Michelin LTX tires 114T versus 116T
Discussion in 'Wheels & Tires' started by GNX6, Mar 18, 2018.
  1. Mar 18, 2018 at 11:34 AM
    GNX6
    GNX6 [OP] New Member
    2014 Crewmax
    TRD rear sway bar TRD oil cap (adds 25 HP, It said so online)
    I finally replaced The factory tires with the Michelin LTX that everybody seems to love. I bought the 116T as opposed to the 114T that is factory because I tow a trailer once a month. ( which coincidentally I may give back because it will end up being a buyback to the defects). So I put the 116 T on and I thought it was a lot rougher than the factory tires. Has anyone run the 114T versus the 116? I know it's not much difference in load capacity but thought it would be better with the trailer. I miss the soft ride of the factory tires but not the lousy traction. Your thoughts?
  2. Mar 18, 2018 at 11:59 AM
    It really only is a difference of 150 lbs per tire in load index rating.
    Surprised you can tell the difference.
  3. Mar 18, 2018 at 12:03 PM
    GNX6
    2014 Crewmax
    That's what I thought too! Maybe it is just a stronger sidewall tire. Typically Michelin's have a pretty mushy sidewall. Worst part is they moved on the rims so I have to re-balance at work Monday night. I had to match mount one to get the road force variation down and when I was checking pressures this morning I noticed my mark on that tire was a 3/4 turn out. Crazy!
    ColoradoTJ likes this.
  4. Mar 18, 2018 at 12:40 PM
    I can’t even tell the difference between my 121-124 load index rated tires.
    They are just stiff no matter what though.
  5. Mar 18, 2018 at 1:03 PM
    Nick T
    Nick T New Member
    Nick
    Which LTX tires were on it and which ones did you replace it with? Factory AT2 will ride rougher (louder, more road noise) then LTX M/S Defender, which rides rougher then LTX A/S (What most reccomend for smoothest quietest ride)
  6. Mar 18, 2018 at 2:42 PM
    GNX6
    2014 Crewmax
    I bought 116T LTX M/S. It originally had Bridgestone Duellers on it. Should have done LTX A/S ☹️ Didn't realize there was a difference. That's ok, I will probably get used to them. They are rated very highly so I will stick it out. Unless someone in the SF Bay area wants them with 200 miles on them, will sell for $850
  7. Mar 18, 2018 at 3:47 PM
    Nick T
    Nick T New Member
    Nick
    Bridgestone Dueller 684 II are A/S tires, you went up to a M/S tire so it would ride a little rougher. You do get the capability of mud/snow, although a dedicated snow tire will be better for winter driving and a A/T tire will be better for the mud.
    Where did you buy the tires? A lot of tire dealers will switch out tires that you are not happy with. Discount tire and Costco do this for free other might charge a small nominal fee.
    Personally, if you plan to hit snow aka Tahoe or Mammoth etc keep the M/S, its a truck ....you'll get used to the ride.
    I have michelin A/T tires, don't like the road noise but it's a small price to pay to be able to take my truck offroad.
    FYI 114t is plenty for a Tundra's tow capacity. Not gaining much with a 116T, step up to a true LT tire if capacity concerns you, those are load range E tires
  8. Mar 18, 2018 at 5:48 PM
    GNX6
    2014 Crewmax
    I get so used to just doing OE tires I never considered that factor. Doh! I bought them from Tire Rack thru my work. I can just yank them and put on craigslist I guess. I paid 850 to my front door for them. I liked the nice ride quality of the stockers but not the poor traction. The truck is 2wd so it doesn't really see mud or snow. My wife wanted a camper trailer and I bought this truck (which I love!) to haul it. I was looking at discount tire as I have a buddy that works there but even getting a deal thru him is was still $150 more. I'll stick with them for a bit, more traction is a good thing. I am going to Re-balance and mark all the tires to make sure they are mot still moving on the rims.
  9. Mar 18, 2018 at 7:20 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    So you got the defender ltx ms? Don't sell them. They're awesome and you'll soon love them. They are a little stiffer than the OE tires on the truck but they are much much better. And they are an AS tire, as far as Michelin goes you'd have to get, I think the defender premier ltx? Which are more expensive and from everythng ive read, not as good.
  10. Mar 18, 2018 at 7:32 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Should have bought them from Discount Tires eBay store. I just bought four LTX AT2 size 275/60-20 for 700.00 shipped to my door, had to buy two at a time to get 100.00 off each transaction over 400.00.
    ColoradoTJ and Pudge like this.
  11. Mar 18, 2018 at 11:41 PM
    Damn, I really need to get with the program and eBay.
    Pudge likes this.
  12. May 29, 2018 at 12:14 PM
    MikeyMTBs
    MikeyMTBs New Member
    You guys running the LT or P-rated version of this tire? My Nittos are shot and looking to replace. I’ve got LTs on now and even at 36psi, they ride rough. I do pull a 4500lb camper 5-6 times per year.
  13. May 29, 2018 at 12:43 PM
    GNX6
    2014 Crewmax
    I'm using the P rated, the LT's will ride rough as hell. I pull a 25 foot Jayco with Stabalizers it's about 4500 lbs dry plus a lot of additional stuff. It rides fine. The LTX is a tad rougher than stock but they have really good traction. I would not get lt's unless you really need it. Keep in mind too the truck is rated for towing 10,000 lbs with the stock tires...
