MPG Trip Summary
Discussion in '3rd Gen Tundras (2022+)' started by Brian89, Apr 8, 2024.
  1. Apr 8, 2024 at 6:31 PM
    Brian89
    Brian89 [OP] New Member
    I have looked in the manual but have been unable to figure out how to get the trip summary to consistently show my last drive mpg. Thanks in advance if someone can help me figure this out.
    Thanks
    B
  2. Apr 8, 2024 at 6:41 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Mine tells me every time I turn the truck off.
    Right after it tells me to check the backseat and if I left a window open.
    Don’t open any of the doors though, it won’t show you if your passenger jumps out once stopped.
  3. Apr 8, 2024 at 10:13 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    That's my wife. She's usually out before it's even in park.
  4. Apr 9, 2024 at 3:22 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    It is in the settings for Eco on the multi-information Display located on the left side of the instrument cluster.
  5. Apr 9, 2024 at 3:23 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    These notifications can be disabled if you want.
    Timmy23[QUOTED] likes this.
  6. Apr 12, 2024 at 7:38 AM
    Brian89
    Finally figured out why I kept getting the backseat alert and not the summary. I usually put my work bag in the back on the floorboard before leaving for work which is causing this alert. Found this on the Toyota Newsroom page for 2024 models:
    For 2024, all Tundra models are equipped with Toyota’s Rear Seat Reminder. This feature detects whether a rear door was opened within 10 minutes of the vehicle being turned on, or at any time after the vehicle has been turned on. If so, it flashes a reminder message in the instrument cluster after the engine is turned off, accompanied by multitone chimes.
  7. Apr 12, 2024 at 8:11 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    You can turn that off on your dashboard. Go into the gear icon, hold Vehicle settings, and it pops up
    Sixty9Four20 and Mattedfred like this.
  8. Apr 12, 2024 at 11:25 AM
    Brian89
    Thanks! I guess I didn't read the manual very well. I missed the entire section (8-2. Customization) and didn't realize the reminders could change there.
