Modification Recommendations
Discussion in '2.5 Gen Tundras (2014-2021)' started by Conner2020, Oct 23, 2024.
  1. Oct 23, 2024 at 8:27 PM
    Conner2020
    Conner2020 [OP] New Member
    2020 Black Tundra SR5 4x4
    Lightbars, lift, custom wheels, larger tires.
    Can anyone recommend some modifications to make to my Tundra? I have added the usual stuff: custom wheels, all-terrain tires, and light bars for every direction (night driving in the country). My truck bed has a tonneau cover, but I'm thinking of switching to an Overland-style bed rack as I have a lot of tools and other things mounted in the back. Just looking for some general cool things that I should think of adding or that the community feels are must-haves.
    Edit: I forgot I added Morimoto XB Headlights and 4 Banger Foglights.
    Links would be appreciated if you've got something.
    FrenchToasty likes this.
  2. Oct 23, 2024 at 8:41 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Transmission cooler.
    NatesNightMare likes this.
  3. Oct 23, 2024 at 9:36 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Tranny cooler, driver side grab handle, front and rear anytime camera, rock sliders and cat sheilds are must haves in my book.
    Fobroader and Mater like this.
  4. Oct 23, 2024 at 10:07 PM
    Joe333x
    Joe333x Member
    Boston
    Curious where you put the anytime camera switch if you have a platinum since there are no open spots.
  5. Oct 23, 2024 at 10:36 PM
    smokint
    smokint New Member
    Go to the 2.5 Gen Builds page…
    Click on any one of them…
    Open your wallet and get busy…
    :bananadance:
  6. Oct 24, 2024 at 3:49 AM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    1UP likes this.
  7. Oct 24, 2024 at 5:04 AM
  8. Oct 24, 2024 at 12:14 PM
    MadMaxCanon
    I have an sr5 so I had spaces above the trailer controller.
  9. Oct 24, 2024 at 12:28 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    bulldog93 likes this.
  10. Oct 24, 2024 at 12:34 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If you are on road a bunch or do any mid to heavy towing- TRD rear sway bar.
    If you are leveled and do any hauling or towing, HD version of RAS. Great way to help support the weak leafs and gain 1-1.5 lift for the rear. Much better ride than AAL or shackles.
    Desert does it seat jackers- huge improvement in comfort
    TRD Led headlights and @iHacker harness if your truck has halogens
    Whatever flavor of cat shield you like, Tundras are easy targets for CAT theft and if they are stolen your truck is out of commission a while...and the huge cost.
    All of these are not too expensive and go way beyond cost/benefit
    RealTruck and bulldog93 like this.
  11. Oct 24, 2024 at 3:45 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    https://www.tundras.com/threads/general-supercharger-thread.85513/page-602#post-3701087
    Florida AF and bulldog93 like this.
  12. Oct 24, 2024 at 11:09 PM
    MadMaxCanon
    Forgot about seat jackers, totally worth it
  13. Oct 25, 2024 at 7:26 AM
    Swimbait
    Swimbait New Member
    Banks Pedal Monster. Easy install, super noticeable right away, and relatively inexpensive (as far as mods go).
    RealTruck likes this.
  14. Oct 25, 2024 at 7:50 AM
    MadMaxCanon
    I'm not sure right now, I bought mine years ago from sparks. I'm sure you can still get the components individually from any dealer. All you really need is the handle and the panel itself, the hardware is pretty common.
    batman900[QUOTED] likes this.
  15. Oct 25, 2024 at 9:25 AM
    SD Surfer
    Bruce
    So Cal
    So are the seat jackers mostly of benefit to taller drivers?
    I'm not like, a member of the Lollipop Guild or anything, but if I fall down I don't have quite as far to the ground as most people. :rolleyes:
    Fobroader likes this.
  16. Oct 25, 2024 at 10:18 AM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    2014 Tundra SR5 Double Cab
    You can buy the pillar and grip independently from any Toyota dealership (ideally, the closer to you, the better… but shop around because different dealers will have different prices). Alternatively, you could buy them from a Japanese company, but it could be weeks to months before it’s delivered. Take a look at these 2 threads for more info: Driver’s Side Grab Handle and Drivers side grab handle UPDATE!! If you need some metric hardware, then send me a DM or just buy the SAE hardware from Lowe’s (either hardware set works).
  17. Oct 25, 2024 at 1:30 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    A bigger fuel tank, 38g OEM or 46g TranferFlo, if yours has the lil one.
  18. Oct 25, 2024 at 1:43 PM
    SD Surfer
    Bruce
    So Cal
    I put mine in the HU. :rolleyes: Also programmed the Maestro "Press n' Hold" secondary function for one of my steering wheel control buttons to bring up the front cam, or there's a "CAM" button on the HU itself.
    OP, having power and lighting in the bed comes in VERY handy.
    Cheap and easy mods that are really useful.
  19. Oct 25, 2024 at 2:47 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Just ordered both parts separately today. There is 25% and free shipping.
    https://autoparts.fredandersontoyota.com/
  20. Oct 26, 2024 at 10:52 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Katzkin leather, Dirty Deeds exhaust, and swap out all bulbs for Vleds. And if you still have factory sound, burn it and get a good system with CarPlay or android.
  21. Oct 26, 2024 at 9:02 PM
    MadMaxCanon
    Probably mostly for taller people but maim benefit is it raises the seat at the knees so your not at a decline while sitting.
