Multiple dash lights suddenly came on my 2012
Discussion in '2nd Gen Tundras (2007-2013)' started by julskeall, Jan 20, 2019.
  1. Jan 20, 2019 at 8:07 AM
    julskeall
    julskeall [OP] New Member
    Good morning
    needing a little help i just bought a Toyota tundra yesterday my track control light ,abs parking brake and i cant remember what else at least 4 others came on the dash ..my radio and heater turned off dash and time display started flashing .when i turned the headlights off the truck turned off..for the remainder of the 1 hour drive home the truck kept shutting off .. PLs Help
    Pinay likes this.
  2. Jan 20, 2019 at 8:11 AM
    Welcome
    What lights are currently on?
  3. Jan 20, 2019 at 8:12 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  4. Jan 20, 2019 at 8:16 AM
    julskeall
    abs,parking brake ,traction control ,4hi, 4 lo,low washer fluid,slip indicator,vsc off
  5. Jan 20, 2019 at 8:18 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  6. Jan 20, 2019 at 8:18 AM
    TXMiamiFan
    Jose
    Savage
  7. Jan 20, 2019 at 8:18 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Get to the dealer ASAP! If cant drive call the dealer and have them come pick it up.
    Black Wolf likes this.
  8. Jan 20, 2019 at 8:19 AM
    What year Tundra, mileage, etc?
    This can help you with the troubleshooting.
    Welcome to the site.
    jeremyd likes this.
  9. Jan 20, 2019 at 8:20 AM
    julskeall
    2012 145000km .going to call dealership first thing in the morning
  10. Jan 20, 2019 at 8:26 AM
    Is there a parts store close to you and can scan codes? This will tell you what’s wrong for free.
    Even purchasing a code scanner is always a good investment.
  11. Jan 20, 2019 at 8:29 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I’d start with a battery/alternator check.
  12. Jan 20, 2019 at 9:50 AM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Northeast Connecticut. Did you get a warranty with the truck
  13. Jan 20, 2019 at 10:02 AM
    Welcome from NY.
    I believe a bad battery can cause this.
    Boosted4runner likes this.
  14. Jan 20, 2019 at 1:10 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  15. Jan 20, 2019 at 1:15 PM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio. Hope you get everything sorted out.
  16. Jan 20, 2019 at 5:28 PM
    Welcome from Ohio!
  17. Jan 21, 2019 at 11:01 AM
    Welcome from Texas
  18. Jan 21, 2019 at 11:07 AM
    Itchyjuffowup85
    Itchyjuffowup85 New Member
    2014 Black TRD 4X4 5.7L V8
    If you're still having this issue. Start with checking you batt cables, if they are good, remove the neg cable for 30 min or so. Put it back on and start the truck.
    I had a similar issue like this and it was a loose cable. Just a thought hope you get it sorted though.
  19. Jan 21, 2019 at 1:34 PM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    welcome from NC
  20. Jan 21, 2019 at 1:37 PM
    :popcorn:Welcome from CO...
  21. Jan 22, 2019 at 6:42 AM
    craigerman
    craigerman New Member
    Craig
    2007 Silver Tundra CrewMax Limited
    3" lift, matching topper
    Mine has done the same thing. Educated guess is bad battery or a loose connection coming off the battery. If the connection even comes loose for a second while the truck is running, it can throw some crazy blinking lights and codes at you. First time it happened to me was when I was in an automatic car wash, and I immediately thought something shorted out. I turned the key off then started it back up and everything was fine. Got home and on a whim I threw my charger on my battery, and it indicated I was down to 55% charge. Charged it up full and its been fine since. I think I have a bad cell on the battery, but have been throwing it on the charger once a week to keep it maintained. Gonna eventually have to fork out the dough for a new battery though.
  22. Jan 22, 2019 at 7:28 AM
    DaHawk
    DaHawk New Member
    DH
    Kentucky
    1020 Black Tundra
    6 inch lift 20 inch custom wheels
    I had 3 dash lights light up on mine. Sometimes they were blinking. Took to dealership. A squirrel had gotten in engine compartment and chewed through the main wiring harness on driver side that goes back into the dash. Damn thing went through the plastic housing and chewed through some of the wires. Not a cheap fix. Have them check your wiring.
