Mirror raising instead of lowering in reverse
Discussion in '2.5 Gen Tundras (2014-2021)' started by AndrewSmith, Aug 12, 2021.
  1. Aug 12, 2021 at 4:06 PM
    AndrewSmith
    AndrewSmith [OP] New Member
    Thornhill, Ontario
    2021 Sequoia Limited
    Hi
    I mostly don't use the auto-tilt-mirrors-when-reversing feature but I noticed something that's probably a defect and I should have fixed while it's still covered under warranty.
    When the mirror switch is on left or right and when I shift to reverse: the left mirror tilts down but the right mirror tilts up.
    Is it possible that I'm missing something and this behaviour is on purpose or is it clearly something the dealer has got to fix?
    Thanks in advace.
  2. Aug 12, 2021 at 4:14 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Do the mirrors adjust properly when you use the toggle? It almost sounds like they are reversed or upside down.
  3. Aug 12, 2021 at 7:21 PM
    AndrewSmith
    Thornhill, Ontario
    It works properly when I adjust it manually.
    Does that sound like a computer problem?
  4. Aug 13, 2021 at 6:38 AM
    Toondra
    Toondra New Member
    2021 Barcelona Platinum
    Stock for now
    What i noticed on my truck is that when I had my mirror select switch in Left or Right it would go down, but when I adjusted my right mirror while I was in reverse, the following time I went into reverse the right mirror would only move down as far as I had adjusted it last.
    Not saying you had done the same thig I did, but just showed me that it will replicate what you did last time.
  5. Aug 13, 2021 at 8:12 AM
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    The mirrors have a memory in the reverse/tilt down mode. With the truck in reverse, adjust the mirror that is pointing up so that it is correctly pointing down. See if that works. Then exit tilt down mode and it should be saved. If this doesn't work, then the others have it right and something is wired backwards, as unlikely as that seems.
    biebs96 and AggiePhil like this.
  6. Aug 13, 2021 at 8:12 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I haven't played with them much in my Tundra, but if they work like they do in my Lexus, and I suspect they do, then they may just need to be readjusted. Put the truck in reverse, then tilt your mirrors down where you want them while reversing. Then, the next time you go to reverse, they should remember that position.
    Saltyhero13 and NewImprovedRon like this.
  7. Aug 16, 2021 at 8:19 PM
    AndrewSmith
    Thornhill, Ontario
    Thanks everyone! It was the memory. Funny how obvious it seems now that I know the reverse position is adjustable :)
    AggiePhil, the ER kid and LS3 like this.
  8. Aug 18, 2021 at 7:13 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Read. The. Manual. lol
