Musty smell after the car wash
Discussion in '3rd Gen Tundras (2022+)' started by DexterL, Jun 17, 2023.
  1. Jun 17, 2023 at 8:50 PM
    DexterL
    DexterL [OP] New Member
    21 lunar rock TRD pro Seqouia
    Hey all, have posted this before but no luck. 1 out of 4 times I go through the car wash my truck stinks all day, then it goes away. Cannot pin point the smell, but have felt around all the usual spots and nada for wetness. All my aftermarket work has been silicone sealed in the grommets and no wetness in there. Zero sunroof leaks and no wet carpet to be found. Any ideas?
  2. Jun 17, 2023 at 8:54 PM
    Have u been running ur AC a lot? If so, drive with the fan on, and AC off for a bit to dry it out and see if it helps
  3. Jun 17, 2023 at 9:22 PM
    DexterL
    hmm I’ll give that a shot. What’s weird though is it’s always after the car wash…
    T-Rex266[QUOTED] likes this.
  4. Jun 17, 2023 at 11:56 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    Question for ya,any chance the car wash place is a tree hugging earth crunching 100% water recycling facility?
    There is a place down my way that recycles the car wash water and after rolling out your vehicle looks clean but smells like a stagnant whore after a long weekend.
    SR5BART, SC4333, mayan and 8 others like this.
  5. Jun 18, 2023 at 3:22 AM
    redneck47441
    redneck47441 New Member
    2018 Tundra
    Try changing your cabin filter. I find depending on where you park it needs changed more frequently than suggested in the manual. I’ve always changed mine as soon as the ac smells a little off.
    DexterL[QUOTED][OP] likes this.
  6. Jun 18, 2023 at 7:19 AM
    Texan-1794
    Texan-1794 New Member
    2023 Tundra 1794
    2023 Blueprint Tundra 1794 - Stock to the Bone!
    can’t help but wonder how you recognized that smell. :monocle:
  7. Jun 18, 2023 at 7:33 AM
    DexterL
    our place recycled the water, probably what’s causing it!
  8. Jun 18, 2023 at 8:41 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    This happened one time with my wife when she got done washing her car at one of those spray-n-wash bays….. I told her to shut all doors, trunk and make sure windows aren’t completely rolled down next time…. Problem solved
    pwpblue likes this.
  9. Jun 19, 2023 at 7:46 AM
    DexterL
    definitely not the case
  10. Jun 19, 2023 at 7:59 AM
    SD Surfer
    Bruce
    So Cal
    My 4Runner years ago had a similar issue once... Sunroof wasn't leaking but the sunroof drain tube was partially clogged, and water was coming into the passenger footwell.
    It took awhile to figure it out 'cuz it seemed to come from the backside of the carpet so it wasn't always obviously soaked.
  11. Jun 19, 2023 at 8:02 AM
    DexterL
    I’m going to check my drains tonight, always have a puddle below them after wards but worth double checking
  12. Jun 19, 2023 at 8:04 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Check under the carpet. Had a guy I sold a car to reach out to me to say his AC or sunroof has been draining into the cab under the carpet and caused mold.
  13. Jun 19, 2023 at 8:20 AM
    SD Surfer
    Bruce
    So Cal
    Yeah, in my case the tube wasn't completely clogged, just restricted enough to back up.
    Good luck, I hope you find the source. This kinda stuff can be frustrating, and that musty smell is nasty.
  14. Jun 20, 2023 at 1:03 PM
    DexterL
    pulled em up yesterday and nothing underneath. Swapping filters tomorrow and pulling a bunch of interior parts off and taking it through the car wash again and will feel around for wet spots
  15. Jun 21, 2023 at 7:12 AM
    DexterL
    Alright so heading into the dealer on Thursday. Yesterday I checked the drain tubes again and all was clear, but the weed whacker cord wouldn’t come out through the drain hole. Poured some water down the drain and noticed that it all comes out through the body of the truck, not the drain. Nothing is wet inside by the drains or the carpet, dealer thinks the tube either got disconnected or wasn’t installed properly.
    mayan, Henry1jg and Mattedfred like this.
  16. Jun 21, 2023 at 8:15 AM
    SD Surfer
    Bruce
    So Cal
    Sounds like progress! :dancingbacon::thumbsup:
  17. Jun 21, 2023 at 10:08 AM
    Breathing Borla
    Northern Illinois
    Can you post a pic of these drain tubes? I’m curious and want to check mine
    iiawah808 likes this.
  18. Jun 21, 2023 at 3:01 PM
    DexterL
    Passenger side, behind the wheel- black tube coming down at an angle
  19. Jun 21, 2023 at 3:05 PM
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Reminds me of the valet BO episode on Seinfeld
    Hella Krusty and Mattedfred like this.
  20. Jun 21, 2023 at 3:46 PM
    DexterL
    Best show ever
  21. Jun 22, 2023 at 12:25 PM
    DexterL
    Can anyone verify where the sunroof drains are supposed to drain from? My dealer is saying mine are functioning correctly... having a tough time figuring out how leaking through the truck body is correct, when there is a vent tube in the same area
  22. Feb 23, 2024 at 8:14 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Following up on this. I’m getting the musty smell smell as well…
  23. Feb 23, 2024 at 8:26 PM
    Hella Krusty
    Hella Krusty New Member
    Give it a week and 50 will have the musty smell and another 100 will blame the hybrid motor. Like a rock rolling down a hill
  24. Feb 24, 2024 at 6:15 AM
    DexterL
    Sold the truck and went back to the old reliable 5.7, no stank, no wind noise, no problems
  25. Feb 24, 2024 at 7:05 PM
    Yota802
    Yota802 New Member
    So is the consensus a drain tube in the front passenger wheel well?
  26. Feb 25, 2024 at 5:48 AM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Do you wash your floor mats 1 of every 4 washes? You gotta let those dry before throwing them back in there. ;)
  27. Feb 25, 2024 at 6:01 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    Consider switching the HVAC to RECIRC while passing through the wash.
  28. Feb 25, 2024 at 7:09 AM
    Markus
    Mark
    Boring, MO
    A few
    I'd say you have a leak as well
