Morimoto XB Headlights - High Beams not working
Discussion in 'Lighting' started by GijoeTundra14, Jul 12, 2020.
  1. Jul 12, 2020 at 1:35 PM
    GijoeTundra14
    GijoeTundra14 [OP] New Member
    Northen California
    2013 Tundra DBL Cab SR5
    Hello All
    I just purchased and installed Morimoto XB on 2013 Tundra dbl Cab. I notice that my High beams are not working when switch on. My low beams/DRL/Turn signals all work fine. Just having issue with high beams on both right and left side. Has anyone had an issue with this? I have reach out to the company and waiting for a response back from them. Other then that I love love the lights they look hot. Cant wait to get this issue fixed. Thanks for Reading
  2. Jul 12, 2020 at 2:13 PM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    If I had to guess I would say you didn't get the high beam connector seated all the way. That one was a little tricky on mine when I did the install, when I first connected it I thought I had it seated good but it was making contact on the edge of the connector which wouldn't let it go all the way in. I had to fiddle around with it for a min and then it popped right in, problem solved. I agree, they do look amazing and work even better than they look :) Hope that helps you out
    TheBeast likes this.
  3. Jul 12, 2020 at 2:20 PM
    GijoeTundra14
    Northen California
    Thanks for the tip I will try that. I will report back once completed.
    41bigdawg likes this.
  4. Jul 15, 2020 at 8:02 PM
    GijoeTundra14
    Northen California
    Hello
    Just giving an update on my high beam issue. Its now working. How i fix the issue was i reseated both high and low beam connections and power on the truck and both high and low beams came on with no further issue. I'm loving these lamps. They are a so so upgrade from the stock lights!!!! So now on to the fog lights will be tackling that project this weekend and will report back how the install went. Thanks again for everyone advice. :D
  5. Jul 15, 2020 at 8:47 PM
    41bigdawg
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Glad you got them working :) they are awesome lights!
  6. Jul 16, 2020 at 2:01 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    They are a so so upgrade from the stock lights!!!:eek2:
  7. Jul 19, 2020 at 8:52 AM
    GijoeTundra14
    Northen California
    Hello All
    Just finished installing the Morimoto XB Fog lights. That went pretty easy. The tough part is taken out the original fog light. if you never done it. Once its out you just have to pop out the lamp from the plastic housing it sit in and then putting the new one in is a snap. and then popping the plastic housing back into the fog light cut out of the truck and then putting all the fasteners that hold the unit to the truck and then the two remaining screws. Hit me up if you have questions.
  8. Jul 19, 2020 at 9:06 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Would you say this was a good investment? Since you said it was "so, so" from stock. Doesnt sound like it was worth the price tag?
  9. Jul 19, 2020 at 9:15 AM
    GijoeTundra14
    Northen California
    The reason i said so so. Cause I was bum that I had issue with my brights. That came down to me installing them, I was in a hurry and it was hot outside so I rush threw the install. If I had of taken my time they would have work correctly the first time. They are definitely a whole lot brighter at night, more clearer as far seeing way down the road at where your driving. So yes its good investment. There are other brands on the market that are a little less money. I dont think they are as plug in play as these are. Would i buy them again. Yes yes. also the price included the fog lights so I didn't pay extra for the fog lights. Its a special they are having on the website. Let me know if you have other questions.
  10. Jul 19, 2020 at 9:22 AM
    BrandonL812
    Brandon
    Gotcha. That makes more sense. The real concern was whether it was brighter for night time, and you've now answered that. Sounds like a good purchased after all.
  11. Jul 19, 2020 at 9:25 AM
    GijoeTundra14
    Northen California
    Hey
    Even the day time running lights are freaking bright. Its like having your headlights on during the day and its just the DRL. I will take pics and post them.
    BrandonL812 likes this.
  12. Jul 27, 2020 at 5:29 PM
    07tundraSILVER
    07tundraSILVER New Member
    hello i have the same issue with my high beams i got one to work the the one does not seam like it wants to click in any advise or tips
  13. Jul 27, 2020 at 5:40 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Get some dielectric grease and try to reconnect.
