Muffler size
Discussion in 'Performance and Tuning' started by TundraOwner2019, Mar 13, 2024.
  1. Mar 13, 2024 at 3:50 AM
    TundraOwner2019
    TundraOwner2019 [OP] New Member
    Brennon
    2019 Tundra Crewmax Platinum
    Wanting to get a new muffler installed on my 2019 plat… will be a whole lot cheaper if I just purchase myself and have it welded on. I’m looking at the Magnaflow dual in single out 14” body. Just planning to do a muffler replacement at this time, everything else will stay the same. So, when shopping for a muffler, what size do I need to make sure the inlet / outlet measurements are? Pictured is the one I’m wanting.
  2. Mar 13, 2024 at 3:53 AM
    Just get a system from @dirtydeeds. You will be much happier.
    dirtydeeds likes this.
  3. Mar 13, 2024 at 5:01 AM
    centex
    centex New Member
    Mine was 2.25” in and 3” out which was factory size on mine. I did the same thing and added an x-pipe as well. Cost me a $186 in parts and $150 to have it all welded in.
    You'll more than likely want to buy the resonator from dirtydeeds which is another $250. At least I did because the drone was insane but I also chalk that up to my rear cats being removed by the previous owner.
    All in, $586.
    Saltyhero13 likes this.
  4. Mar 13, 2024 at 5:13 AM
    TundraOwner2019
    Brennon
    Yeah I’m gonna keep the rear cats on and keep the exhaust stock other than the muffler. I appreciate the info
  5. Mar 13, 2024 at 6:08 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    That muffler will likely leave you disappointed after all costs to cobble it together. I have run Magnaflows on several vehicles, they drone. I didnt mind that on muclecars but on a daily driver it gets old on long trips. You wont see a performance improvement either. If you want a nice sound and actual HP and torque improvement look into the offerings from @dirtydeeds.
    dirtydeeds and Saltyhero13 like this.
  6. Mar 13, 2024 at 6:30 AM
    TundraOwner2019
    Brennon
    Not looking for performance really, just a little aggression. I had this same setup on my 6.2 Chevy and had no drone and it sounded good. From what I’ve been told, chevys drone worse than these Toyotas so I feel pretty confident there will be no drone
  7. Mar 13, 2024 at 6:39 AM
    centex
    centex New Member
    I had the exact opposite experience. I run Borla pro xs mufflers and on my last two chevys there was no drone but on the tundra it was ringing my ears. The dd resonator solved it instantly.
  8. Mar 18, 2024 at 2:53 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    This is not true. Tundras drone worse for sure.
    if drone is a concern you have the option to run our resonator. It works no matter what.
    I guess the big question is: why spend $ to lose low end torque, horsepower and fuel economy just for sound?
    you can have the above performance AND the sound you want.
    Tundras are different than the other trucks you’ve had. We are just trying to help you not make the same mistake tons of people already have made.
  9. Mar 18, 2024 at 3:19 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The tundra drones way worse than the 5.3 silverado i had
