Moisture Inside Moonroof
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by evann139, Oct 31, 2020.
  1. Oct 31, 2020 at 9:35 AM
    evann139
    evann139 [OP] New Member
    Evan
    2020 Army Green Tundra TRD Pro
    On cold/wet mornings moisture builds up on my moonroof (inside the cabin).
    All windows are completely shut, there is no dampness on the floors, and climate control was NOT left on re-circulate before turning off the vehicle.
    Does anyone else have this issue? Any quick fixes?
    I have an appointment with the dealer but figured I'd see if this is a common issue. Pics below
  2. Oct 31, 2020 at 10:40 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I think it may just be condensation. Air has moisture in it. When it cools enough it will form that condensation. One thing to try- run the AC a few minutes before you turn off the truck and lock it up- like the last few minutes on the way home, even if you are running you heat- hit the AC button to dehumidify the truck interior.
  3. Oct 31, 2020 at 10:50 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    That may or may not be a problem. It means you've got a bit of moisture in the cabin. The source could be human caused, such as wet floor mats from shoes, or it could mean there's small air leak at the gasket, or possible water infiltration into the cabin.
    It's 38 and wet here right now and there is no condensation on the inside of my moonroof. Was the shade pulled shut all night, or left open? If the shade was shut, that could be the cause. Check for wet floor mats, or wet floors under the mats. Feel around the carpet for wet spots, particularly in the corners.
  4. Oct 31, 2020 at 10:51 AM
    19TurdPro
    2019 Tundra TRD Pro
    I missed where you said the floors aren't damp.
  5. Oct 31, 2020 at 11:43 AM
    evann139
    Evan
    Shade was completely shut. I'll give it a try with it open. Thanks
