Maintenance required
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bentarm13, Nov 26, 2022.
  1. Nov 26, 2022 at 2:09 PM
    Bentarm13
    Bentarm13 [OP] New Member
    So..driving home suddenly maintenance required shows on the dashboard. Get home and call dealer to schedule service appt. Next day start truck and the message is still there, no dashboard controls, truck is shifting with a noticeable pause. App is showing maintenance required. Any ideas what I am in for? Already need to have the drivers exterior trim replaced, oil change at 12k.
  2. Nov 26, 2022 at 2:13 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Keep track of your own maintenance.
    Turn off the maintenance required light as follows:
    Put Tripometer on Trip A
    Turn engine off
    Push the tripometer reset button and hold
    Turn the engine on to the accessory position. DO NOT let go of holding down the Tripometer reset.
    Watch as the screen tells you "resetting maintenance"
    After that it will be turned off.
    Again. Keep track of your own maintenance activities. The idiot light "maintenance required" is just that.
  3. Nov 26, 2022 at 2:13 PM
    The maintenance required light is telling you that your oil change is coming due.
  4. Nov 26, 2022 at 2:14 PM
    That procedure depends on the model year. My 2020 has a reset maintenance in the dash display menu.
    MadMaxCanon, Jaypown, Neo258 and 3 others like this.
  5. Nov 26, 2022 at 2:17 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    It's not telling you that something is wrong, like a check engine light. "Maintenance required" pops up on my dash every 5k miles. As others have said, it's an oil change reminder.
    I think your noticing the truck shifting late is maybe just because you saw this light on the dash and are looking for the cause.
    JLS in WA, Neo258, snivilous and 5 others like this.
  6. Nov 26, 2022 at 2:55 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    2018 also has reset in the menu
  7. Nov 26, 2022 at 3:57 PM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    It's your truck but I would never run a new engine 12,000 before I dropped the oil and filter
  8. Nov 27, 2022 at 9:27 AM
    Bentarm13
    Dude, this will be my 3rd fluid change. Guess it makes Sense, got 1 at 2k and 7k. Just seems silly the truck wouldn’t tell you what maintenance is needed.
    WILLINH likes this.
  9. Nov 27, 2022 at 9:41 AM
    FrostyTundra22
    FrostyTundra22 No longer new member
    2020 Toyota Tundra 1794 Crewmax
    The truck will never tell you what’s needed. It will only say Maintenance required every so often. On my Toyota’s, I believe the dealership has it set at 5k intervals.
  10. Nov 27, 2022 at 10:00 AM
    Kernal
    Kernal New Member
    Kyle
    Charleston SC
    ‘18 4x4 4x4 DC
    Ever heard of an owners manual? Depending on year and mileage your trucks Maintenance light will come on every 5000 miles. It’s just for the oil change interval.
    Consult your owners manual for other regular recommend service intervals.
    JLS in WA and Joe333x like this.
  11. Nov 29, 2022 at 4:50 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Depending on your year, Toyota has a 10K mile OCI for oil changes. I get a Maintenance reminder light for those. I also get them every 5K for tire rotation.
    Also, what @Kernal said. Look at the owners manual. Plethora of information.
  12. Nov 29, 2022 at 8:48 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Lol should tell you what is needed? Nobody ever said Tundras were that smart
  13. Nov 29, 2022 at 9:57 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I thought every God fearin' man kept a maintenance notebook, in the garage, for all of his cars?
    I also use the "maintenance" section in the tundra console to remind me to do sh1t.
    HulkSmurf14 and Terndrerrr like this.
  14. Nov 30, 2022 at 10:38 PM
    Bentarm13
    I have not heard of that. There’s a big book with lots of pages in my glove box thingy but I can’t read so good and there’s no pictures. Any other advice Chief?
    muskytuck likes this.
  15. Dec 1, 2022 at 4:22 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    The maintenance required light starts coming on at 4500 miles then goes away and stays on at 5000 miles. It is triggered strictly by miles.
  16. Dec 1, 2022 at 6:09 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    He's just giving you the correct answering. The Toyota suggested maintenance intervals is in the manual and that light just comes on every 5k and can be reset easily on your own.
  17. Dec 1, 2022 at 6:18 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I write it down in the back of the maintenance book that came with the owners manual in the glove box that has the mileage intervals of what needs to be done/checked. Gotta make sure you check off that floor mat inspection!
  18. Dec 1, 2022 at 6:27 AM
    Joe333x
    Joe333x Member
    Boston
    I started using Google Keep, that way it's backed up and I keep part numbers, links to tutorials ect.
    MadMaxCanon[QUOTED] likes this.
  19. Dec 1, 2022 at 6:28 AM
    MadMaxCanon
    Nice, I would totally buy a truck from you
  20. Dec 1, 2022 at 6:29 AM
    Joe333x
    Joe333x Member
    Boston
    Haha thanks, my goal is to keep it forever :fingerscrossed:
  21. Dec 1, 2022 at 6:32 AM
    MadMaxCanon
    Same. I kind of have to at this point. My garage looks like a toyota service parts department. I bought fluids, filters, wipers, all sorts of maintenance stuff on sale that should last me till 100k miles.
    Joe333x[QUOTED] likes this.
