My WTF last 24hrs....all warnings lights flashing
Discussion in '2.5 Gen Tundras (2014-2021)' started by Vito117, Feb 5, 2022.
  1. Feb 5, 2022 at 7:50 AM
    Vito117
    Vito117 [OP] New Member
    ANTONIO V.
    IOWA & ILLINOIS
    2019 TUNDRA CREW MAX-- LIMITED- TRD PRO
    So driving home last night had a major ass blowout on left rear. Popped on the spare made it home. Of course the TPMS was voided out as I drove. No biggie, right?
    Got up this morning to head down to the tire place to replace the spare with a new tire.
    Truck starts....and every damn warning, bell, whistle, light was going off on dash.
    Checked usual: doors, gas caps, hood, no wiring loose under hood...etc.
    Just had a pretty thorough 100K maint done- plugs...etc- 10,000 miles back.
    Turned off truck....let sit for 30 mins. Same thing. In park and when driving along.
    Even after the new tire was put on I checked and the TPMS was working - all tires showed the PSI. Yet these warning lights still going ape shit crazy as I drove away.
    Truck drives fine. Any ideas?
  2. Feb 5, 2022 at 8:00 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Did the blowout take out one of your rear sonar sensors?
    Tundra805 and AZBoatHauler like this.
  3. Feb 5, 2022 at 8:02 AM
    Vito117
    ANTONIO V.
    IOWA & ILLINOIS
    Good question. I'll shimmy under there to inspect all 4
    Thanks
  4. Feb 5, 2022 at 8:06 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have read the sensors are not fond of cold, it says 11 degrees, that's pretty cold.
  5. Feb 5, 2022 at 8:08 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Sounds like a broken abs or speed sensor wire/plug.
  6. Feb 5, 2022 at 8:19 AM
    Vito117
    ANTONIO V.
    IOWA & ILLINOIS
    Rear parking sensors are intact as is the wiring/connections. No signs of any foreign object slamming up underneath.
    This truck has driven in very cold temps ( Minus teens) all winter with no issues.
    Also checked the ABS sensor and plug connect under wheel that was blown and all seems OK.
  7. Feb 5, 2022 at 8:38 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I had something similar on my 4Runner and it turned out to be worn alternator brushes.
  8. Feb 5, 2022 at 8:45 AM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Scan it? Check the codes. If nothing too crazy unhook the battery and let it sit for 15 and reconnect.
  9. Feb 5, 2022 at 8:47 AM
    2mchfun
    Simple coincidence..battery might be going South. 2019 very likely.
  10. Feb 5, 2022 at 8:52 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    a1_848404D.jpg 00C4E613-1DC3-403D-AD29-5203564762EDC3946B08-3802-446F-B170-0C4E2797417E.jpg Could be a rear wheel sensor is out. Might sit on the hub right next to the brakes. Parts 89546 or 89545
    Tundra805 likes this.
  11. Feb 5, 2022 at 9:01 AM
    Mobeyk
    Mobeyk New Member
  12. Feb 5, 2022 at 9:07 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    My bet is on the battery; same thing happened to me (minus the tire blowout) a few weeks ago. Hopefully the tire issue is a coincidence and a new battery will fix your problems
    1eyedclyde likes this.
  13. Feb 5, 2022 at 9:30 AM
    Vito117
    ANTONIO V.
    IOWA & ILLINOIS
    I'll get battery checked.
    A barely 2 year old battery though? WTF ?
    avssuc likes this.
  14. Feb 5, 2022 at 9:33 AM
    shawn474
    MoCo, Maryland
    Yeah my dash lit up like a Christmas tree. There was nothing else that indicated low battery - truck started fine. I cleaned the terminals (there was a lot of corrosion on the battery posts). That helped for a few weeks. Then it happened again and I changed the battery to an optima yellow top. No problems since. And this seems to be a common issue with the stick batteries.
    avssuc likes this.
  15. Feb 5, 2022 at 9:35 AM
    Mobeyk
    Mobeyk New Member
    well, his issue came after the tire blew. Seems logical that debris or tire chunks from blowing hit the rear wheel speed sensor or ripped a wire. Id check there in addition to the battery. Damage is not always visible right away. Sensor might be out.
    shawn474[QUOTED] likes this.
  16. Feb 5, 2022 at 9:58 AM
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    Mine died at less than 17,700 miles and 2 year 10 month.
    avssuc likes this.
