Method wheels
Discussion in 'Wheels & Tires' started by scottgri, Jun 12, 2024.
  1. Jun 12, 2024 at 8:39 PM
    scottgri
    scottgri [OP] New Member
    2019 tundra limited offroad
    None
    I want to order a set of these method eighteen inch wheels when they become available. What I need to know is what the poke would look like once i get them installed on my tundra
  2. Jun 12, 2024 at 8:47 PM
    RobertD
    Robert
    DFW, Texas
    @memario1214
    These wheels should be available, they have been out for awhile now.
    If you are looking for the +40 offset, it won't be much different from stock. If your stock wheels have a +60 offset, the +40 will be .75" further out.
    Looks like you have black selected. I was looking for the bronze a while back before I changed plans and found these images. These are the 0 offset so they stick out a bit more.
    Screenshot_20231122-152459_Chrome.jpg Screenshot_20231122-152516_Chrome.jpg Screenshot_20231122-152535_Chrome.jpg
    Saltyhero13 and Ponderosa_Pine like this.
  3. Jun 12, 2024 at 8:51 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    40mm offset will be close to flush with less than 1/4" of poke. I have +25s on stock tires and they poked about 3/4 inch without flares.
  4. Jun 12, 2024 at 8:51 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    This is 315/70r17 with 50mm offset. So depending on your tire size could be the same poke or a little more/less. You likely won’t need fender flares/won’t get major rock hits.
    Saltyhero13 likes this.
  5. Jun 12, 2024 at 9:59 PM
    scottgri
    None
    Do you know if those bronze wheels are 17" or 18"
  6. Jun 12, 2024 at 10:00 PM
    RobertD
    Robert
    DFW, Texas
    The pictures are of 18", at least that is what I had searched for.
  7. Jun 12, 2024 at 10:07 PM
    RobertD
    Robert
    DFW, Texas
  8. Jun 13, 2024 at 8:52 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I'll let other folks share their fitment photos for you to peruse, but I do happen to have 4 of those wheels, in black, on the shelf. You wouldn't have to wait! :cool:
    Mater and RobertD like this.
  9. Jun 13, 2024 at 10:01 PM
    scottgri
    None
    What size wheels do you have. What are the specs
  10. Jun 13, 2024 at 10:48 PM
    blenton
    blenton New Member
    The wheel is also a 8.5" wide wheel, vs the stock 8" wide wheel, which gives an additional 1/4" of poke. So I believe that pushes the wheel out ~1" instead of .75". Not to be nit picky or anything...
    RobertD[QUOTED] likes this.
  11. Jun 14, 2024 at 6:59 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Here is a great tool for understanding tire/wheel fitment when moving to different offsets or sizes.
  12. Apr 16, 2025 at 12:13 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Did you ever end up with these wheels ?
  13. Apr 16, 2025 at 8:11 PM
    scottgri
    None
    No I ended up buying 17" black Kansei roku wheels But I ended up not even using them because I got a set of TRD rock warrior wheels. Now I need to sell the Kansei wheels so that i can buy tires for the RW WHEELS
    BillyB likes this.
