May have found an inexpensive canopy for my truck!
Discussion in '1st Gen Tundras (2000-2006)' started by AlbertaBeef, Jan 20, 2020.
  1. Jan 20, 2020 at 8:58 AM
    AlbertaBeef
    AlbertaBeef [OP] New Member
    Glen
    Airdrie, Alberta, Canada
    2001 Tundra 4x4 Access Cab TRD Off Road
    17" Rims and 265/70R17 tires, 20" Light Bar, Power Stop Brakes, Diff Breather Relocate
    It's a proper fit, I think - it was on the previous owners 2006 AC and I have a 2001 AC - should be same fit I believe, right??
    it's in a bit of rough shape with lots of weather exposure (which just appears to make it easier to paint as almost all the lacquer/clear seems to be gone) and some hinge issues. It only closes on one side (hinge/alignment issues) and there's no keys ... and it involves about 4 hours of driving ...
    BUT it's only $200 and all the glass and seals are intact.
    Turns out the manufacturer is still in business making caps so I *may* be able to get some parts for repairs.
    I will be headed out on Friday to see it and hopefully pick it up. I'm excited as it seems these are a rare find, from what I can tell.
  2. Jan 20, 2020 at 9:02 AM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
  3. Jan 20, 2020 at 9:26 AM
    AlbertaBeef
    Glen
    pics he sent were CRAP. Like 200x300 and fuzzy. I'll take pics once I head out there.
  4. Jan 20, 2020 at 9:38 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes, the bed dimensions are the same from 01-06. Who is the manufacturer?
  5. Jan 20, 2020 at 10:04 AM
    Professional Hand Model
    Hand Protectors
    Are you positive the bed dimensions are the same?
    Without me looking it up, my memory says there is a very small discrepancy although either will fit. Someone check me on this.
  6. Jan 20, 2020 at 10:12 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The beds are different between Double Cabs and Access cabs but he mentioned staying AC to AC. I'm not aware of any changes to access cab beds. Also, the shell on my truck is from an 06 Double Cab but still fits.
  7. Jan 20, 2020 at 10:14 AM
    AlbertaBeef
    Glen
    Canadian company - Range Rider out of Summerland, BC.
  8. Jan 20, 2020 at 10:24 AM
    AlbertaBeef
    Glen
    OK, so further pics - it's missing ONE piece of glass - center piece in the front. Shouldn't be too expensive. Here's some poor quality pics, LOL.
    bmf4069, jewsNbrews and Y0TA PR0 like this.
  9. Jan 20, 2020 at 11:59 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Replacement Windows are stupid expensive on truck caps, so research if you can just replace that piece of glass. If it's like most caps, it will have a serial number on it on the inside, if you can get that, you can contact the company and confirm fitment. If it's not made specifically for your truck it will be impossible to seal weather tight...so if that is important, check it out. Good luck!
  10. Jan 20, 2020 at 12:43 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    FWIW mine stays open 24/7-365 for the dog. I rarely get any water in it at all. Maybe due to aerodynamics or angle of bulge above window.
    AlbertaBeef[OP] likes this.
  11. Jan 20, 2020 at 1:10 PM
    AlbertaBeef
    Glen
    The current owner tells me it cracked and he removed it - says he never had an issue and moved one of his boxes up under it that he access frequently so he could get to it from inside the cab, LOL.
    Either way, I also have a buddy at a glass shop, so I'm sure I can make this work either with or without it ...
