior likes this.
  30. Sep 12, 2024 at 2:28 PM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    I wonder if with the new short block part # 11400-F4020 addresses the issue?
