Multiple Issues with 2017 TRD Pro with only 36k miles HELP
Discussion in '2.5 Gen Tundras (2014-2021)' started by kaner777, May 13, 2024.
  1. May 13, 2024 at 8:59 AM
    kaner777
    kaner777 [OP] New Member
    Ryan
    2017 Toyota Tundra TRD Pro
    Started experiencing issues with my 2017 Tundra TRD Pro in the last while.
    tldr: Neutral safety switch bad, check engine/traction control off, AC blowing hot.
    Was told my Neutral Safety Switch was bad and I just missed the warranty date so decided not to replace it as it isnt always an issue. Recently I've been having my check engine light come on and traction control turning off. Took the suggestion I read about disconnecting battery, waiting and then reconnecting and has worked but it has came back 2-3 times and goes away the next day. Now I am having AC Issues. My climate might have me have the heat on full in the AM and then max AC in the PM. When I turned on the AC today(It worked fine last week) it was coming out hot, not warm but very hot.
    I am wondering if anyone has an ideas what this could be, I am thinking it could be electrical but I havent had my AC checked as it is only a new issue.
  2. May 13, 2024 at 9:04 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    What codes are the CEL?
  3. May 13, 2024 at 10:00 AM
    biebs96
    PA
    Is it the original battery?
  4. May 13, 2024 at 10:02 AM
    kaner777
    Ryan
    It hasn't stayed on long enough for me to have it checked. The traction control turns off when the CEL comes on is all I know
  5. May 13, 2024 at 10:03 AM
    kaner777
    Ryan
    I bought it 3 years ago and I haven't changed it. Can't speak for if it was changed before
  6. May 13, 2024 at 10:07 AM
    AZBoatHauler
    So.Arizona
    Should have a manufactured date on it. I’d start there.
  7. May 13, 2024 at 10:08 AM
    Your neutral safety switch should be replaced if they recommended that. It's involved in numerous systems (including the traction control) and literally says safety in the name. They're like $150. The AC could be a blend door issue.