  17. Feb 5, 2022 at 10:02 AM
    shawn474
    MoCo, Maryland
    i agree
  18. Feb 6, 2022 at 7:27 PM
    bfunke
    South Carolina
    My battery just died this weekend. Started fine in the morning. Parked it a couple hours and went to start nothing. Only wierd electrical indications I was getting my keyhead transmitter would sometimes not lock the car until lights went out. Got a jump and it wouldn't keep running if headlights on. Limped to parts store with everything shut off. Hoped to get an X2 but was told had to order and would take 1-2 weeks so I went with a Group 24F AGM instead. Battery clamp on order from @Coupe. Picked up a GM diode for $4 at O'Reilly. Should be GTG.
  19. Feb 7, 2022 at 4:23 AM
    BlacknWhite23
    BlacknWhite23 New Member
    2021 Black TRD Off Road
    I just had to put a new battery my daughters '21 Hyndai Kona. Not even 8k on the clock. Batteries suck. Let us know what you find.
    Mr Badwrench likes this.
  20. Feb 7, 2022 at 4:45 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I concur…
    Your symptoms are extremely similar to what my 2017 4Runner did OP when the wheel speed sensor wire broke. No traction control, no 4x4, no ABS… My was broke during a simply tire change and a blowout could easily break that harness.
  21. Feb 8, 2022 at 8:27 AM
    Vito117
    ANTONIO V.
    IOWA & ILLINOIS
    Well, this is the proverbial conundrum. Battery and alternator are OK .
    Yesterday I took it to my local Toyota service center, and they were yammering on about how I may need to have a body shop replace the parking sonars on rear bumpers as they have been damaged. WTF? Wrong-- no damage to these and wiring connections are spot on.
    I figured truck should be under some warranty thus reason I went to dealership.
    I mentioned the ABS /speed controls on all 4 tires....did they check them? they said yes. No codes came back.
    So as of now:
    No cruise control, no blind spot monitor. Instrument cluster warning lights still lit up like Vegas.
    Front and rear parking sonars seem to work fine.
    4WD works.
    All HVAC working. Crappy JBL head unit working.
    So, this morning I took it to a Toyota guy down the street from my office who's been doing my oil changes, etc. Hopefully he can get this BS nailed down.
  22. Feb 8, 2022 at 3:50 PM
    BlacknWhite23
    Weird. No codes but all the stuff lit up on the dash. Doesn't make any sense.
  23. Feb 8, 2022 at 4:01 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    These things literally freak the hell out if voltages aren’t all checking out right. My battery crapped out at 2 years also and these same lights were present as the battery was shitting itself, even though it checked out “OK” as did the alternator. Replaced the battery with an X2 and the problems all just went away.
    Retired...finally and 2mchfun like this.
  24. Feb 15, 2022 at 2:37 PM
    Prather805
    Prather805 New Member
    White Tundra 1794 2017
    No previous warning signs of anything wrong at all… got into my truck this morning & seems like every light on my dash is on and blinking. Also, speedometer isn’t working. Not sure if this is the same issue you have or not, but I’m curious to see how yours turns out. I guess I’ll have to take mine in tomorrow morning to see if the dealership can tell me anything
  25. Feb 15, 2022 at 2:41 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Have you checked under the hood for any possible wiring damage from rodents?
  26. Feb 15, 2022 at 2:52 PM
    Prather805
    Yeah.. I did.. started to even disconnect the battery and reconnect it, but didn’t have time at the moment
  27. Feb 15, 2022 at 3:01 PM
    Vito117
    ANTONIO V.
    IOWA & ILLINOIS
    Taking it to yet another shop on Thursday.
    Also, another mystery since this whole damned thing began: I've noticed when I fill up the tank the mileage reset has always said "430 miles" or something close to that. Now when I fill up its shot up to 582 miles !
    No way in hell this thing gets that kind of mileage on one tank.
  28. Feb 15, 2022 at 3:03 PM
    Rockanock
    Rockanock 21 Chevy 2500
    Shoot mine died at 19k miles and the truck was 6 months old
  29. Feb 15, 2022 at 3:04 PM
    TILLY
    Massachusetts
    Well that's good news at least, let us know how you make out at the dealership.
    Prather805[QUOTED] likes this.
  30. Feb 15, 2022 at 3:07 PM
    Prather805
    same here bud… same here… everything is reset and flashing. What scared me at first is I thought my 4wd was on and that I had been driving without recognizing it was on. Thought maybe one of my kids had turned my 4wd knob. Then I realized it was everything. But yeah.. mileage, mpg, trip, all that reset. Abs, brake, 4wd, tire pressure, etc.. all on or blinking
