Marker & Fender Lights
Discussion in '3rd Gen Tundras (2022+)' started by Gary86, Apr 14, 2024.
  1. Apr 14, 2024 at 6:13 PM
    Gary86
    Gary86 [OP] New Member
    Gary
    2024 SR5 TRD Off-Road
    6" Readylift|Hostile Rage 20x10|Toyo OC R/T 35s|TRD Sway Bars| 2019 PRO Headlights w/ @iHacker harness|Morimoto Foglights|5% Tint
    Hey everyone. I did a search and didn’t really find an answer.
    I’m looking to get the Pro fender flares and wrap matte/flat black and also the marker lights for the grille. The Rave harness for the fenders looks like it taps into the running lights for head/taillights.
    I’m trying to see if anyone has wired the grille marker lights to a source such a running or headlights? I don’t want them on all the time.
    I’m hoping to get these all wired up to come on only with running lights or when the headlights are on.
    I appreciate any help.
  2. Apr 15, 2024 at 7:53 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    There is lots of info on the forum about this topic. Do you have premium headlights or no?
    Can’t tap into the premium lights as they are canbus. Non premium you can.
    in waiting on my fenders. I will be doing a 7 pin to 4 pin harness, and wiring then to that. That way they only come on with running lights, and there is no damage/scarring left on oem wiring harnesses.
    Blufin and Gary86[OP] like this.
  3. Apr 15, 2024 at 11:33 AM
    Gary86
    Gary
    I have the none premium. Rave has a wiring harness for the fenders that taps into headlight/tail light running light wires so they aren’t on all the time.
    I was trying to accomplish the same with the grille lights.
  4. Apr 15, 2024 at 11:34 AM
    Gary86
    Gary
    I reviewed that thread. Didn’t see anything specifically for wiring the grille lights to the running lights for the headlights. Rave makes a harness but it’s to the ignition. I’m going to look at the fuse boxes for a different fuse to tap.
    Selldawg22 likes this.
  5. Apr 15, 2024 at 3:26 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    you didn’t read the thread as I am just one of the ones that posted the exact information you are looking for.
    Not trying to be difficult here but you were linked with a direct answer to your question. You can tap into the same running lights up front for the TRD flares that you can for the TRD grill marker lights.
    Black widow TRD and teab like this.
  6. Apr 16, 2024 at 11:38 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    So you understand where you are going to tie the marker lights on the fender flares but you don't grasp the concept that you can wire the grill lights to the same circuit? The answer is to wire the grill marker lights to the same source you're choosing to power the front fender flares.
    ryanwgregg likes this.
  7. Apr 16, 2024 at 2:03 PM
    Gary86
    Gary
    Thanks. I got that. I’m far from being electrically inclined. All the plug and play harnesses I’ve found don’t allow for that for the grille markers. I’ll probably find someone local from our Toyota group to help.
  8. Apr 18, 2024 at 2:34 PM
    Gary86
    Gary
    Thank you. I guess I could wrap in electrical tape to help.
  9. Apr 29, 2024 at 5:29 PM
    Selldawg22
    Selldawg22 New Member
    Looking into the same thing. Did you find a different fuse to tap?
  10. Apr 29, 2024 at 5:54 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Not a Gen 3, but I tapped into the headlight parking lights for my grille lights in my 2014.
    Put a very small inline fuse and a Deutch plug in case I needed to remove the grille.
    I used to have to remove the grille to change headlight bulbs but now have OEM LED headlights.
    Also used that circuit for my Rigid pods..
    They come on with the parking lights..
    ED9943DE-EF87-495C-B7D9-2D0618D68B24_zps_84d5ac37a38531fa0c15f8880a3edfe145b48c00.jpg 2AC76BE3-391B-41D3-A70A-E8FC2829176D_zps_e572e0f24156aa20ac37f373090c3865fa2b28be.jpg 5F225999-563B-4406-85F4-7844858A0198_zps_f5708ba39e084ec06f8781bc55d4d9c4a2819a22.jpg
    51AA14B2-FCB4-48B4-ACE9-C05B99AC172E_zps_3216112bc4b49f1a9cafbd4fc2ed9f5d853356a3.jpg D9EBA7D3-462C-46D1-8875-3CB261A5B8D5_zps_12e8bbb7d376b3bf8a000c3066d6e7c14ce8bcc4.jpgvye6ix6v_zps1xm0ffid_dff50e2fc975337da564912e210d094cb4768f9f.png
  11. Feb 20, 2025 at 2:48 PM
    Chief Wraps
    Chief Wraps New Member
    Oak Harbor, Washington State
    2024 Tundra Platinum, 4x4, V6, loaded
    Bug deflector, mud flaps, electric side steps, folding bed cover, tinted windows, AVS Window Deflectors, Blue interior accents, vinyl wrap pieces on hood, fenders, tailgate, front bumper cover.
    Incorrect. You can tap into the premium lights wire for the DRL. I just did it when I installed my vent lights.
  12. Feb 21, 2025 at 7:43 AM
    Ipaddick
    Ipaddick New Member
    Canada
    I’m against tapping into factory wires. Made myself a wiring harness, that goes from the 7pin to 4 pin trailer harness. Used deutsch connectors throughout. Everything can be quickly disconnected if need be, and removed.
  13. Mar 1, 2025 at 2:25 PM
    bailey bulldog
    bailey bulldog New Member
    I have the premium led headlights....what kind of plug and play solution is there for the front fender marker lights?
  14. Mar 1, 2025 at 2:44 PM
    Ipaddick
    Ipaddick New Member
    Canada
    The closest you’ll get to plug and play is rave might have a harness that uses an add a fuse. But making yourself a harness like that is not hard, and a lot cheaper
  15. Mar 1, 2025 at 2:46 PM
    bailey bulldog
    I've got that....I was thinking, could you maybe get a fog light splitter, and wire up the fronts to the split?
  16. Mar 1, 2025 at 2:48 PM
    Ipaddick
    Ipaddick New Member
    Canada
    Probably could.
  17. Mar 1, 2025 at 6:01 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    if you want the marker lights only on when the fogs are on, sure
    Ipaddick likes this.
  18. Mar 1, 2025 at 7:34 PM
    bailey bulldog
    LOL, ya I didn't think that through did I?
    Goobax[QUOTED] and Ipaddick like this.
