Mower Blade Pulley broke 3 times!
Discussion in 'Outdoors' started by Fotnot, Apr 13, 2020.
  1. Apr 13, 2020 at 9:44 AM
    Fotnot
    Fotnot [OP] SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Any insight on this would be appreciated. I have a Kubota Z125 54" 26HP ztr. It has been great for the past 4 years. Late last year, I had a blade pulley on the "passenger" side(which is furthest away from spring tensioner) shatter. The middle part of the pulley that mounts to the shaft broke away and the outside of the pulley. I replaced it the first time about 6 months ago after the mowing season ended. This season I started up again and after about 3 cuts it broke again. Then, 2 cutting hours later(or less) it broke again! My buddy had done a lawn business for a few years and said he'd never seen that. My brother worked at a Kubota dealer and said that it's not common, but some have been replaced. Also, I checked for campaigns on it and there are none for my model. I've been really happy with the mower, but surprised as hell this is happening. I have not replaced bearings since they are sealed and when I rotate them, they are extremely smooth and no resistance or noise. Never hit anything with it and never washed the deck off while warm/hot. Always let cool for a couple hours or waited until next day to make sure I wouldn't spray cold water on a hot bearing/spindle/etc. and cause any expansion/contraction issues from extreme temp changes. I always lifted up the plastic guard that covered them to make sure I got dirt and grass out. After it broke the first time, I just kept it off to help eliminate that problem, but obviously it's not helping. Pic below to show how it broke the last time. Thanks in advance to anyone that can help.
  2. Apr 13, 2020 at 10:09 AM
    Wow..this is weird.
    Replacing with OEM parts I'm guessing.
    Shaft not bent?
    Fotnot[OP] likes this.
  3. Apr 13, 2020 at 10:13 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I agree with TJ, there's an alignment issue maybe, deck position, or wobble in the pulleys.
  4. Apr 13, 2020 at 10:14 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    verified shaft not bent with another brand new shaft by rolling the 2 against the each other and looking for any gaps and nothing. And yes...replacing with OEM parts as of now. About to go and get my buddy to take the one that just broke and weld it stronger. The place it broke is just a crack now, but I'm almost positive it will be broken by next use. He's welded them before when he owned his lawn business and it helped and never had issues again...it was a different type of pulley/brand, but still on a blade pulley from a ztr.
  5. Apr 13, 2020 at 10:20 AM
    Hopefully that fixes your issues. Having down time on a mower sucks, especially where the grass grows fast.
  6. Apr 13, 2020 at 10:28 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    luckily i cut it about a half inch shorter than normally would for anticipation for rain. so I got some time before NEEDING another cut. found out just now that place i bought it from will replace under 30 day warranty(bought it 3 weeks ago).
  7. Apr 24, 2020 at 7:45 PM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    I’m sure you’ve already thought about this but have you checked torque on it? Also belt size to make sure it’s not pulling and putting stress in it? I rarely clean my deck topside and pulley area and I live in a grassy and sandy area where buildup is going to happen and have never seen that happen yet.
    what about yard pattern? Does it struggle in certain spots but not others where it might stress the blades which might stress the shaft at certain spots in the yard?
  8. Apr 24, 2020 at 7:53 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    How about the blade it self? Off balanced at all or chipped?
  9. Apr 25, 2020 at 11:17 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    so I have checked the belts and blades. both seem fine. I found one of the idler pulley's had some wiggle/slack to it, so I went ahead and changed that out. it's right next to the blade pulley that messed up, so i'm hoping that's it. also changed out one of the bearings on the blade pulley hoping it will help since it seemed like it wasn't spinning as easily as it should and had a couple feels of a bad ball in it.(the bearings on these are sealed bearings). Mowed yesterday and it didn't seem to act up or anything....time will tell.
  10. Apr 25, 2020 at 12:07 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Swap it’s blade with one on opposite side to see if problem stays. Also check or just replace the deck belt. If a belt gets too hot or stuck for a second, it will become mis-shaped and cause a nasty vibration only seen when deck is engaged.
  11. Apr 25, 2020 at 1:28 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    @Fotnot maybe the bearing is binding when it gets hot. Maybe check the balance the blades too. Seems to me that the shaft would have to come to a quick stop for that to snap, or vibrate enough to weaken it.
    Edit: Sorry just read you changed these!
  12. May 11, 2020 at 7:02 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I would assume it is being fatigued from flexing due to an alignment issue. Check to make sure it is at the same height off the spindle housing as the other pulleys. Also check spindle for excessive endplay.
  13. May 11, 2020 at 11:08 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    So I ended up changing out an idle pulley next to it and have cut the grass once since then and haven't had an issue. When I pulled the idle pulley, it had a slight wiggle in the integrated bearing, so I'm hoping that's the fix. Time will tell. All the other pulleys seemed fine
