Making sequential tail lights work?
Discussion in '3rd Gen Tundras (2022+)' started by smileytn1, Jan 28, 2024.
  1. Jan 28, 2024 at 11:44 AM
    smileytn1
    smileytn1 [OP] New Member
    HI all! Has anyone found a way to make sequential taillights to work on a 2022 limited? I know the capstone does this like the ford mustang does but i need to know if it is programmed into the software or would I have to purchase those tail lights and will they plug in without modifications or does anyone make a kit to make this possible? Thanks for all ideas! smileytn1
  2. Jan 28, 2024 at 11:48 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    You have to buy the lights, they aren't cheap. They plug in same as the standard taillight.
  3. Jan 28, 2024 at 1:02 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I did the swap on my SR5. Works perfectly fine and was able to sell my OEM lights for 500 so was all in for maybe 300 for the upgrade. Completely plug and play.
    If you consider doing this, would also look into getting the tailgate elbow harness (eBay) to add that functionality as well.
    ryanwgregg and pwpblue like this.
  4. Mar 10, 2024 at 1:29 PM
    smileytn1
    Hi Goobax ,where did you sorce these and do they have the tailgate switch? i have a limted could you send a link please?
  5. Mar 11, 2024 at 9:03 AM
    ArBrnSnpr
    ArBrnSnpr New Member
    Colin
    22' AG SR5 TRD OR
    If you have a link for the harness, please share! I'm not too concerned with sequential taillights, but I would really love to have the elbow button!
  6. Mar 11, 2024 at 10:39 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I ordered from sparksparts. Would see if you have a local dealer who does online pricing though as shipping can be expensive for larger items. The part numbers are in the ultimate parts thread so you can search there if needed.
    the guy who makes them releases them on eBay. Search his username on YouTube and he posts a video of how to do the swap and what part numbers are needed for the taillight button and trim piece. You dont need to do the sequential tails to do the mod. I just figured why not as it was not a lot of investment for me since I sold the OEM tails for 500 for the pair
  7. Mar 11, 2024 at 1:00 PM
    ArBrnSnpr
    Colin
    22' AG SR5 TRD OR
    If I could sell my stock lights, it would definitely make the swap more appealing! You may have lucked out getting that much for them though.
    Thanks for the link!
  8. Mar 11, 2024 at 1:45 PM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    If you wanted to add the tailgate release switch to the passenger side instead I figure all you would need is a longer adapter harness? What if you wanted a switch on both sides I guess the adapter harness would need two female ends and one male end?
  9. Mar 11, 2024 at 2:05 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    would assume would be a simple extension and/or splitter but can’t speak to on weather or not the trim piece is ambidextrous or amenable to being cut out for the button and mounting appropriately
  10. Mar 12, 2024 at 8:44 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    In order for the elbow switch to work, does the truck have to be unlocked?
  11. Mar 12, 2024 at 9:40 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    No. Need the key fob in your pocket/on your person. If unlocked no fob needed
  12. Mar 13, 2024 at 4:04 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Ok. So it has a pickup sensor like the tailgate handle. It'll allow the regulate to open but not unlock the truck. Thanks.
  13. Mar 14, 2024 at 7:59 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    i talked to the guy who makes the harnesses and he said its doable but the switch doesnt fully bolt up to the passenger side trim. Stays in place fine, just doesnt use all mounting tabs
    G3ardnut[QUOTED] likes this.
  14. Mar 14, 2024 at 8:43 AM
    G3ardnut
    Joe
    Canada
    Thanks for looking into that. It would be nice to have the release on both sides of my Limited TRD OR. So besides securing the switch fully I think the harness he sells would also work just by extending the wires that go to the male plug on the drivers side and also protecting these wires with a wire loom. I am also concerned as to how water tight this harness is on the backside of the connectors. I would probably need to de-pin it and put on some heat shrink on the backside of those connectors. That is a nasty environment back there.
    So parts needed would be the switch, 84945-0C010 (about $65 US) the switch bezel which they call a Tail Light Assembly Insulator??? you need to buy the sequential turn signal type 81568-0C1060 (about $10 US) and the $60 harness which I think is a bit pricy for what it there but the Engineering is done for you.
  15. Mar 14, 2024 at 9:36 AM
    ArBrnSnpr
    Colin
    22' AG SR5 TRD OR
    Does anyone have direct contact info for the harness seller? I like to avoid eBay wherever possible.
  16. Mar 14, 2024 at 9:51 AM
    G3ardnut
    Joe
    Canada
    I did a search under vanga115 and it shows that he has no stock left right now. Plus a got a number hits showing what appears to be the exact same harness but made in China and are generally $16 less including shipping.
  17. Mar 24, 2024 at 7:48 PM
    RatPanda
    RatPanda New Member
    Ryan
    2022 Tundra 4x4 CrewMax 5.5
    Don’t forget the two little orange clips if you’re as OCD as I am…they don’t come with the trim piece.
    Tundrastruck91 likes this.
  18. Apr 20, 2024 at 11:57 AM
    rwsessions
    rwsessions New Member
    Ryan
    2023 Silver SR5
    Do you have a part number for the clips?
  19. Apr 20, 2024 at 2:19 PM
    rwsessions
    Ryan
    2023 Silver SR5
    Thanks @ryanwgregg!!
    ryanwgregg[QUOTED] likes this.
