MGM Dupli Color
Discussion in '2.5 Gen Tundras (2014-2021)' started by Lossy87, May 14, 2020.
  1. May 14, 2020 at 4:19 PM
    Lossy87
    Lossy87 [OP] New Member
    Carlos
    2014 Tundra Crewmax
    Has anybody used Dupli color MGM match to do their grill surround and hood bulge and bumper ends?
  2. May 14, 2020 at 4:35 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    No but I just bought a bunch of cans to paint my son's battery powered tundra to match mine :D. Figured it's close enough but prolly not exact.
    Try paintscratch.com if you want a real match. Had good luck with themcin the past, but their more expensive
    AircoolerKirk likes this.
  3. May 14, 2020 at 4:56 PM
    Nightstalker82
    Nightstalker82 New Member
    SAN ANTONIO
    2019 MGM Tundra TSS SR5 4x4
    Hmm..tough call. Most people just do a DIY vinyl wrap or plasti dip. Not sure, if the paint will stick to the chrome very well.
    I have bumper caps now, but here's mine before that. Plasti dipped with about 5 coats of black, then about 3 coats of grahite metalizer. Came out damn close, and know one ever knew.
    Sorry can't help about the paint color. I'd say just test it out on a piece of chrome/plastic lying around the garage. That's what I did before I committed to doing the entire bumper end caps.
    TRDFerguson and panicman like this.
  4. May 14, 2020 at 4:57 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    purplenova likes this.
  5. May 15, 2020 at 5:16 AM
    Blacktooth
    Blacktooth New Member
    Raleigh, NC
    2018 Platinum
    I used it for the chrome Toyota emblem on my last Tacoma. The color was spot on. I also did the chrome grill surround on my second gen Tacoma with it as well, but it was silver mica or something. I didn't wet sand between clear coats (used Duplicolor for that too) so it wasn't buttery smooth like the factory finish, but for a few bucks I was happy with the results.
  6. May 15, 2020 at 5:31 AM
    Yoda1
    Yoda1 New Member
    2016 MGM Tundra Crewmax
    I didn't have much luck on the chrome with Dupli-Color. Had better results with Plast-Dip but I find I have to redo it after winter.
  7. May 15, 2020 at 5:49 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    How hard was it to get that cover off ?
  8. May 15, 2020 at 6:42 AM
    It just lifts off.....easy peasy.
  9. May 15, 2020 at 6:53 AM
    purplenova
    Tom
    Ohio
    I did not know that - thanks :thumbsup:
  10. May 15, 2020 at 6:55 AM
    :hattip:
  11. May 15, 2020 at 7:06 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I used Duplicolor to color match my old hood bulge and grille surround. The color was VERY close in my experience, but it did not last over the chrome - I had rock chips form super easily, and I think some bug hits may have done some of the damage. I didn't do a great job on the primer stage though, so that's part of the issue, but I just don't think the chrome will hold paint well.
    Like others have suggested, get some Anthracite Gray PlastiDip and Glossifier. Or just bite the bullet and buy color matched parts.
    Lossy87[QUOTED][OP] likes this.
  12. May 15, 2020 at 8:17 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Damn, that looks great!
  13. May 15, 2020 at 9:58 AM
    Inquiringone
    Ter
    NorCal 408
    Just pulls right off. Lift the front up about 4 inches and pull forward.
    You can look under it when you lift up to see the mounts which are spikes, the rear has U shaped clips that mate together.
    Sorry I didn’t have pictures of that
    purplenova[QUOTED] likes this.
