MotiveX Filter Wrench Stuck on Plastic Canister
Discussion in '2.5 Gen Tundras (2014-2021)' started by NCSkeeter, Dec 18, 2021.
  1. Dec 18, 2021 at 7:54 AM
    NCSkeeter
    NCSkeeter [OP] New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    The title says it all. This is the first oil change after the free dealer changes. The filter was really tight, but I was able to get it off with my 1/2” ratchet. Problem is now the canister is stuck in the wrench. I cannot wiggle it off. Lightly tapping didn’t help either. It’s sitting in the freezer now to see if that will help.
    Any other ideas?
  2. Dec 18, 2021 at 7:57 AM
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    Thread the canister back on and wiggle the wrench back and forth. Happened to me as well.
    Cock-A-Doddle-Do and bfunke like this.
  3. Dec 18, 2021 at 7:58 AM
    NCSkeeter
    Good idea. I tried the same and it is stuck good.
  4. Dec 18, 2021 at 7:59 AM
    Spray some WD-40 on it and wait a few minutes then thread it back on and try to tap it off lightly.
  5. Dec 18, 2021 at 8:02 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Take a bolt that is bigger enough to fit through the hole where you attached the ratchet. And GENTLY tap on the floor or with a hammer. Also try to lubricate in between the plastic and metal. A little soapy water. Make sure you completely wipe off whatever you use before reinstalling.
  6. Dec 18, 2021 at 9:12 AM
    NCSkeeter
    WD-40 and putting it back on did the trick! I did notice the canister rotated a bit relative to the tool. I think it had slipped a bit.
    Glad to have the job done, but missing my old Taco today.
  7. Dec 18, 2021 at 9:13 AM
    NCSkeeter
    This would have pushed on the drain valve mechanism I believe, which I was trying to avoid.
  8. Dec 18, 2021 at 9:30 AM
    SteyrM40A1
    SteyrM40A1 New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    Those tools are designed to only go on one way. I got mine stuck by not having it lined up correctly with the canister.
  9. Dec 18, 2021 at 9:47 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    I only suggested it because I have done it in the past with my wife’s RAV4 and her Highlander. It usually touched the outer ring. Glad everything worked out for you.
  10. Dec 18, 2021 at 10:01 AM
    :hattip:
  11. Dec 18, 2021 at 10:06 AM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Might try a heat gun and see if that helps loosen it up some. Maybe it’s freezing cold. Happened to me last year, left the stuck oil filter wrench on and just drove it. Few months later I popped it off with a tap of the hammer
  12. Dec 18, 2021 at 10:07 AM
    NCSkeeter
    Definitely not freezing cold. 70 degrees in NC today. :amen:
  13. Dec 18, 2021 at 11:00 AM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    ^^This^^
  14. Dec 18, 2021 at 11:08 AM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    If its the original plastic one, just replace it with the aluminum upgrade.
    JLS in WA and AGSport like this.
