Mirror problem
Discussion in '1st Gen Tundras (2000-2006)' started by tundrainsc, Apr 29, 2024.
  1. Apr 29, 2024 at 2:08 PM
    tundrainsc
    tundrainsc [OP] Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    I bumped against a low hangin limb and now my mirrrw is flopping around. I have it taped in place temporarily. I think i stripped something. Any ideas? can it be repaired or need a new mirror?IMG_2053.jpg IMG_2054 (1).jpg
  2. Apr 29, 2024 at 2:27 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    There should be 3 torx heads underneath that hold that mirror in place. Most likely will need a new mirror.
  3. Apr 29, 2024 at 2:33 PM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Gorilla glue until you find a replacement.
  4. Apr 29, 2024 at 2:48 PM
    shifty` Light a match to my ass 'cause I'm blowin' up
    Or if the fastener it was using is stripped, opt for thicker-body fastener. It needs to move, so I don't feel like glues/adhesives are the answer here, unless you're injecting it into the hole, and running your fastener up into said gluehole. :rofl:
  5. Apr 29, 2024 at 2:58 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  6. Apr 29, 2024 at 3:02 PM
    Check for wires going into the mirror, some of '05+ had heated mirrors (mine does)
  7. Apr 30, 2024 at 8:42 AM
    tundrainsc
    06 Limited 4.7 2WD
    Think I will try glue. Is gorilla glue the best I never tried it.. I have tried super glue on past projects. It only works on my skin
    1lowlife likes this.
  8. Apr 30, 2024 at 8:44 AM
    tundrainsc
    06 Limited 4.7 2WD
    Thanks. only adjustment on mine
  9. Apr 30, 2024 at 8:47 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I had a speed nut mount break on my 2014 hood bulge.
    I tried several types of glue and epxoy, but nothing ever held up to the wind and vibration.
    I ended up replacing the hood bulge.
    Maybe someone has a solution that worked..:thumbsup:
    My 05 DC SR5 also had heated mirrors.
    I'd be surprised if your limited didn't...
  10. Apr 30, 2024 at 8:47 AM
    tundrainsc
    06 Limited 4.7 2WD
    Thanks Thats a good alternative Mine are white Would change both sides to get back to matching.
    1lowlife[QUOTED] likes this.
  11. Apr 30, 2024 at 9:08 AM
    You should just be able to swap the caps over. @The Black Mamba posted instructions on how to pop the caps recently, IIRC. But my brain fails me from time to time.
  12. Apr 30, 2024 at 9:10 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    shifty`[QUOTED] likes this.
  13. Apr 30, 2024 at 2:11 PM
    FishNinja
    Lee
    06DC2wd
    golf club epoxy is crazy strong. Shear strength is in the neighborhood of 4000psi
    RCwyoming and 1lowlife[QUOTED] like this.
  14. May 2, 2024 at 8:25 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    So I haven't messed with my Tundra specifically but when my sister needed a mirror on her 2014 camry I ordered one with a black cap and planned to swap over the paint matched white one only to find that the aftermarket one used totally different clip locations. Ended up just leaving it black. Just something to be aware of.
  15. May 2, 2024 at 8:31 AM
    Honestly, if it were me, I'd be hitting a JY.
    1lowlife and Pnwtundy like this.
  16. May 2, 2024 at 9:19 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Look on ebay for a used mirror.
    Pnwtundy likes this.
  17. May 2, 2024 at 10:24 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I wonder if sequoia mirrors fit on tundra?
  18. May 2, 2024 at 10:25 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    I would think they would on a DC
    1lowlife and Kimosabe[QUOTED] like this.
  19. May 19, 2024 at 7:03 PM
    tundrainsc
    06 Limited 4.7 2WD
    Can anyone recommend a replacement mirror having the snap off cap that will accept my stock cap. My stock cap is white. I would like to snap it on the replacement mirror to match my other mirror. The ones I have found online don't mention having a snap off cap
  20. May 19, 2024 at 7:05 PM
    No clue. Honestly it’s so easy to find used ones at junkyards, I’m not sure I’d buy a new one. Www.car-part.com or just use fleaBay maybe.
  21. May 19, 2024 at 7:32 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I tired buying just the caps color matched at the junk yard and they only sell the whole mirror. I saw someone mentioned they bought two new ones from rockauto for under $80. One side is about to be sale (about to be discontinued) the other is full price
  22. May 19, 2024 at 7:37 PM
    Yeah, I mean, I’d just buy a whole used mirror is what I’m saying. Two new ones for 80 though, that’s compelling. I’m sure you’d be out $50-60 per used mirror over here. Currently my Facebook Marketplace is loaded with parts trucks though, so ….
  23. May 20, 2024 at 1:42 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I believe that you want to search for "paint to match" when looking at a replacement mirror. The cap will be primed, and somehow removable to do so. However, they are aftermarket, so there's no guarantee that your cap will fit.
  24. May 20, 2024 at 10:26 AM
    CS01SR5
    CS01SR5 New Member
    2001 Tundra 4.7
    I got a set of Kool Vue mirrors off ebay for like $60 and was VERY pleased with the quality. They fit and look perfect. Mine are the SR5 chrome mirrors but I think I recall seeing an option for the color match mirrors that come without the Cap.
    Rock Auto has a different brand that comes without the color cap: More Information for TYC 5330032 (rockauto.com)
  25. May 21, 2024 at 7:11 AM
    tundrainsc
    06 Limited 4.7 2WD
    I looked at the TYC 5330032 on Rockauto. The picture shows a mirror without the cap. Triedv to call Rockauto to see if my paintede white cap will snap in on their mirror. Rockauto does not accept phone calls to discuss parts. Thinking of taking a chance and ordering their mirror. It looks the same as my oem mirror. Hope someone will respond that has experience with this TYC 5330032 mirror. Not sure if I can return if it does not workout the my cap fits
  26. May 22, 2024 at 3:16 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    RA accepts returns but they deduct shipping and a stocking fee.