  14. Jul 27, 2020 at 5:42 PM
    TheBeast The Beach
    the high beams on the Morimotos are so much brighter than oem Toyota.
    GijoeTundra14[OP] likes this.
  15. Jul 27, 2020 at 6:12 PM
    GijoeTundra14
    Northen California
    I was just going to say the same thing regarding the grease. What I did was unplug it and reseat it twice and it finally click this the High Beams working. Oh and it will click.
    4x4WarriorOfRocks likes this.
  16. Jul 29, 2020 at 1:07 PM
    mrn320
    mrn320 New Member
    2012 Black Tundra TRD Rock Warrior
    • 5.7-liter DOHC i-Force V8 381 horsepower and 401 lb.-ft. torque with TRD oil and radiator cap • Nitto Trail Grappler M/T LT305/55R20 performance tires • KMC Wheels XD801 Crank 20” cast aluminum wheels • ReadyLIFT 2.5” Front and 1" Leveling Kit • Bull Bar • Hella Halogen Headlights • Custom Window Tinting • WeatherTech Side Window Deflectors • Custom Notre Dame Trailer Hitch • Toyota TRD rear sway bar • Tonneau soft cover • Toytoa bedliner • Toyota Tundra Smoke Tail Light and Bed Light
    I thought I saw a rumor that Morimoto was going to redesign the XB Headlamps to address some field issues. I'd like to buy the Headlamps and Fog lamps as I have been upgrading my front end. Anyone know if that is true or not?
    @GijoeTundra14 where did you buy the lamps and any discount codes?
  17. Jul 29, 2020 at 2:18 PM
    TheBeast The Beach
    yes I believe a Version 2 is coming out. Not sure when. Minor changes apparently.
    @Headlight Revolution posted about it.
  18. Jul 29, 2020 at 2:28 PM
    mrn320
    mrn320 New Member
    tundraatx likes this.
  19. Dec 2, 2023 at 11:59 AM
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    I'm having the same issue. Gonna try to reseat the connectors with some dielectric grease. Mine didn't seem to click in as well either. Thanks for the post.
  20. Dec 28, 2023 at 1:16 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I had the same/similar issue. No high beams. I reseated every connection after an ample dose of dielectric grease, and seated until I heard and felt solid clicks on everything. Now every aspect of DRL, low beam, high beam, and fogs work as expected/intended. I am VERY pleased.
  21. Dec 28, 2023 at 7:11 PM
    4x4WarriorOfRocks
    Same here! Just had to get them seated nice and tight.
  22. Dec 6, 2024 at 5:53 AM
    bobodog96
    bobodog96 New Member
    Phoenix
    '05 Tundra V8 - Crew Cab TRD - Blue
    - Running boards - Replaced interior & exterior lights with LED bulbs - Upgraded tinted windows - Installed front and rear cameras - New set Big O Big Foot A/T on original rims with lock nuts - New rotors & TRD brakes - New OEM upper and lower ball joints - New Bilstein 5100 all the way around - New fan blower - Repaired broken rear sliding window - Replaced manual front seats with electrical/heated seats while using the original factory cloth covers - New starter - Replaced 1 catalytic converter - Replaced cell battery with high-end gel battery - Replaced chipped/damaged window sil rubber bottom of all windows - Tailgate security lock installed
    Hello All,
    Just purchased and installed the Morimoto H4 2Stroke 4.0 LED Lights.
    Love the pattern and they are better than my old "Amazon" purchased a few years ago.
    Yes they lasted but one of the hex setting screws apparently backed out and was lost so the aim got distorted.
    Anyway, I also purchased the anti-flicker harnesses to go along with the bulbs.
    After install, high beams not working.
    I did set the plugs into each other well (so I think) and electrical taped the connections to help keep moisture out.
    There was old dielectric grease in the harness female plug, but I didn't add new grease.
    Reading your posts, I will try reconnect everything, add new dielectric grease AND listen for a "click", which for sure was not heard last night.
    Will revert back with feedback.
